Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
I love my RCA...excpect that recently it's been exhibiting some rather odd behavior. It turns on by itself, the volume turns down on its own, the menu keeps popping up on-screen, and the channels constantly change...all without me touching the remote. Any ideas?
  • RCA Master
  • 8,617 Answers
Thats the classis sign of a failed small signal board. You can get replacement signal boards from www.tvrepairworld.com
Posted on Sep 29, 2010
My rca truflat tv's volume goes up and down by itself.
It is probably the volume button.I clipped two prongs on mine and use the remote to turn it up and down
Jan 16, 2011 | RCA TruFlat 27F520T 27" TV
I have Bose Companion 2 Series ones and the left makes odd noises
> I turn the volume to a low it still has the odd noise
If there is any drive to the speaker at all (volume not turned off), the rattle is probably coming from a broken 'surround;' the part that keeps the cone centered around the outer edge.
Another point of failure is a structure called a 'spider' that is located between the voice coil and cone that ensures the voice coil stays centered.
If there is hum with the volume turned completely down, the amplifier driving the speakers (internal or external) has a failing filter in the power supply.
Dec 14, 2009 | Bose Companion 2 Computer Speakers
Volume turns down by itself
Its the buttons on the tv, they need to be replaced, or replace the whole key pad on the tv. that should fix ur problem
Mar 17, 2009 | RCA F36650 36" TV
Volume & Menu screen flipping out
Replace all of your contact switches on front panel board power/off/on vol- vol+ ch- ch+.
Jan 05, 2009 | RCA HD52W66 Projection Television
Volume decreases by itself
maybe defective speaker or audio output ic or shorted capacitor within audio circuit
Nov 09, 2008 | RCA F32648 32" TV
BLOW OUT
Check on your deflection board for open capacitors Green & Gold writing cp150 location number 2200uf 16 v and two 220uf 35 volts.
Sep 16, 2008 | RCA HD56W66 56" HDTV
Intermittend no audio from digital inputs, flicker video monitor out, volume goes up but not down
Since the problem appears only after the unit has been run for a while, I'd be looking for any part close to a heat source. The odd behavior suggests that there is noise on the data lines for the volume control chip and the digital processing areas. Look for a bad 5V regulator +/or bad caps on the 5V line. Also check for poor solder connections in the power supply and final output stages.
Keep us posted.
Dan
May 13, 2008 | NAD T762 Receiver
RCA P52927 volumn control
The buttons on control panel are there for convince not for everyday use. Use remote, your control panel is bad.
Nov 11, 2007 | RCA P52926 52" Rear Projection Television
Volume
This sounds like a case of a dirty/defective rotary encoder. The volume control used here is not the conventional potentiometer type , but a rotary set of switches that tell the sytem if the knob is being turned left ot right.
Do you think you'd be able to open the unit and spray some contact cleaner into the rotary encoder? It might involve dis-assembling it down to front bezel removal.
jango.
Aug 18, 2007 | RCA RS2044 Shelf System
Volume is uncontrolable
Hi sounds like you have the audio out from the cd changer connected to the RCA/Phono out of the radio. double check that the output from the CD changer is going into the correct phono/rca connector regards Mark www.carradiospares.co.uk
Apr 04, 2007 | Panasonic CX-DP88 8-Disc CD Changer
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
159 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
