Question about Zenith Audio Players & Recorders
Model z1233ba preset radio channels, need instructions
2 Suggested Answers
  • 16210 Answers
SOURCE: How do I preset channels on the Nexxtech AM radio Model 1219833?
The most common way to set those buttons is to tune in a station and then press and hold the button down that you want to set it to. It will beep of flash to show you that it has preset.
Posted on Jun 18, 2014
How can we preset radio stations on RD-N1
I'm not familiar with this particular stereo but typically radio presets are programmed by manually seeking out your favorite channel. Once you' be tuned in, press and hold the button (usually numbered 1-5 or 1-6 for preset programming) hold the button until you hear a beep or the display flashes briefly. If this is a newer touch screen style radio, these instructions may be antiquated and most likely insulting :)
May 30, 2014 | JVC RD-N1 Micro System with CD Clock Radio...
How do you set the time on a Zenith Z1233ba
March 5, 2015.
I'm selling these Zenith Z1233BA Clock Radios
on ebay. I have sold about 10 without any problems, but someone just ask if I know where the get the instructions. I could not find the manual online.
Here are some of the basic.
To set the time set the lock button on the bottom to off, press the clock button, the clock will flash then use the set buttons on top to change the time. Use the <> to change the time, when the time is set press and hold the enter button until you hear a beep. You have to cycle through all the minutes to get to the next hour. Do the same to set the zone. And to set the Date select the CAL button and do the same as setting the time. Put it back on lock when the time, date and zone are set.
To set the Alarm press the Alarm Set button then use the set buttons on top change the Alarm time. Use the <> to change the Alarm time, when the Alarm time is set press and hold enter until you hear a beep. Press the Alarm On/Off button to select radio or buzzer for the alarm or alarm off. To set the PRESETS tune the radio to the station you want to be a PRESET, then press and hold a PRESET button until you hear a beep.
Mar 09, 2014 | Zenith Audio Players & Recorders
Bush radio ne3116 - i cannot preset channels
Choose the required station with up/down arrow buttons, press SELECT.Press and hold PRESET button until number flashes.Quickly scroll through preset channels with arrow buttons.When required preset chosen, press SELECT.
Voila: station saved!
Took me about 15 minutes to figure it out, as bought radio second-hand with no instructions, and none on internet, until now!
Sep 14, 2011 | Audio Players & Recorders
Have purchased a dewalt radio/charger through sears, was a close out where had no instruction for presetting channels 1-2-3-4 Not able to set, need instructions.
1. Select the Radio Station you want to save.
2. Press and hold the Memory button that you want that station on, 1, 2, 3, 4.
The display will flash the station number, when it stops flashing, the channel is set.
Oct 21, 2010 | Dewalt DC011 AM/FM Radio
How to set presets gpx rdt4004sp
You can store up to 10 channels. For channels 1-5:: Go to station you desire. Press MEM button. Press 1 button to store. Press MEM button again. Do the same for buttons 2,3,4,5 to store channels. After you store to buttons 1,2,3,4,5 then: For channels 6-10: Go to station you desire. Press MEM button. Press +5 button. Press 1 button to store. Press MEM button again. Do the same for buttons 2,3,4,5 to store channels.
May 31, 2009 | GPX RDT4004SP AM/FM Radio
Radio for Sandisk model SDMX1
Press the AB button to toggle between Audio Play, Radio, and Voice Record. Use the left/right scroll to highlight Radio. Then press the center button or play/pause button once to select radio.
You will see FM Radio in the upper left corner of the display. Under that you will see either Preset followed by a number OR Channel. If it is on Preset, you can use the left/right scroll to switch between preset stations. If you press and hold the AB button, the player will scan through all frequencies to find the strongest stations in your area and set those as the default preset stations. When on a particular station, press and hold the record button to delete that station from your presets.
Press the center button once to switch to Channel (or back to Preset). Under Channel, you can manually scroll through the frequencies yourself. Push left or right and hold for about a second to find the next available station.
Press the play/pause button once to toggle between Mono and Stereo.
Those are all the functions I've found so far. Hope it helps.
Good luck,
vw
May 26, 2009 | SanDisk SDMX1-1024-E18 MP3 Player
Zenith Z212G radio, Need preset modification instructions
Zenith Z212G radio, preset modification instructions
  1. Display desired station
  2. Press Memo Set button to make "Memo" flash on display
  3. Select desired preset number
  4. Press Memo Set button to save
Apr 12, 2009 | Zenith Z115S Clock Radio
Channel programing for presets A B & C
http://www.xmradio.com/pdf/hardware_support/delphi/roady2_guide.pdf
Nov 10, 2008 | Delphi Roady2 SA10085 XM Radio Receiver...
Cannot get to tune one station to next station
Does the radio have a full subscription? Next, check the "Preset/Direct" button and push it until "direct" is lit up. Then you can directly enter the channel number. Also, you can go into the MENU and set what channels to skip and jump to. My guess is that you bumped the "Preset/Direct" button and your radio is in "PRESET A or B or C" - you need direct. Try that first, than get back to me - okay? BTW, I'm assuming you're talking about an XM satellite radio like the one in the photo?
Oct 28, 2007 | Delphi Roady SA10035 XM Radio Receiver
422 people viewed this question
Top Zenith Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Greg Cann
Greg Cann
Gagan Telecom
Gagan Telecom
Level 1 Expert
Are you a Zenith Audio Player and Recorder Expert? Answer questions, earn points and help others
