Question about Whirlpool RBD305PD Electric Double Oven
Error code E6F2
What does this error code mean E6F2
  • 2 more comments
  • borisnoris May 24, 2008
    what does this error code E6F2 indicate
  • dpayne0098 Jul 02, 2008
    The oven has been out for several days off and on. Then all of a sudden the E6 F2 error code came on. What does this mean?
  • dplumb Jul 07, 2008
    I also have the E6 F2 problem. I've already tried the first step of tripping the breaker off then back on. I left it off overnight. I'd like to try to clean the connections myself. Can anyone tell me how to access the control pannel or key pad?
  • Anonymous Jan 21, 2009
    Does anyone know how to fix this problem. The repair people tell me it might mean my control pad needs preplaced. It will cost me $342.00. Does this sound right and how hard is it to repair myself?
    President:
  • 1,314 Answers
I got a tech sheet for your range accept this message as a fix ya and e mail me at b4829@yahoo.com and ill send it back as an attachment just say f2 e6 code
Posted on May 24, 2008
Hi Electrolux cooker 607601 error code 4 f on the top oven when using the grill what does that error code mean. Kind regards
It is good practice to specify model of appliance
(like EOG9330XN).
Probably means temperature range of oven sensor exceeded
(for more than 5 seconds).
Dado
Jan 10, 2015 | Electrolux Ovens
Door latch stuck
This error means your temperature sensor (probe) has failed and needs to be replaced.
Nov 05, 2014 | Whirlpool GMC305PD Electric Single Oven
I have a kenmore elite oven what does an error code F-3 mean
Th eF3 error code means that their is a problem with the tempature sensor...this tip i wrote expalins what the F3 error code means.
http://www1.fixya.com/support/r10343697-error_codes_f3_f4_mean_oven
GENE
Oct 03, 2011 | Kenmore Ovens
Just got error code "fe02"
The F2-E0 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F2-E0 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced . GENE
Sep 18, 2011 | KitchenAid Ovens
What does error code "F-1"
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced GENE
Sep 09, 2011 | Ovens
Whirlpool double oven gives E6F2 error code what is the problem?
Hello & Welcome to FixYa
F2-E6 error means open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you want to do it yourself and wan to be sure before replacing the sensor then you can test it with a voltmeter between 1080-1120ohms....if it reads more then or less then this then it needs replacement however, if the reading is around between 1080-1120ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Feb 15, 2011 | Whirlpool RMC275PV Double Oven
When I turn the GE oven on sometimes it works fine other times it will shut off. When it shuts off it will give the F2 or F3 error sign.Can you please tell me what this means? Thanks
Hi, the F2 Error code means the oven has detected an excess temperature condition. Most often this is due to a bad temperature sensor - the sensor costs about $75 from an online repair site.
The "F3" error code means the oven sensor is open, I suggest you flip breaker off then back, on Re check for error, if OK fine if not turn back off and fix or call for service man...
Oct 06, 2010 | Ovens
I have an AEG Electrolux oven D8800-4 double oven and have ann error code A3, what does this mean?
I hope you mean error code F3. if so then that means a software error and if you disconnect from mains supply then reconnect this should reset the fault if that does not work you may have a damaged circuit board.
Hope I helped.
May 06, 2010 | Electrolux Ovens
Whirlpool electric range RF361 bxdn 0. error codes? PF?
hi Jon
look on the back of the unit, there should be an envelope that has a paper in it, that paper should tell you what the code means.
Apr 01, 2008 | Ovens
Whirlpool RBD305PD Electric Double Oven Logo
487 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
