My 42" LCD flat screen tv, is showing no power. I have checked all connections, and even tried a different plug. 2 other items are on the same circuit and they are working. The tv was working fine this morning, but when we got home this was our problem. Any suggestions?
    Champion:
  • 367 Answers
It sounds like the power supply is bad.Open the back of the TV,and look at the can shaped items called capacitors on the circuit boards.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.I hope this helps.If you have any questions,please let me know.Thank You very much!
Tyler
Posted on Sep 28, 2010
Hi I have teviono 42" lcd4203id model and tv is white picture nothing on there the TV powers up light comes on but it doesn't bring picture what the fault would be?thanks
TEVION 42" FLAT SCREEN LCD TV MODEL LCD4203ID
www.ebay.co.uk/.../TEVION-42...TV-MODEL-LCD4203ID-/1213...
eBayTEVION 42" FLAT SCREEN LCD TV MODEL LCD4203ID in Sound & Vision, Televisions ' eBay.Missing: white
main board for tevion lcd4203id 42" lcd tv mhdv4201 ... - eBay
www.ebay.co.uk > ... > Other TV & Home Audio Accs.
eBayMAIN BOARD FOR TEVION LCD4203ID 42" LCD TV MHDV4201-ZC01-01 (B) ... Mouse over image to zoom .... *Please open the back cover of TV then check the part number of screen, it would be on white label at back of screen ... of actual item in yourTV as well as check either if it is compatible with your TV model.
LCD TV Repair made easy # 1 - YouTube
? 7:38
https://www.youtube.com/watch?v=GryA_Zl4EBk
Aug 27, 2009 - Uploaded by Grants Pass TV Repair
I have a 2008 model Sanyo dp42848 42' lcd tv with ccfl lighting. .... bought a Seiki tv and within 1 month ...
LG 42LC2D 42 in. LCD HDTV Fusing unit - Que
Dec 29, 2015 | Televison & Video
Nothing on screen when DVD inputs are plugged into our Aquos.
Check that the input you are plugging the DVD into on the TV is actually selected as the TVs input. Try using a different input and also different input types/cables. Most DVD players will have HDMI and also either component or composite type outputs. Try the different cable type and make sure the TV is looking at the correct input. Do you have sound?
Feb 11, 2015 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Its stays on sold red when powered on . when i remove the invertes cable that connect to the power supply it turns green then i can power it on to blue ! but when i plug the invert cables back it stay red...
With a flat screen TV, this is a bad symptom indeed. If you wish to get some details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy. Surf the site with patience.
Screen shots to defective flat screen TV are given. You can compare it to your TVs' screen and can make sure about the fault.
Jan 26, 2014 | Proscan 42LA45H 42 in. LCD TV
My 32 inch lcd tv green line in panel
Try unplugging as suggested. Also, try different inputs (HDMI, component, etc.) and different cables to be sure it's not some external item causing problems or just one input. Also plug it into an outlet on a different circuit in your house.
If everything you try still shows the lines, it's probably the screen itself and is too expensive to fix.
Nov 14, 2013 | Samsung LN32A330 32 in. LCD TV
Vertical lines on lcd toshiba tv
I'm sorry that the TV is displaying vertical lines on the screen. Please follow the troubleshooting steps and check the operation:
Please make sure that the connections are secure and proper.
Try connecting a different video source like DVD player or VCR and check the operation. If it works with another device, the issue might be with the input device currently.
Also try connecting the device to a different port in the TV if no other devices are available.
If the issue persists, try with a different cable.
Perform a power resetting and check the operation. To perform the power resetting, unplug the TV from wall outlet for more than 2 minutes and then reconnect it.
If the issue persists, after all above troubleshooting steps, service may be required. You can click hear to setup a service for the TV.
Also it would be good if you can come back with the model # of the TV to check whether the issue can be resolved with a firmware update.
Thanks for understanding. Please let me know if you require any clarifications/additional help.
Sep 26, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Have an insignia tv that won't power on...was off..made popping noise...won't power on. checked power in both the surge protector it was in & wall. all other items plugged into surge protector work....
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 27, 2010 | Insignia NS-LTDVD19-09 LCD TV
I turn on the tv and it has a blue screen and no
Just try to reset so picture will back to normal again, some LCD TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the LCD TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the LCD TV power button for five seconds.
4. Plug the LCD TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the LCD TV is responding again.
6. Turn off the LCD TV and reconnect the devices.
7. Turn on the LCD TV.
Hope it may help you;
Regards;
VOTIT
Apr 23, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
Vizio 42" LCD. Flat screen. Won't display CC on setup screen using HDMI input. Have a Sharp tv on another Directv box and it shows CC via HDMI connection. Problem with receiver or with TV? Costco's "Help"...
CC is a feature of the TV. All TVs are different in features and the Vizio is limited on its features due to cost. To eliminate the directv receiver connected to Vizio TV just swap with the receiver connected to Sharp TV and see if CC is displayed.
Mar 05, 2009 | Vizio VO42L 42 in. LCD TV
Problem conecting hp laptop to sony bravia 52" hdmi tv
u need 2 change ur pixels 2 1024 by 768 in display settings then click the screen with 2 on and extended ur display to it ,then open windows mobility center and click connect display this will open a screen with 3 options chose the bottom 1 use external display only or sum think like that this should work once u have ur display showing on ur tv then click connect display again and chose the top option and u should get ur display on both screen let me know if this solves ur prob it worked 4 me regards davy ps if u plug in and loose control of ur lap top i think uv already selected use external display only try changing ur pixel 2 1024 by 768 and try again if not u need 2 plug into different tv nd change this if u have any more probs with this let me know this prob had my head dun in 4 days tryed the tech guys nd they said my tv port was broke liers(there a wast ov time)
Jan 19, 2009 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
