Question about McCulloch Garden
I have a McCulloch FH160B power washer and it no longer builds up pressure. I haven't used this very much at all. I tore it apart and cleaned everything I could find. When i pull the trigger for the spray nozzle, I get line water pressure. When I release the trigger, the power washer sounds like it starts to build up pressure. When this was working correctly, the pump would shut off when the trigger was released. Any suggestions?
5 Suggested Answers
  • 101 Answers
SOURCE: pressure washer won't build pressure
The problem sounds like its in the handle.. trigger mechinism
Posted on Dec 15, 2008
  • 10 Answers
SOURCE: pressure washer stalls out when wand nozzle is released
common for not starting unless trigger engaged as you are turning the pump as well as engine creating pressure,as for stalling pump has unloader valve which is probably in need of grease(use good silicone grease)this allows water to ciculate when trigger released.
Posted on Apr 20, 2009
  • 15 Answers
SOURCE: I have a Briggs & Stratton gas power washer. This
Sounds like the unloader is not working correctly. Try replacing it and see what happens.
Posted on Apr 23, 2009
  • 187 Answers
SOURCE: Karcher K 3.68 M operation
These units have pressure valves that automatically turn off the pump once the pressure is high enough. The pressure switches do fail and sometimes stick and act as you've described.
Posted on May 07, 2009
I have a blower/vac made by McCulloch that won't start! I tore the carb apart & cleaned it! Got it started but w n rev up! Turned I&H screws all t w in & bk out now won't start! help!
McCulloch 2 cycle leaf blower vac - YouTube
? 3:40
https://www.youtube.com/watch?v=skwugvObHtU
Dec 1, 2013 - Uploaded by Alan Marshall
McCulloch 2 cycle leaf blower vac. ... Your brand new leaf blower won't start? Try this ... starting contest echo pb251 vsmcculloch leaf blower.
cold start of my mcculloch leaf blower. - YouTube
? 4:24
https://www.youtube.com/watch?v=MgfmIezh65c
Mar 13, 2010 - Uploaded by keepin'itcountry
cold start of my mcculloch leaf blower. ... Your brand new leaf blower won't start? ... starting contest echo pb251 vs mcculloch leaf blower.
McCulloch won t start Leaf Blowers Questions & Answers ...
www.fixya.com > Forum > Tags > won t start > Leaf Blowers
McCulloch leaf blowers won t start related questions and answers. Ask your McCulloch questions. Get free help from leaf blower experts.
Nov 07, 2015 | McCulloch Garden
Is the power switch for the FH180B replaceable?
  1. McCulloch napa auto parts Pressure Washers Problems ...
    www.fixya.com > Forum > Tags > napa auto parts > Pressure Washers
    McCulloch pressure washers napa auto parts related questions and answers. ... a 7022-140a02 power switch for a McCullouh high pressure washer FH180B.
Jul 22, 2015 | McCulloch FH180B - Pressure Washers -...
How to get soap to come out of dispenser of mcculloch power washer fhh 18a
Most people make the mistake of using a high pressure tip on their power washer while trying to get the soap dispenser to work. These tips are usually red, green, white or yellow and they cause too much back pressure at the dispenser for it to work. You need to use the soap tip, they're usually black, for the dispenser to work properly.
Jun 17, 2012 | McCulloch Garden
Trigger don't release
I have a hose and gun that fits the McCulloch FHH18A that I no longer need as I had to buy a complete universal hose/gun and wand unit since I had broke the wand and the replacement wand was no longer available. If you are interested in it, email me at burmakow@nwciowa.edu and we can figure out a price.
Apr 28, 2012 | McCulloch FHH18A Electric Pressure Washer
I have a McCulloch electric power washer Model #FH170A that looks the same as the FH180. I need the Start Capacitor for it. I haven't been able to locate one localy and I'm not having any luck on...
you need the values off of it .. say 25uf at 120v volts.. the part number is a joke, as you now know trying to find one.. but enter the values and ..ta da.. i would first have the cap checked by a pro.. look for your local pool pump ELECTRIC motor repair guy with free testing .. BEST THING YOU CAN DO !
May 27, 2011 | McCulloch Garden
Mcculloch power washer fh140A 1400 PSI help
the unit will only **** up solution when the pressure is low, thats how they all work so you cant use pressure at the same time. You will notice that the pressure drops when using the solution ****..
soap 1st the pressure wash.
Jul 02, 2010 | McCulloch FH140A Electric Pressure Washer
McCulloch FH160G Pressure washer has a weak spray. Unable to locate my owners manual.
http://weborder.husqvarna.com/order_static/doc/MOUS/MOUS2008/MOUS2008-FH160G-6096160G04-966989801.pdf your owners manual. Most likely the gun needs replacement or you can take it apart and replace the necessary o rings. These are common issues with this type of pressure washer.
Apr 21, 2010 | McCulloch FH160G Pressure Washer
How do I turn the soap on my mcculloch power washer
Not sure about the McCulloch , but most pressure washers will only draw the soap in low pressure mode. either turn or pull the nosel on the end of the lance to switch to low pressure. I hope this helps.
Sep 07, 2009 | McCulloch Garden
No soap comming out of my power washer
I had the same problem on the same unit. All you need to do is pull out the front tip of the gun nozzle to engage the soap dispenser. It's as simple as that, but because there is only a tiny footprint mention of this in the instructions, it turns out to be a long drawn out problem for many of us. Hope this helps.
RP
Apr 22, 2009 | McCulloch FHH18A Electric Pressure Washer
Garden Logo
101 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
