Question about Dell W5001C 50 in. Plasma HDTV
Dell symbol flickers when you put tv on,black screen but have sound.had problem before,was told it could be power supply had it replaced ,worked fine 4 days later went out magain what could it be?
  • 130 Answers
Hi yes it could be the power suply but if you had a light gray horizontal bar in lower part of the screen before it went out this spell big problem other wise it maybe only power suply
that can be bought on ebay
Posted on Sep 28, 2010
Model 50LN5700-UHBUSYLJR. Why is there sound but no picture??
Chance your led strip if you are sure that your power supply led module is working perfectly
Jul 20, 2015 | LG Televison & Video
Sony 52xbr4 screen flickering
Fault with the main power supply regulator board. Ubnormal DC voltage output from it. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and precious time.
Aug 29, 2014 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Tv screen flickers then turns black. has sound but is very faint.
The power supply may be failing, leading to video instability.
Nov 01, 2017 | Polaroid Televison & Video
Screen flicker/going black
the problem is power supply replace it.
Apr 15, 2013 | Samsung Ln40b540 TV
I have a Vizio VF550XVT1A. The screen started to
Hi Alfred Grace,
First of all, thank you for posting your question here at Fixya.
Based on the symptoms you've described, I don't believe that the backlights are already faulty. If backlights gone to malfunction, that are permanent, but in your case you've said that the TV power up fine for half an hour, this is an indication that the fault not came from the backlights but from the inverter boards. Inverter boards are the one giving high voltage to the backlight to light up, it has a built in protection circuit that will activate once there's a malfunction on the board to avoid further damaged because of high voltage output.
If you would like to fix it yourself, I would advice you to replace both the slave and master inverter board. I saw your board at shopjimmy.com. Click it HERE for the replacement. Replacing these boards are not technical, all you have to do is to unplug the unit overnight to drain any voltages from the power supply board, disconnect all connectors and then put-in the new boards. No soldering required. If just in case that the inverter boards are not the issue (I'm pretty confident that the power supply board is working fine), don't worry, the link I've provided accepted return, the fault is on the power supply board.
Hope I helped you.
Have a nice day!
Good luck and take care!
Jdvillanueva
Dec 21, 2011 | Vizio VU42L 42 in. LCD TV
Plasma tv takes time to start then picture flickers really badly then picture returns as normaal for a few hours then goes black but still has sound i turn off tv for a number of hours & repeat the...
This tv seem to have two problems.The problems that the tv take a long time the tv to turn on,the tv power supply board have dying capacitors most likely.That the board where the power a/c cord plug into it.The picture flickers badly this problems is harder to determine because this causes by two backlight buffers boards X,Z buffers boards could be either one it is dying.This tv should get an estamate by a shop or shops and repair it by them,bcause the tv must have to be doing replacing x munbers capacitors components to the tv power supply board and alot more work to trouble shoot and to detrmine which of the buffers boards it is the causes of to the picture screen to be badly flickers and replacing it.
Jun 10, 2011 | LG 42PX8DC Plasma TV
My Dell 1905FP 19 monitor went black & green power light flickers
It sound like a short circuit. I had this problem with 1907FP model. It had an USB port on the monitor which got damaged and it was shortening to the groung. In your case it might be a bad internal power supply board.
Nov 20, 2009 | Dell UltraSharp 1905FP 19" LCD Monitor
Tv is black when turning on tv
well i have the exact same problem with my tv... was told i need a power supply, an ssb mainboard, a y buffer board and a y main board.................. sucks!!!!!!!!!!
Sep 29, 2009 | Philips 50PFP5332D 50 in. Plasma...
Screen black - power to tv is good.
The power to the TV may be perfect but the supply in the Tv that provides power to different areas may be bad and need to be replaced. there could be a bad capictor in the power supply that is cause.
Jul 10, 2009 | Westinghouse SK-26H520S 26 in. LCD HDTV
Dell W5001C 50 in. Plasma HDTV Logo
136 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
