This may be one of the models that comes apart--if it is on either side you will see two plastic caps--beneath are either regular bolts or L shaped ones you turn.
Most of the sets that had the feature needed the front screen removed first to do this.
If you do not see the black plastic caps (two on either side) it does not have that feature.
SD TECH
yes it does have the two black caps on both sides. how can i take the screen off. Thank you
Get some help, two person job to remove screen.
1) Remove front speaker grill (it pulls off)
2) Directly behind is inspection plate, remove it--if front keyboard with buttons is in the bottom part of
the screen frame you need to follow the wires (usually two sets) and unplug them (inline plugs to
right and at top of opening with inspection plate removed)
3) With keyboard disconnected look at bottom of screen unit---4-6 black screws to remove.
4) Due to size screen, one person on either side.
5) Lift up from both sides at the bottom--screen frame etc engages hooks, lift about 3-4 inches
and carefully pull entire unit out.
As far as the caps on the side go====two ways they do it, one there are L shaped bolts--you turn them
until they disengage. Second way on some models they are bolts to be removed. You will know which. The caps should just pop off with a tiny flat bladed screwdriver.
SD TECH
thank you very much
