Question about HP LaserJet 3600n Printer
HP LaserJet 3600n I replaced the black cartridge. The new one was defective and continuously calibrated! - so replaced it with another one. Before figuring out that the cartridge was the problem I downloaded the latest drivers from HP - (Nov 2008?) for a fix.... But with the new cartridge and after full calibration, all graphics now print in extremely poor quality. I used to be happy with the print quality - but now it is unacceptable. The "narrative" print appears fine - but all graphics have about a 50% shadow and the small ones are illegible. Any ideas?
  • 734 Answers
Yes,
Go to Computer, then System Properties, The Device Manager. Down the list of devices you will see "Imaging Devices". Open the category and dowble click on your printer. Go to the Driver tab, open and,
Marcus choose.."Rool Back Driver" and follow the instructions.
Regrads
Posted on Sep 28, 2010
  • 2 more comments
  • Marcus
    Marcus Sep 28, 2010
    Sorry about the typing. It's been a long day
  • Marcus
    Marcus Sep 29, 2010
    One other comment for you, if the driver rollback doesn't have the desired effect, a full and proper uninstall and re-install of the printer will likely solve all issues. With HPs this is not as straightforward as you might think, but I am an expert at laying out the steps so that when the printer is re-installed, if anything about the printer does not work, you know to look elswhere. Troubleshooting is not alwys either quickly accomplished no completed. It wouls also be VERY helpful for you to provide the version of your Operating System and exact model # of your computer.
    Marcus
  • alison_mo420 Sep 30, 2010
    Well, I uninstalled and reinstalled (it went directly to plug and play and not to the original CD I had in)... and it still doesn't print the graphics right.
    This is a Dell 2400 computer using XP.
    And - When I tried to install from the disk (Xp - autorun) - it says "file not found???"
HP laserjet 3600n magenta and yellow color are not visble
Replace it for a new cartridges. If continues the problem check the laser, clean it.
Jun 21, 2011 | HP LaserJet 3600n Printer
I installed new cartridges (4 colors (B, Y, M & C) and closed the top cover, it calibrating continuously for a week and more. So, please help me to solve this issue. My printer model is HP Laser Jet...
Hi I'm sorry to say its normally a faulty cartridge.
You now the black belt in the front of the machine well the machine when it calibrates prints a pattern on the belt and it uses this pattern to calibrate its self but if the pattern is not on the belt it can not finish the calibration.
solution replace the toners one at a time until you get it going
yours Ian
Mar 08, 2011 | HP LaserJet 3600n Printer
HP 3600n color printer only printing solid black page. cartridge is fairly new. what is the problem?
defective cartridge or problem whit laser/scaner assy - replace cartridge ( to solve this just turn back your old cartridge and try to print something to be sure before you buy new one) - visit HP servise for laser/scanner assy
Sep 29, 2009 | HP Color LaserJet 3500 Printer
3600 cartridge
You might be able to cancel the calibration. If not try to power it down and back up. If this doesnt work you probably have a bad cartridge. They have microchips in them and if they are defective it make strange things happen.
Aug 29, 2009 | HP LaserJet 3600n Printer
I also have a Color Laserjet 3600n printer. It keeps on calibrating without stopping when I switch it on. why ? I seen another posting with the same problem. I can not find a solution.
In the menu reset the memory and all active i/o channels. If still problem encounters then try replacing the cartridge. I think cartridge has some problem
Jun 23, 2009 | HP LaserJet 3600n Printer
Can't stop the printer calibrating
No guarantee this will fix your problem, but the last time I experienced this problem it ended up being one of the toner cartridges. I replace her refurb. toners to OEM brand.
Jun 02, 2009 | HP LaserJet 4600dn Color Printer
Have a Color Laserjet 3600n printer. It keeps on calibrating without stopping when I switch it on. why ? thank sin advance.
600 Hp Continuous Calibration 1 Votos
This is an answer to most of the problems of "continuous calibration" in the HP 3600.When the printer begins to constantly calibrate and falls in line so we have a problem, there are several causes for that problem and must be discarded from the simplest solution to the most complex.
Let's begin:
SOLUTION 1: The first thing to do is turn off the printer, and remove the cartridges, toner dirty or if the internal parts of the printer remove the excess, if there is dirt in the transfer belt clean.then close the front cover and turn on the printer without cartridges. then open the lid, place the magenta cartridge, and close the lid again, and so putting the four cartridges. If the problem persists try the next solution.
Solution 2: We must be alert to any strange noises in the printer, it is likely that one of the sticks is failing, if we are a strange noise came from, and replace the cartridge.
SOLUTION 3: There are times that it is software problem can be solved with a "COLD RESET" to do this we must turn the printer, and press the green button several times in the main menu until you see some options, navigate to the Down Arrow button until COLD RESET appears, press OK. the printer will restart and initialize. then restart and probably reached OK status.
SOLUTION 4: Sometimes by changes in temperature and environment where the printer is out of calibration sensor, to do a need to upgrade the firmware of the printer, usually ends the problem here. To download the firmware of the printer with the improvement due to "Countermeasure for multiple Successive Causing Environmental Sensor Calibrations." Is in the following link:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=501044&swItem=lj-44336-1&prodNameId=501046&swEnvOID=54&swLang=8&taskId=135&mode=4&idx=0
SOLUTION 5: If any of these options serves, it is likely that the mirrors of laser printer are dirty, this requires us to print a sheet to observe defects in print (moved, blurred, misplaced shadows), if any of these defects appear we disassemble the printer for cleaning the laser ... in this link are instructions
http://ingenioysoluciones.wordpress.com/2010/04/12/limpiar-espejos-de-la-impresora-hp-3600n-para-corregir-impresion-defectuosa/
May 26, 2009 | HP LaserJet 3600n Printer
Hp Color LJ 3600 continue. Calibrating
Had a similar problem with a customer's printer. HP tech support had me change out the environmental sensor and the boards, this did not fix problem. In the end we had to get a replacement printer (thankfully the unit was under warranty)
Jan 10, 2009 | HP LaserJet 3600n Printer
HP Color Lserjet 3600
We found that we had a defective cartridge. We returned it. A replacement cartridge did not cause the printer to callibrate continuously.
Hp 3600n repl. cyan cartridge & mach. is in continual calib mode
Let's begin:
SOLUTION 4: Sometimes by changes in temperature and environment where the printer is out of calibration sensor, to do a need to upgrade the firmware of the printer, usually ends the problem here. To download the firmware of the printer with the improvement because of "Countermeasure for multiple Successive Causing Environmental Sensor Calibrations." Is in the following link:
Nov 20, 2008 | HP LaserJet 3600n Printer
HP LaserJet 3600n Printer Logo
232 people viewed this question
Seeker5211
Seeker5211
