My HP computer keeps restarting to password screen. If I enter password it logs on but then restarts minutes later. If I don't enter password it simply restarts anyways.
  • 27,725 Answers
One bad lead will cause your computer to continue in a cycle
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
hope this helps
Posted on Sep 28, 2010
How to recover my windows xp passwords
For Xp, usually we use Safe Mode to reset windows password.
First, restart your computer, keep pressing F8 before Windows XP loads, then select safe mode and enter, you will see the default administrator account appears in the login screen, click that account and enter your system, go to control panel to change your other account password. When it finishes, restart the computer, log in the related account with the newly created password.
If the method above can't help you ,try to use the Windows PassWord Reset ,it is very easy and safe.
Jun 09, 2012 | Microsoft Computers & Internet
I have a aspire acer 5520 laptop and lost my password. I have no disk to reset it and create a hole new user. what can I do?
Well, have not created reset disk before, you can try to reset windows password in safe mode, this method do not get help from other precondition.
Here are how it works:
First, restart your computer, keep pressing F8 before Windows loads, then select safe mode and enter, you will see the default administrator account appears in the login screen, click that account and enter your system, go to control panel to change your other account password. When it finishes, restart the computer, log in the related account with the newly created password.
And if you failed reset in safe mode, I recommend you use a windows password reset tool to create a reset disk, this method 100% guarantee.
The process isfollowing.
Step 1: Download the Windows Password Reset and burn a erasable CD/DVD, or USB
Step 2: Boot the CD into the ISO image which is provided by Windows PasswordReset
Step 3:BIOS settings
Step 4:Reset the Windows admin password.
Itis an easy-to-use way to reset the password. You can have a try.
May 10, 2012 | Acer Computers & Internet
Forgot my password to my hp pavilion
Forgot HP password?
You can reset hp password by the safe mode, just do as the following steps,
Step1: You should restart your computer, and keep pressing F8/F2 toenter the Safe mode.
Step2: After enter the safe mode, you can see the default administratoraccount, just click it to enter the system.
Step3: Open User Account in control panel, pick the account you have forgottenthe password to change the password.
Step4: Restart the computer, you will log on with the newly created password orwithout password
May 09, 2012 | HP Computers & Internet
Computer would not booy up. now it does but the password does not work
which operating system ant what type of computer??
Restart your computer
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
also
how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased
or if using XP
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer Advanced Boot Options screen appears. Select the Safe Mode option using the up and down arrow keys, then press the ENTER key. Choose "Windows XP Home/Professional", depending on the version of the operating system. Press ENTER. Shortly, the welcome screen should show.
Log in as "Administrator". Click Yes to not use System Restore Mode.
Click the Start button. Choose Run and type in "control userpasswords" (without the quotes). Click OK.
Select the "Administrator" user. Click Change my password. Enter a new password in the corresponding text boxes. Click OK. Write this password down and store it in a secure place Close the User Accounts window and restart Windows.
hope this helps you
Sep 10, 2011 | Computers & Internet
I have a HP Compaq dc5700, and i want to set it to default settings. I do not have any passwords for it. It has windows vista. i tried going to setting(f10) and it asks for a password. I removed the...
Password Security
Establishing a Setup password:
1. Turn on or restart the computer. If you are in Windows, click Start > Shut Down >
Restart.
2. As soon as the computer is turned on, press F10 when the monitor light turns green to enter
Computer Setup. Press Enter to bypass the title screen, if necessary. If you do not press F10
when prompted, a restart will be necessary.
3. Select Security > Setup Password and follow the instructions on the screen.
4. Before exiting, click File > Save Changes and Exit.
Restart.
3. Select Security > Power-On Password and follow the instructions on the screen.
Changing a password:
1. Turn on or restart the computer. If you are in Windows, click Start> Shut Down > Restart.
To change the Setup password, go to step 2.
To change the Power-on password, go to step 3.
2. To change the Setup password, as soon as the computer is turned on, press F10 when the
monitor light turns green to enter Computer Setup. Press Enter to bypass the title screen, if
necessary.
3. When the key icon appears, type your current password, a slash (/) or alternate de-limiter
character, your new password, another slash (/) or alternate delimiter character, and your new
password again as shown:
current password/new password/new password.
NOTE: Type the new password carefully since the actual characters do not appear on the
screen.
4. Press ENTER.
The new password will take effect the next time the computer is restarted.
Deleting a password
1. Turn on or restart the computer. If you are in Windows, click Start > Shut Down > Restart.
To delete the Setup password, go to step 2.
To delete the Power-On password, go to step 3.
necessary.
3. When the key icon appears, type your current password followed by a slash (/) or alternate
delimiter character as shown. Example: currentpassword/
4. Press Enter.
from
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00794304/c007943
04.pdf
Feb 09, 2010 | Computers & Internet
I restarted my Hp 510 laptop and it completely got
well, you can try pressing CTRL+ALT+DEL while on the log on screen if you're using xp... are you?
Nov 14, 2009 | HP 510 Notebook
How to Reset HP Mini 1000 Laptop BIOS?
http://laptoppassword.blogspot.com/2011/06/hp-mini-password-service-compaq-mini.html
Clear Bios Password for HP Mini - Compaq Mini:
HP Mini 1000, HP Mini 110, Compaq Mini 110C, Compaq Mini 110, HP 2230S, HP Mini 1120LA, HP Mini 1151NR, Compaq 700....If you see this screen on boot:Enter CURRENT Password: [_______________]
We can help you Remove Password, right now !!!
You just enter 3 random passwords one by one and see if you get a similar [System Halted] message with 10 chars Error Code. (e.g CNUXXXXXXX, 2MCXXXXXXX....)
Jul 16, 2009 | HP Mini 1000 Netbook
Problem to log in.
Start up in safe mode pressing F8 on boot up and select safe mode. When in the system under administrator there will be option for you to delete the password on your account. Re boot then enter again with no password.
Feb 22, 2007 | Toshiba Satellite M100 Notebook
Computers & Internet Logo
David Payne
David Payne
