Question about Sub-Zero 632 / S
Just moved into a home with a Sub Zero 632. Refrigerator side is working fine, but freezer is not cooling at all. Freezer was turned off for extended period before we purchased house.
    Sergeant:
    Champion:
  • 351 Answers
May have lost it coolant or a bad thermostat
Posted on Sep 29, 2010
Lights all went out in refrigerator side of Sub Zero 632
I WILL BET THEY ARE DISCONNECTED !!!! CHECK FOR CONTINUITY AND SEE WHERE THE CONNECTION IS OUT.
Oct 13, 2012 | Sub-Zero 632 / S
Refrigerator side does not go under 34 ang is not cooling enogh
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 26, 2010 | Sub-Zero 632 / S
Sub-Zero side by side freezer working fine frig set to 38 and is up to 50 and will not cool anything I can do?
heatman101
Dec 26, 2010 | Sub-Zero 690 Side by Side Refrigerator
I have a Sub zero refridgerator 590, the refridgerator side is not getting cold, and it's icing up inside where the fresh foods are stored, yet the freezer is working fine. Please help
The freezer coils are iced up and that is blocking the sir flow to the fridge.... You have a defrost problem and that is causing the refrigerator to be warm...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
heatman101
Nov 28, 2010 | Sub-Zero 690 Side by Side Refrigerator
Hi. My Sub Zero 632 is dripping water from the bottom corner of the freezer door. Can you tell me what the problem is and how I might fix this? Thank you so much.
It does appear that your side by side refrigerator has an ice maker, so that rules out any extra water from a faulty valve.
I think the seal on your freezer door may be broken/torn.
Usually there is no water (per se) in the freezer, but as things thaw, or as the door is opened it can create condensation that leaks. The freezer will retain cool for a while but eventually things will thaw out and water will leak.
Please check the thermostat for the freezer, and make sure there are no containers leaking in the fridge portion.
Good luck.
Sep 26, 2010 | Sub-Zero 632 / S
My side by side G E Sub-Zero is not getting or staying cold on the refigerator side, the freezer is working, what could be the problem?
check to make sure the damper door between the freezer and refrigerator is operating and not iced up so it can open fully to let cold air in from the freezer compartment
Dec 25, 2009 | Sub-Zero 632 / S
Sub Zero side by side frig. side not cooling. Freezer works fine
There is a fan inside the freezer and possibly the fridge. It circulates the cold evenly throughout the unit. The fan may shut off with the door open so hold the door switch in to see if you hear the fan. It's behind the rear cover on the inside.
Sep 11, 2009 | Refrigerators
Freezer side of 690 does not work (not even cool); refrigerator side works just fine.
Check the fan in the freezer department. It has to run when the door i closed. Sometimes the door switch is bad. This causes the freezer coils to ice up so the cold air does not go through the coil to cool the freezer. Unplug the power cord for 1 hour or two hours. Then plug the cord in and see if the freezer gets cold.
May 15, 2009 | Sub-Zero 690 Side by Side Refrigerator
Sub-Zero 632 / S Logo
204 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
