Question about Sharp AR-M205 Copier
My Sharp error display
On the screen it says L6 and nothing can be done with the copier. Can I have some assistance. I can be reached at 954-520-0006 or pierrot9@comcast.net
  • mgibbons Sep 09, 2008
    L6 flashing,
    Problem Solver:
  • 3 Answers
Check poligon motor if it is runnig through diagnostic mode or replace it,,,also you can remove it and look if needs oil.
Posted on May 25, 2008
My sharp AR-5316 is displaying an error code L6. please what could be the possible fault and solution. mzm from dubai
Error code L6: Polygon motor lock trouble Details : The polygon motor does not rotate. Possible Cause :
  1. Polygon motor unit failure
  2. Polygon motor connection harness trouble
or disconnection
  1. MCU PWB failure
Solution:
  1. Replace the polygon motor.
  2. Replace the MCU PWB.
Oct 14, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-M205 - Error Code L6
Hello sir; "L6" display it means laser motor defect need to replace.
Aug 19, 2009 | Sharp AR-M205 Copier
Sharp AR 163 display L6 error
The error is for the polygon motor if you have done the test for the motor and it doesnt work I think thereis the answer because they spin so fast the motors will eventually go if it had been a little noisy p[rior to this then it has a read or seize error if you know how to take it out youcan manually gently spin it to see if it is stuck just make sure you use a clean dry cloth to cover it prior to turn as you might mark the mirrors.. Good Luck A
Jul 01, 2009 | Sharp AR 163 Copier
Error code L6
L6 is a Polygon Motor Lock
You could try to reset the machine with a simulation code 14, which to perform it:
1. Push Clear, Auto, Clear, Auto in a steady rythmic fashion. If done correctly the screen will go blank and all the lights will turn off. If done incorrectly wait 15 seconds then try again. Clear is the red "C" and auto is on the left hand side, the word auto directly above the button.
2. Once you're into this mode enter the number 14 as if you were doing 14 copies then push the green copy key.
If the L6 returns after the reset then you will need service on the machine, Sharp will fix it for a flat rate charge of $140.00 for parts and labor out of warranty. Give them a call 1800 237 4277 in this case.
Dec 26, 2008 | Sharp AR-5316 Advanced Digital Imager...
Gunawan
Hi Gunawan,
The error 'L6' is usually an indication of problems with the Laser Unit in the copier.
Unfortunately the unit will have to be replaced and can only be done by trained personnel.
Contact your closest Sharp Dealer for assistance.
Regards
Gavin
Oct 13, 2008 | Sharp AR-5316 Advanced Digital Imager...
Error code L6-10
sir, I ma indian & I have a tosiba estudio 161 I have problem diaplay in on display screen when i switch on the start so display show screen ---
Jul 02, 2008 | Toshiba e-Studio 161 Copier Copier
Sharp display error
hi!
your ploblem is en the poligon motor,,,replace it with a new one or you can remove from the machine and look if needs a little bit of oil.
May 24, 2008 | Sharp AR-M205 Copier
Sharp -AL1644 flashing L6 error
Feb 29, 2008 | Sharp AL-1641CS Laser Digital Copier
Sharp AR-5316, showing L6 on display
The L6 code means trouble with the laser unit ( polygon motor), it has to be replaced. The laser unit is under the exit tray. Hope this helps.
Jan 02, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-M205 Copier Logo
59 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
