Question about TruTech PVS31170S1W 17 in. LCD Television
I need the screws to fasten the screen to the stand, 4
  • 11,361 Answers
They are Metric screws, M4 that you can get them from HD or Lowe's for about 35 cents each. Juts get the length from 3/8" to 1/2" to try.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Posted on Sep 28, 2010
How do I remove the stand to put my LT19C300 Samsung on the wall
Look for holes in the back of the TV just above the stand. There are screws in those holes that hold the stand on. Shine a light in one to see what kind of fastener it uses. Some are phillips head screws, some use hex head screws. Locate the tool necessary to remove the screws and take all of them out. Have someone help you hold the stand while you lift the TV off the stand.
Mar 02, 2015 | Samsung Televison & Video
How do I remove the stand from a toshiba 32hl57 tv
  • 1 & 2 Remove all cables and lay down towels on a clear space.
  • 3 Set the 32HL57, screen side down, onto the towels gently.
  • 4 Locate the four screws at the bottom center of the TV. These screws attach the stand to the Toshiba 32HL57.
  • 5 Using the Phillips screwdriver, unscrew all four screws, one at a time.
  • 6 Once the screws are completely removed, grab the base of the stand and gently pull away from the TV.
  • Read more : http://www.ehow.com/how_7318172_remove-stand-toshiba-32hl57.html
    Jan 20, 2015 | Toshiba Televison & Video
    Missing screws for stand
    Probably ace or any hardware store
    May 27, 2013 | Televison & Video
    LCD screen totally white when turn on
    The HP is a flat screen monitor used with many desktop computers. When the LCD on your HP monitor goes white, it is an indication that your monitor's inverter board has gone bad. The inverter board is a small circuit board that transfers power from the monitor's main circuit board to the LCD screen. Replacing the inverter board means dismantling the HP monitor.
    1. Power down your computer and unplug the HP monitor cable from the back of your desktop. Disconnect the power cable from the back of the monitor. Relocate the monitor to a flat work surface. Place the monitor with the screen facing downward.
    2. Remove the Phillips-head screws from the monitor's base stand and from the back cover. Lift the base stand off of the monitor and remove the back cover. Peel away the foil from inside the monitor around the internal circuit board.
    3. Locate the inverter board near the bottom of the monitor's casing. Unplug the power cables from either side of the inverter. Loosen the Phillips-head screws from the inverter board. Lift the old inverter out of the monitor's casing and set it aside.
    4. Place the new inverter inside the monitor. Replace the Phillips-head screws and fasten it in place. Reconnect the power cables to the connectors on each side of the new inverter. Replace the foil around the outside of the main circuit board.
    5. Replace the back panel and base stand, and their retaining Phillips-head screws
    I hope you find it very helpful.
    Thank you for choosing fixya.com
    Aug 11, 2011 | HP Computers & Internet
    Sharp Aquos 47 inch tv. Just moved and can't find the 4 screws to the stand, where can I buy new screws or get the specs if I were to buy new ones at Home Depot? Thx
    these are pretty common screws if you still have the box and everything it came wtih new then it perhaps may have the screw sizes included with it in there if not then go to a local fastener store as home depot sells them in large packages for even more money by going to the fastener store you can get multiple sizes in one shot try till you succeed and get more of the ones that fit while you return the rest i hope this helps and they are usually about an inch in 3\4 of an inch in length
    Nov 19, 2010 | Sharp LC52SB55U LCD TV
    I can not remove the stand from my tv
    1. Verify that there are 4 screws fastened (2 screws on each side which can be unscrewed using a hexkey)
    2. place the TV on a flat surface with the screen facing down... unscrew the 4 screws using the right hexkey size.
    3. Pull the stand downwards to take it off.
    Sep 12, 2010 | Sharp LC-52D64U 52 in. LCD HDTV
    How do I stop or reduce the front l washer from vibrating so much
    Hi
    The machine is not balanced on the floor well.... the 4 stands on which the machine rests have adjustable screws... You will need to fasten or loosen the nuts that will adjust the height of the legs on which the machine rests.... all the 4 legs need to be firmly on the floor .... If one is too high then the machine rocks on its side...
    Regards
    Berry
    Feb 04, 2010 | LG Washing Machines
    Cant find fuse box
    When you stand in front of the car, look at the battery.
    now look furter away from you - that's the air filter casing. (It has 4 screws fastening it, 3 are easily visible)
    now look even further away from you - THERES THE FUSE BOX!!! (it has a screw in the middle.)
    Jun 28, 2009 | 2003 Oldsmobile Alero
    Ge dishwasher
    If your GE dishwasher is between 5-10 years old, you may try replacing the check valve piston & nut assy (about $14). It's located on the inside in the rear of the dishwasher behind a screen which is fastened by about 4 screws. Once the screen is off, you can easily unscrew the check valve assy by hand ... install the new check valve assy ... reinstall the screen with the 4 screws ... and save yourself $400 for a new dishwasher.
    Apparently, the rubber cone in the check valve assy deteriorates over time and prevents the pump from fully draining all the water from the bottom of the d/w at the end of a cycle.
    GOOD LUCK!!
    Feb 02, 2008 | Dishwashers
    TOSHIBA TELEVISION STAND
    Can you post a pic of the stand showing its fasteners?
    Usually they are just screwed on. (But of course manufacturers have a thing about always trying to hide the screws)
    Jan 18, 2008 | Televison & Video
    TruTech PVS31170S1W 17 in. LCD Television Logo
    Top TruTech Televison & Video Experts
    Jason Morris
    Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
