Question about Maytag Neptune MAH5500B Front Load Washer
How do I get to where you clean the hose filter screens
  • 347 Answers
If you shut off the water supply and remove the hoses from the back of the machine they are right inside the fittings from where you removed the hoses.
Posted on Sep 29, 2010
Washed some dirty runners & 2 small rugs on Daily Wash; came up with error code 5E cleaned debris filter any idea where water hose mesh filter is?
Usually on the back where hoses are attached to it . inside hoses are screens . turn water off ,unscrew the hose and check , then put hose back on tight .
Feb 14, 2016 | Washing Machines
The cold water does not flow correctly, there are no kinks or blockages in the hose. I believe it is the cold water solenoid as the hot water works fine.
If you have any cold water at all the filter screen in the water valve is dirty.
Turn off the cold water.
Remove the hose from the cold water valve connection on the washer.
Use a bent paper clip to remove the filter screen from the valve.
Clean the screen and replace it in the valve.
Re-connect the water hose and turn the cold water supply on.
If the screen is already clean,replace the water valve on the washer.
Jul 17, 2011 | Washing Machines
Fowl odor in front loader
Clean out the small holes in the gray door gasket (at the bottom) to allow water to drain back into tub. Open access door at bottom left on front of machine, use small hose to drain remaining water from machine, remove and clean out filter there. Re-install. Run washer on the tub clean cycle if you have that cycle, or if not, use the longest, hottest cycle you can, but make sure to use a commercial washer cleaner like Affresh, Washer Magic, Whirlaway hot tub cleaner, etc., with no clothes in the washer. After cleaning tub, make sure you only use one tablespoon of HE detergent per cycle, and only one teaspoon of fabric softener per cycle if you use softener.
Feb 13, 2011 | LG WM-2277HW Front Load Washer
How do you clean the polaris feed hose?
Where the hose connects to the wall you push the fitting in and turn it 1/4 turn then pull out. Inside the fitting is a screen that will clog up. Remove this and clean. If you have a cartridge filter this will need to be done after cleaning the filter. If you have another filter you may have a problem with the filter and will need to check this out. Good luck.
Mar 24, 2010 | Zodiac POLARIS 380 HEAD/HOSE INGROUND POOL...
Washer will not fill with water. How do you clean hose filter screen? where is it located?
Hose filter screens are located inside the screw-on hose connectors at both ends of the hose. Turn off the water supply. Unscrew the hose from the water supply and look inside the end of the hose for the filter screen. Do the same where the hose is connected to the washer.
Dec 21, 2009 | Maytag LSE7806A Top Load Stacked...
Slow Cold Water Fill
There is possibly a filter screen in the hoses as well as the water valve.Check the hoses for screens.Occasionally the water valve will deteriorate inside and must be replaced.
I am on a water well and have the same problem. This weekend I installed a inline filter purchased from Lowes. It has stopped the sand and silt problem. You will have to buy one extra water hose to do this yourself.
Jul 16, 2009 | Kenmore 22422 Top Load Washer
Cold water just drips, hot is fine, good pressure.
turn off water then remove hose. filter is in the fitting on the machine where the hose connects. pull out filter and clean or replace it
Apr 19, 2009 | Maytag Dependable Care LAW9406
Kenmore 90 Series fills so slow on rinse cycle
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside where you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 09, 2009 | Kenmore 15944 Top Load Washer
Front load ge washer does not finish cycle
This model does not have a drain filter. There are filter screens inside the inlet valve where the hoses attach onto the machine. Take hoses off and look inside where the water goes into machine to see screens. Also, take the other end off hoses to make sure there are not screened hose washers in either end of the hose which may need to be cleaned or replaced.
Oct 18, 2008 | GE WSXH208A Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
122 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
