Have an HP monitor and have a white rectangular shaped box that pops up in the center of the screen constantly, in the center of the box it says OSD Lockout. Can not get it to go away. What do I do?
    Scholar:
  • 128 Answers
To resolve the issue you can hold the power button of the monitor until you get another message something similar to "OSD unlocked". Now if the problem continues, switch off the monitor and remove the power cable then let it sit for a couple of minutes to 5 and connect it again.
Posted on Sep 29, 2010
Osd volume control won't go away
bad switch i monitor.
fix switch
or new monitor.
its just a switch, it closes and OSD pops. on demand by said switch, OSD is a timing processor in the display that has the OSD code in it , "program"
Mar 25, 2017 | HP Computers & Internet
A white block appears in the middle of the screen... it says" OSD lockout" occasionally it will disappear for a moment, but then returns or a large black box that has "Main Menu" at...
Fix One: Plug in the monitor and power it up. Hold down the Powerbutton until you get a message saying "OSD Unlocked". If the problem persistsafter OSD is unlocked then unplug the monitor from the wall, wait 20 secondsand try again. Fix Two: Turn on the monitor and hold down the Menu button for 10-20seconds. This should unlock the OSD. Fix Three: Turn off the monitor, press down the Menu button and thenturn on the monitor. Wait 10-20 seconds. This should unlock the OSD.
Aug 10, 2011 | HP Pavilion w22 22" LCD Monitor
Hi i have a problem in my hp lcd screen.Its HP L1906 (19'') ,the problem is that the Main menu pops up without pressing the menu button .And a black phrase in a small white box in the middle comes...
Press the menu button and navigate until find "factory reset" and select ansav/exit.
If you need more help post back!
Thumbs and testimonial are welcome!
Jul 08, 2011 | HP L1906 19" LCD Monitor
Unwantred announcments in the center of the screen
This problem comes from the control switches on the front panel. I had the same problem and fixed it by opening the monitor (unscrew 3 screws on the back side, remove plastic shape of the stand, unscrew 5 screws of the stand and open the back; unscrew the 2 screws of the button switch panel). Now inject contact spray on every switch button. If the problem remains you may have to replace the button swithces. Thats all!
Oct 12, 2009 | Philips 190V6FB 19" LCD Monitor
The osd main menu has appeared on my hp pavilion f1703 monitor
Control Panel->System->Hardware->Device Manager->Monitor. select and uninstall. Then let Windows detect the monitor and re-install the drivers for your monitor. Do the same for the disply adapter in the Ctrl Panel.
Aug 24, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
CANNOT REMOVE THE OSD MAIN MENU FROM MONITOR SCREEN
The problem of OSD Menus popping up automatically are usually caused due to a faulty switch in the Menu button which is getting switched on automatically.
This menu will not harm the computer but constant OSD menu will most probably lead to permanent damage to the pixels in the LCD screen plus it is a constant irritation to your eyes which are most precious.
This problem can be rectified by replacing the faulty menu switch. Hope this solves your problem Thanks.
Jul 23, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
OSD lockout appears constantly in center of screen. (HP w1907)
If you have tried changing hook up cables and tested your monitor on another computer with the same result. You have to take the monitor in for servicing. Something has gone wrong in the control circuit and it needs repair. Hope this helps.
Apr 14, 2009 | HP Compaq WF1907 Monitor
My computer screen has a blue box that pops up and say "Controls locked". I am assuming that the buttons on the bottom right hand corner of my moniter is what it is talking about because when I hit the...
This is from the user manual for the monitor. You can download a copy from hp here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=324216&os=228&lang=en&
Click on the "monitor user's guide" link to download.
There are four adjustable options on the OSD settings screen: Lock OSD settings, Timeout, H Position, and V Position.
To change OSD settings:
1 Open the OSD setting screen under the Advanced menu. See
“Using the On Screen Display” on page 25.
2 Press the Browse buttons to select the option you want to adjust.
3 Press the Select button to check the option.
To change OSD lock setting:
1 Press the Browse button to select yes (lock) or no (unlock). The
setting is automatically saved when you change the value.
2 Choose Exit sub-menu and press the Select button to return to
the OSD Main Menu or press the Menu button to exit OSD.
NOTE: Once OSD is locked, all OSD functions including the
shortcut buttons are disabled. If OSD is locked, pressing
any button on the monitor directly opens the Lock OSD
settings window so that you can unlock OSD.
Dec 02, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Whereabouts and meaning of OSD
OSD stands for On Screen Display. You get to it by pressing the Menu button on the front of your monitor.
Here's a link to making adjustments...and unlocking the OSD:
HP f1703
Oct 18, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
OSD doesn't appear
You will find the number one motto from many of the Tech's is "If it ain't broke, don't fix it!!!" If you must fix it try the latest drivers for your video card and for the monitor. The OS(XP) is always changing. Keep the drivers up to date. Otherwise. Don't mess with it. Good Luck, Let me know what happens. Tim
Mar 06, 2007 | LG Flatron F700P 17" CRT Monitor
Computers & Internet Logo
133 people viewed this question
David Payne
David Payne
