Question about Whirlpool LGB6300 Gas Dryer
Dryer barrel wont spin - Whirlpool LGB6300 Gas Dryer
    Sergeant:
    Champion:
  • 351 Answers
Check belt
Posted on Sep 29, 2010
Barrel not moving
What Make and Model is it Carol? Chances are it needs a new belt. Depending on the make and model you can probably open it and check to see, and install a new one yourself.
Dec 09, 2013 | GE GTDX100EMWW Dryer
LG dryer wont start at times and will at others. If I spin the barrell it will work on speed dry only. Any other selection and it just makes a buzzing sound.
The belt may be too loose or the motor is over loaded. In worse case you need to replace either the motor or control board.
Sep 07, 2013 | LG Dryers
My dryer is making a loud noise when it spins. it hangs up in ceartin spots when it spins. do you know what may be causing this.......Eric
I can't speak to your model specifically but typically dryer barrels run over nylon glides that can wear out. They're meant to be serviced and relatively easy to replace.
It may also be the main bearing which requires complete removal of the barrel - much harder but not too hard for the DIYer.
Mar 03, 2011 | LG DLE5977 Electric Dryer
The barrel won't spin. the heat is still working, but the barrel won't spin. i may have overloaded the dryer (five pairs of jeans and three hooded sweatshirts) there was a loud bang noise and the barrel...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Dec 29, 2010 | Dryers
I have an indest 7kg tumble dryer the barrel has stopped spinning. it still heats up but wont spin.the barell can be turned by had but very stiff still. any ideas on what may have caused this or how to fix...
It sounds to me like the actual motor has stopped functioning. This could be due to a number of causes, but is more than likely due to wear of the conductive 'brushes' inside the motor itself.
I recommend having a qualified person come have a look.
Apr 15, 2010 | AEG T58840 Dryer Electric
My dryer is not heating,we have checked all of the settings, and the barrel is spinning so can you please help, the unit is about 4 yrs.old I have a maytag neptune
check ur breaker first, dryers will run on 120volts but wont heat unless have 240.
if electric check ur heating element, thermostats, and thermal fuse for continuity with a meter.
if gas check the ignitor,thermal fuse, and secondary gas coils,
Feb 05, 2010 | Maytag Dryers
I have a clunking noise when the drying cycle is running
I found a screw stuck between the dryer barrel where it spins around. I jiggeled the barrel enough so the screw fell out and problem solved.
Dec 11, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Fisher and paykel clothes dryer wont turn with clothes in it.
Hi
Most dryers work with a belt around the drum. Either the belt is stretched and needs replacement or there may be a belt tensioner which needs adjustment to tighten the belt.
What is happening in your case is that the belt is slipping on the drum as it is too loose.
Best wishes,
Graemevm
Jun 18, 2009 | Maytag PYE2300AY Electric Dryer
Dryer stumbles to get started spinning
probably need the wheels and idler inspected
Dec 31, 2008 | Amana NDE2335AY Electric Dryer
Whirlpool LGB6300 Gas Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
