I have a Konica 7022 that i need a driver for so i can use as a printer and scanner etc. I have down loaded drivers and nothing i find works the right way. Please help!!!
5 Suggested Answers
Beni S-P
  • 1006 Answers
SOURCE: I need the driver to install the sharp am900 scanner
here u go and let me know if ur problem is fixed:
http://www.google.com/search?hl=en&sa=X&oi=spell&resnum=0&ct=result&cd=1&q=download++Sharp+SHARP+AM+900+Printer+DRIVER&spell=1
And please rate this solution as FIXYA if ur problem is fixed
Posted on Nov 16, 2007
SOURCE: Hp Deskjet F370 All-in-one Printer.Scanner.Copier
HOW CAN DOWNLOADS HP DESKJETF370 DRIVER
Posted on Sep 26, 2010
SOURCE: konica minolta 1390mf driver + windows7
Konica Minolta in Japan don't know when the 1390mf driver will be available. Still waiting also
Wayne
Posted on Dec 21, 2010
  • 278 Answers
SOURCE: I have an epson stylux
hello the driver is ready to download from here just chose you system expl... and download it nooowwwwwwwwwww
http://driverscollection.com/?H=Stylus%20TX200&By=Epson
Posted on Jun 11, 2011
Konica 7022 26-3
Yes I stated what I recommended to do in your last post!
Jul 12, 2014 | Konica Minolta 7020 7022 7025 Copier Drum...
Copy of konica 7135 is unclear while running. at first is copy is clear, later the copy is not clear... blurred
try to make some copies from your pc if the results is ok that simply means something with your scanner unit, for exaple the pnnel needs to be lubricated and the ccd unit needs to be cleaned.
Mar 20, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
I have a Konica Minolta 7022 printer, scanner, fax, and copier machine. How do I get it to scan?
Please see this website complete manual for Konica MInolta 7022 printer I think i can help your problem
http://help.nceas.ucsb.edu/images/2/2a/Konica.pdf
Thanks
May 10, 2011 | Konica Minolta Office Equipment & Supplies
USE KONICA 7025 AS A PRINTER...
have you loaded the print driver on your computer? Does the machine have a print controller (IP 011/421) and networkcard (KN303) Can down load print driver software at Konicaminolta.us
Mar 10, 2010 | Konica Minolta Office Equipment & Supplies
Konica 7022 with Problem code F-26-1
There is toner/starter spilled onto a sensor near the drum, it mite just need to be cleaned, this sensor monitors the drums abililty to develope a image, if the cleaning does not work it mite be the sensor or the drum. The drum needs to be removed to clean the sensors.
Mar 23, 2009 | Konica Minolta Office Equipment & Supplies
Mita/Kyocera ai3010 and Konica 7022 Tarpon SPrings, fl
Kyocera Mita Ai 3010 works well only with OEM toner. Print System has no decent drivers for XP and forget about Vista. Doc feeder needs separation rollers every 15,000 feeds. I will replaced it if needs more than $250 in parts.
Feb 14, 2009 | Konica Minolta Office Equipment & Supplies
Can't start up Konica Minolta Elite 5400 II
This problem usually occurs when the scanner software crashes, or the scanner is turned off in operation, or the computer is shut down before you quit the software, etc.
The K-M driver software gets corrupted.
I use mine with a Mac G3 Tower and OS-X v 10.4.9.  What I do is search for all the Konica-Minolta components using OS-X spotlight and then delete them.  After reinstalling the K-M driver software and restarting the mac, the scanner should work fine.
Nov 15, 2007 | Konica Minolta Dimage Scan Elite 5400 II...
143 people viewed this question
jasbo
jasbo
