Question about Vizio Televison & Video
I ahve a vizio 32 inch 720. it is about three years old. and on sunday i noticed a maroon line about 1/16 of an inch wide. looking at the tv it is about 8 inches in on the right. what could be causing this
  • 11,361 Answers
It can be the TFT driving circuits on the LCD panel assembly had failed (which is more likely, LCD panel will be needed), or the T-CON board.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps
Posted on Sep 29, 2010
  • German Isales
    German Isales Feb 04, 2011
    That sounds like you have a mainboard problem. I have the mainboard for your vizio 32" Model # E320VL this is the brain that drives the pixels on the screen i also have the power supply my parts are pulled from my vizio 32" the screen was cracked but every other part work fine. Mainboard is the board that has all of the RCA Components connections.
    Price Mainboard $65 Please contact me: Computertech1990@gmail.com
    Thanks
1 inch red and green lines in a strip across top third of tv
Id start by replacing the tcon board, its the small board generally at the top of the set. sometimes under a metal cover
Nov 27, 2017 | Vizio Televison & Video
Is the integral Freeview on my 32 inch Full HD TV HD or Not
Simple answer. No. But please read on . . .
Full HD Freeview, i.e 1080p does not exist. The four HD channels currently available on Freeview all transmit at 720p resolution. There is insufficient bandwidth in the TV transmission range for the HD channels to transmit at 1080p. It could be done, but it would be at the expense of other channels.
Your TV, however, is Full HD, as indicated by the 1080p in the specifications. This means it can display a full HD picture from a device which outputs at 1080p resolution. Devices which generally output at 1080p resolution include Blu-ray DVD players, games systems and PCs.
When viewing a Freeview HD channel, your TV will display the picture in 1080i (interlace) resolution. This is not true/full HD. The transmitted picture comprises of 720 horizontal lines and the software inside the TV is creating the additional 360 lines and interlacing them between the 720 lines from the original transmission in order to create a 1080 line picture which fills the entire screen.This process is commonly known as 'upscaling' and can cause deterioration in the overall picture quality, most noticably on poor quality, cheap TVs.
Hope that explains it for you sufficiently!
Nov 10, 2011 | Televison & Video
Lcd tv has black cloudy line from top of screen about 1 inch wide and 4-5 inch long down the screen
This problem is not just for Philips. I've found similar complaints online for JVC, and my Vizio 32" LCD has the same problem. In my case the TV is about 3 years old and has a lot of hours on it.
Oct 23, 2009 | Philips Televison & Video
Vizio 32" no picture only sound 1 year old 720 I
call 1-877 MY VIZIO if your set is still under warranty. If not, you'll have to find a local TV repairman to get it working again. Let him know that he can order a main board from http://www.encompassparts.com/models/?VIZVW32LHDTV10A Expect to pay somewhere around $200 if you find someone willing to do the repair.
Jul 14, 2009 | Vizio L32 32 in. LCD HDTV
Green purple and blue bars rolling through screen
It is probably the main total assy needs to be replaced.
Jun 26, 2009 | Samsung LN32A550 32 in. LCD TV
Register a 32 inch Vizio Tv
go to www.vizio.com. select the support and go down to the register your vizio. Fill out the require field and press submit. this will get your TV register.
Jun 16, 2009 | Vizio VW32L 32 in. LCD HDTV
Blue lines appeared near lower half of screen
Hello... This sounds like a convergence issue, but I didn't think they made rear-projection TVs as recently as 2013? Also, your post says you have a 32"? If it's a 32", then ignore the following.
If it is a convergence issue, parts will need to be replaced. There are usually two STK ICs and maybe some resistors that can go bad.
I hope this helps!
Nov 24, 2017 | Panasonic CT-32HX41 32" TV
Discolored lines within picture 32 inch LCD TV
I have the same tv, if you turn up the brightness and turn down the contrast that should help a little bit.... Hope this helps
Aug 15, 2008 | Vizio L32 32 in. LCD HDTV
Cant see full picture w/ Vizio 32in HDTV
You would look for a format button on your remote.
Dish Network: bottom left the asterisk "*" button
DirecTV: top left, second from the top labelled "format"
Cable remote: look for format, zoom, or aspect ratio
Pressing this button should scroll you through the options.
Apr 16, 2008 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
522 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
