Question about Whirlpool Refrigerators
My freezer is not getting cold enough. I'm not positive how old it is as it was in the home when I purchased it. The freezer is on the top and has been fine up until a couple days ago. I took all of the food out and only put new trays in to make ice. 1 of the 4 trays froze. I did vaccum the back and the front underneath. The fan isn't running in the freezer however the 1 in the bottom of the fridge is. I can't see the 1 in the freezer so I don't know where it is. Any suggestions ?? It is a Whirlpool model # ET22DKXN00 and the serial number is ED3146283. Thank You, Cindy Padlo cindypadlo@sbcglobal.net
  • 1 more comment
  • cindypadlo Sep 29, 2010
    I did order a fan. I hope it works.... I'll let you know. Thank You very much !!
    I'll try this suggestion!!
  • cindypadlo Oct 09, 2010
    Problem solved....... Thank you !!
  • Whirlpool Master
  • 3,361 Answers
Hi Cindy,
You already figured out your problem.
It is the non-working freezer fan motor.
If the freezer fan motor does not run,the freezer barely freezes and the lower fresh food compartment gets a little warm.
You can get a fan motor from a local appliance parts store if there is one in your area.
If not,order online from www.repairclinic.com .
To replace the fan motor,you would unplug the refrigerator.
Remove everything from the freezer including the ice maker.
Remove the screws from the back wall of the freezer and then pull the freezer panel out of the way.
The fan motor will be right in front of you.
Let me know if this helps you.
Good luck.
Posted on Sep 28, 2010
Smeg fridge freezer FA421XS not cooling
There is copper lines by the compressor it sounds like its low on freeon the cooling chemical you can purchase a kit and weld a valve on the in line and load it up with more freeon that may work
Oct 12, 2014 | Smeg FA421X Top Freezer Refrigerator
Fridge not keeping things cold enough
fridge coldest setting is 1
freezer warmest setting is 1
Dec 08, 2017 | Fisher and Paykel E522BLXEZ EZKleen...
Used Kenmore freezer won't get cold enough
If it is running but not cooling enough the problem is in the sealed system.
If you started it up just after hauling it home it may have be moved around enough to get oil in the systems smaller tubing causing problems. Unplug the unit for 24 hours and let it sit. Try it again for 24 hours and see if it cools.
If not this means either there is a refrigerant (freon) leak in the system or a restriction causing the refrigerant to not flow properly.
Either one are an expensive repair. and will require a professional to look at.
May 09, 2010 | Kenmore 5 cu. ft. / 142 liter Chest...
I have some problem with my AMANA BX20ML Model REFIGERATOR
You may have a bad condensor fan motor or paper may have gotten pulled under the fridge and jammed the fan blade. The energy switch will not help with cooling it only controls exterior moisture.
Feb 16, 2010 | Refrigerators
Why does freezer get cold but not refrigerator side?
Check the freezer temp (available in most grocery and home improvement stores). The temp should be between 0-10 degrees F (not just barely below freezing).
You can also try to find a solution on www.repairclinic.com or click here.
Aug 13, 2009 | KitchenAid KSRG25FKSS Side by Side...
Hotpoint CTF15ELD top freezer refrigerator - freezer O.K. refrig too warm
It's likely the door was inadvertently left open, and the cold air passages from the freezer have built up enough ice that the cold air from the freezer has no way to enter the refrigerator. Check the cealing of the refrigerator. If you can see or feel ice in the passages between the freezer and fridge, you can probably solve the problem by finding a safe temporary home for your food, and leaving the refrigerator unplugged overnight.
May 25, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Ice maker stopped working, plus fridge not cold, but freezer o.k.
I would check that fan motor in the freezer section is running. it distributes cold air from freezer into refrig section also if this motor is running the top portion of freezer will not get cold enough to allow ice production. the motor is easy to repl and is mod# specific you should be able to buy one online.
Jan 21, 2009 | Kenmore 64802 Top Freezer Refrigerator
Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
Nov 10, 2008 | Frigidaire FRT15B3A Top Freezer...
Freezer not getting cold enough
I think your system has a leak and has lost the refrigerant charge.
The only way to check is by accessing the sealed system. Most systems are covered for five years on the compressor. Contact the place of purchase and give them your indications for your problem.
Jul 06, 2008 | Freezers
Have you tried re-gassing your fridge maybe one of your lines may have a leak,let a refrigeration technician check it out to certain
Nov 28, 2007 | Refrigerators
Refrigerators Logo
126 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
