Question about Miele Novotronic W1918A Front Load Washer
Check Inlet My Miele washing machine was in the middle of a wash cycle and the check inlet botton flashed red. What do I need to check or clean so solve this?Where is the inlet? Many Thanks!
What's reason of the check inlet warning
Posted on Aug 26, 2012
    President:
  • 1,314 Answers
Where the water lines attach to the washer at the back un screw them and check the screens on the water valves see if rust or trash is restricting the water flow
Posted on May 24, 2008
I have a Miele Novotronic W 828 the check inlet red light is flashing - what do I do?
Hi dear. Seems to me your machine needs new inlet valve replacement.Due to it's age, it's quite normal. Thanks.
Jan 26, 2016 | Miele Washing Machines
Miele washing machine w 487 check drain and check inlet
Clean out the pump trap. If you are on well water or just have very hard water, your inlet valve may be becoming constricted as well, remove the fill hoses from the back of the machine and shine a bright light into the valve to see if the screens are getting clogged with debris: In this case, follow the instructions the computer is giving you.
Apr 12, 2013 | Miele W487 Front Load Washer
Miele W1926 check inlet light flashes at he end of rinse fill
Hi Yugin.That indicates your machines water inlet valve is faulty.(Means it's taking less water then normal)Please check this steps & do it fast before water inlet is finishes:1-Turn your machine on & run empty with pre-wash cycle first.2-Please ajar the detergent drawer & check runing water on compartment one 3-Please press pre-wash button & compare the running water volume on compartment two.If the running water volume 1 is less then 2 or vs.water valve needs to be replace.That's causing problem.I hope that helps.Thanks.
Jul 26, 2010 | Miele W1926A Front Load Washer
Inlet blockage red light flashing
Try turning the machine on its side, undo the bottom and check that the polystyrene float (attached to a switch) is not somehow jammed. This float cuts off the water if the machine leaks internally, and produces the symptoms you describe. It's a really good machine so don't throw it away!!
If that still doesn't help then it might also be the motor brushes, which produce similar symptoms - if your machine starts to fill but then flashes and just drains again, it's almost certainly the brushes. This might be the case after you check the float problem.
Sep 05, 2009 | Miele Novotronic Premier 500 Front Load...
Meile W 844 Drum not turning
Its probably the motor brushes you need to replace them
May 10, 2009 | Miele Novotronic W1918A Front Load Washer
Red light flashing
red light is check drain?
Clogged by something.
Could be a coin.
Use to have large coin when i was young and forgot remove from my jeans. So mum made me repair that every time. In that case filter clean, but coin bloking filter inlet.
Not necesarily coin in your case.
never buy these deals over Ebay my advice.
If you have the machine already then this is first to look for.
Nov 16, 2008 | Miele W310 Front Load Washer
Miele Novotronic W 844 Washing Machine
Pete,
When I had this problem I went along the entire water inlet route and verified flow. Water flow entering the soap dispenser tray should be very robust & audible; if not, you have a flow restriction or low pressure, flashing red light or not.
I'm stating the obvious because I actually missed some filter elements the first time I tried. Disconnect inlet hose at plastic fitting on chassis and verify your flow there. Then look inside the inlet barb and use a small pair of channel lock or lineman's pliers to grasp the tab on the inverted "basket" and pull it straight out. These filters can be packed full of sand and small gravel inside--they were in my case.
Good luck,
Adam
Aug 03, 2008 | Miele Novotronic W1918A Front Load Washer
All Miele washing machines and dishwashers need to fill in a required time. Flashing inlet (Tap icon) indicates that the machine can not fill in time. There are filters in the end of the hoses which connect to your water supply from the machine and filters in the inlet valves which you can get at by removing the hose from where it fixes onto the machine it'self. You will need some long nose pliers to grab the little tab on the small filter to get it out. Clean all filters and hoses. Still same problem then check the pressure of the water coming into the machine. There should be a good pressure coming out of the hose and will be difficult to stop the flow of water with your finger.
Dec 20, 2007 | Miele Novotronic Premier 500 Front Load...
Miele Novotronic W1918A Front Load Washer Logo
1,814 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
