Question about Electrolux UltraLux 2000 Bagged Canister Vacuum
My electrolux model e canister vacuum won't turn on when I flip the switch even though it's plugged in to the outlet.
LizDahl
  • 75 Answers
SOURCE: Electrolux Advantage Series canister vacuum
There is an area on the back of the tank where you will see lines, put your thumb there and pull the top half of the tank towards yourself. That should open the machine so you can replace your after filter.
Posted on Dec 29, 2007
LizDahl
  • 75 Answers
SOURCE: electrolux canister vacuum
The easiest solution would be to call your local Aerus/ Electrolux representative, because the corporation doesnt publish diagrams.
Posted on Jan 12, 2008
SOURCE: Ambassador 111 Electrolux canister vacuum,
Had same problem about a year ago. Had it serviced and was advised the power harness of which the retractable cable had to be replaced.
Posted on Jul 01, 2008
  • 566 Answers
SOURCE: Electrolux #1521 Canister Vacuum won't stay closed
hi from uk your problem with the canister cover/door coming off whilst vaccing ? you have renewed bag ? ok but there is a filter/gauze also inside the canister where bag is fitted if you check inside you should see the filter at opposite end from where bag is secured it is usually fitted behind a slotted pull out plastic gate ? this filter/gauze is to allow air out of canister when vaccing and the filter traps any dust that may accumulate inside the canister case so the dust does not get blown out to atmosphere/rooms SO if this filter is clogged it will not allow vacced air to escape out of canister so result is build up of pressure within cylinder and eventually cover flips open ! so for now you can remove filter/gauze and wash then dry refit this will allow air to escape from canister but still retain dust particles from escaping as it is designed for however may i suggest you replace filter when convenient ? all above is on assuming that the latch on cover is working ok and not now damaged ? hope this helps best wishes
Posted on Mar 01, 2009
galati2k
  • 281 Answers
SOURCE: No suction on my Electrolux central vacuum in all outlets even though motor is running and there is no clog in the hose.
go to the main unit,you have a blockage where the suction originates.can you disconnect the main suction line to the unit?do that and turn it on.if you have suction then then the main suction tube is blocked.a towel or rag of some sort got sucted in and got caught before it made it to the dirt tank please leave feedback
Posted on May 06, 2009
My back wheel won't roll on my electrolux 2100. If I turn the cannister over, I can spin the wheel, but when I place it right side down, it just drags on the floor. How do I replace it?
Hi you need to find a local Vacuum repair place one that deals in Electrolux, and go there and take the vacuum or the make and model, and ask for a replacement part, that is the only way that you would be able to obtain spare parts, in fact while you are there, perhaps even inquire as to how much it may cost to do it? ask for a "Quote" and go from there.
Oct 07, 2011 | Electrolux UltraLux 2000 Bagged Canister...
I have a Electrolux canister model L-E (circa 1986). Won't turn on. I think the foot switch is broken inside. Was working fine - turned it off then would not turn on BUT foot switch sounded different,...
I have one of these LE models also. Yes, the on/off button is broken. I have had to replace it twice on mine. My local vacuum repair shop suggested NOT to use your foot to operate this switch, but just press it on or off with your fingers. That will help to keep it from breaking.
Jan 10, 2011 | Electrolux UltraLux 2000 Bagged Canister...
My electrolux oxygen won't turn on. Could it be the switch and can I fix it myself?
mcdevito75 here, The first thing is to make sure you are useing a live or good wall outlet. Then you can try the on / off switch a few times. If this doesn"t work it may be the switch itself. Look for an appliance repair center in your area.
Jul 23, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux Harmony Not working
maybe it is clogged. does the light go out if you turn it on with no bag?(for testing)
is the roller spinning?
Jan 07, 2010 | Electrolux Harmony Canister Vacuum -...
The on/off buttons are not working anymore? Any
With your hose plugged into the vacuum, check your cord at the outlet, is it securely plugged in? There are no signs of cord damage? If so, you will need to take it to the shop,but it probably just has the wrong sequence in the power buttons.. turn on the main unit switch then turn on the hose switch to the canister, if no power, then hit the switch on the machine again, it should power up, if it does not, open up the bag compartment, and shut it again, making sure that the bag is aligned inside and the cover is closed tightly. Did this fixya? Let me know. You may need to contact electrolux for a replacement hose. they are really good about warranty service and will send yu a new hose at no charge if they determine that is the problem. Here is some contact info. Thanks, Rene(the Vacuum Doctor)
http://smallappliances.electroluxusa.com/node47.asp
Nov 13, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
May 05, 2009 | Electrolux Central Vacuum
My electrolux canister vacuum roller does not spin even though it has power.
When the vacuum is one and the switch for on for the carpet position. There is a small button the the floor attachment which we call the power head. It will b in the place of where the head becomes L shaped its either black or red. Push the button while the machine is on. If it does not work call ur electrolux dealer and have them pick it up. Or call me I'm a dealer and can have UPS pick it up no charge for u 1-866-966-9350.
Sep 26, 2008 | Electrolux Guardian Bagged Canister Vacuum
Electrolux UltraLux 2000 Bagged Canister Vacuum Logo
70 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
