Question about Dryers
Neptune gas dryer 9700 - drum turns fine, ventilation clear, but..... intermittent heat. Ignitor glows orange, then fires gas for about 10 seconds before fire cuts out - then repeats same process every 90 seconds or so.... . Likely to be ignitor, thermostat, coils? Any way to test before replacing? which one to replace first? Thanks!
    Sergeant:
    Champion:
  • 351 Answers
Ignitor that what i would replace you can test it with an amp probe your paper work should tell you how many it draws to open gas valve
Posted on Sep 28, 2010
I have a LG dryer model dlgx3002w not heating.
It sounds like you didn't install the ignitor properly. Try re installing the ignitor, because it's opening the gas valve saying it's hot enough to light, but if it's out of position, it won't create proper combustion.
Nov 23, 2013 | Maytag Neptune MDG6800 Gas Dryer
First cycle dryer will fire as normal. each time after it will not light. glow plug is working but no gas allowed to turn on. i'm feeling it may need coils for gas valve?
I would change the ignitor first...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 16, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Doesnt heat, or only works intermittently.
heatman101
Dec 11, 2010 | Frigidaire Electric Dryer
I have a gas dryer, modle number mdg9700aww.There is no heat. drum rotates and fan works. Checked the heat sensor and ignitor and both work. The dryer heats intermittantly when the back is opened up....
heatman101
Nov 05, 2010 | Maytag Neptune MDG9700A Gas Dryer
No heat in the dryer. It is Maytag Neptune gas dryer about 9 years old. The drum rotates just fine but heat stopped a couple of days ago.
heatman101
May 14, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer heats intermittently clcles off heat then
Try vacuuming lint and dust out of the burner intake and exhaust ports. Hope this helps!
Dec 05, 2009 | Kenmore 73952 Gas Dryer
GE Gas Dryer (Model DQSR 483) Drum works but does not heat
There are three things besides what you aleady checked:
1. Open the small access door in front of the dryer and start the heat cycle. The ignitor must glow a bright orange so that it is hot enough to light the gas. If there is no orange glow, then the ignior needs replacement.
2. If it glows then cuts off, then glows, again and cuts off, the thermocouple sensor wire is out of position. It needs to be very, very close to the ignitor. This thermocouple sends a temperature signal when it senses that the ignitor is hot enough to ignite the gas. Unplug the dryer. Re-position the thermocouple wire mount so that the thermocouple wire is almost touching the ignitor. You may also "bend" the wire. Plug power back on and heat.
3. If it still does not heat, then the automatic gas valve that is controlled by the thermocouple sending unit is broken. The automatic gas valve cannot be safely "fixed" and must be replaced.
Hope it's just the thermocouple wire.
Oct 01, 2009 | GE DBXR463EBWW Electric Dryer
Worked fine until today. Not heating. Drum turns well
Ken,
I am diagnosing a similar problem in my dryer. Mine is a MDG4000BWW but the part catalog looks almost exactly the same. If you haven't done so already, make sure your vent pipe is clear. Since the air flow carries away the combustion gasses, there are safety switches to shut off the gas if the vent is blocked. If the vent is clear, take off the front cover by unscrewing the four screws that hold the door and door stops. The front panel should tilt forward and come free. The gas control is pretty straightforward. There is an ignitor that heats up and glows yellow. On my machine it is on the left hand side of the burner and is very obvious. If the ignitor does not heat up, that is probably the problem. You can confirm that the ignitor is getting electricity with a voltmeter. If you don't have one try the other heat ranges on the dial. It is unlikely that all the control positions would go bad at once, so if none of them make the ignitor work I'd recommend replacing it. If the ignitor works then a solenoid (electric control valve) should open and allow gas to flow into the burner. If the ignitor goes off without the burner starting, then the primary solenoid needs to the replaced. If the burner lights but does not stay on, then there are two potential problems. There is a flame sensor that detects the fact that the burner is on and sends a signal to a second solenoid to keep the gas on. It may be hard to tell which is the problem without a meter. My bet would be the solenoid. If the gas comes on properly and stays on for more than a minute or so, but then goes off and does not come back on I think you have a thermostat problem. There are two (on my machine) one to prevent overheating and one that cycles that gas on and off to maintain temperature. The high limit thermostat is to prevent fire if the cycle thermostat fails. All the parts are available online and range from about $16.00 to $35.00. Hope this helps - good luck
Jun 29, 2009 | Maytag Neptune MDG5500AW Gas Dryer
GAS DRYER WON'T HEAT
you need to check to see if the egnitor is comeing on do you see a orange glow in there if not you will need to replace the ignitor
Mar 24, 2009 | Maytag Neptune MDG9700A Gas Dryer
Maytag Neptune MDG300aww Gas Dryer Heats On and Off
hI YES THE COILS IS WHAT YOU HAVE TO CHANGE thANKS FOR THE QUESTION tHE APPLIANCS DOC
Sep 12, 2008 | Dryers
Dryers Logo
Top Dryers Experts
