Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ge side by side refridgerator
The freezer works only 50% of te time
  • Situsav May 24, 2008
    the freezer works only 50% of te time on a
  • robert samples May 11, 2010
    please be more spefic on your promblem hows the refridgerator side look to see if there is frost on the bottom back panel on the freezer side is the freezer fan running etc ...what do you mean by 50% of the time more info more we can help
How to activate the adaptive defrost on the side by side refrigerator
Posted on Feb 23, 2009
    Champion:
  • 210 Answers
Check frost pattern on evaporator.
Posted on Jul 22, 2008
Hi we have a norfrost chest freezer it is freezing everything but bread on superfreeze when we take it off of superfreeze it defrosted the bread
sounds like the thermostat is at fault or more than likely the refridgerant gas has partially escaped due to a leak, check te seals on the doors first. hope this helps.
Oct 09, 2016 | Freezers
Freezer stops working if temp in house is set to 50 degree other people close to us have same unit and set their place at 50 degree, their freezer still works both 8 months old
call for a repair person house ttemp has nothing to do with freezer working or not . and 50 degrees , isn't it cold in there all the time
Mar 15, 2015 | Refrigerators
Why won't my refrigerator and freezer stay below 50 degrees?
Barbara, does it stay at 50 degrees even if you set it lower? I have a similar problem but temps. look ok.
Jul 30, 2014 | Maytag Refrigerators
Freezer not getting cold enough (20-25) and fridge at 45-50 and running all the time
Check and clean the coils. If that doesn't work, then the Freon needs recharged.
Jan 23, 2014 | Kenmore Refrigerators
Casio TE- 2400: How do I add a 50%
After you enter the item at full price during a sale, just type 50 and press %- button.
If anyone needs a programming manual for a Casio TE-2400, c-tech has it here:
http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-2200_and_TE-2400_dealers_manual.html
Apr 01, 2012 | Casio Parts Cash Register PC Desktop
Not cooling freezer/frig.
starts to work but then stops again? Yes that could be the motherboard but I would test the fan with direct voltage to see if it will run a long time.
Aug 14, 2009 | GE Profile PSS26NSTSS 25.5 Cu. Ft....
TE-72 sporadic hammer
You should have no more than 70cc of oil in the housing. AW46 Hydraulic fluid will work.
Aug 12, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
NATIONAL NR232-TE-X IS NOT MAKING ICE .
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
fdjdfh
Jun 05, 2009 | Hoover HCA454FK Bottom Freezer...
Whirlpool side by side refrigerator not cooling
Hello danielscynt,
Welcome to Fixya,
You said, freezer is fine the refrigerator is 50-65 does not get colder than 50.the evaporator fan is working but it seems to be blowing very little air
Have a 1998 Hotpoint Model # CTX16CAZDRAD Serial # ZS738209. The refrigerator is not cooling. Temp is at 66 degrees with setting at 5. The Freezer is working, but it seems to be running all the time. Please help!
There are a few things that come to mind!
The Freezer is working, but it seems to be running all the time, you said!.
This could be a bad thermostat!
But lets try some simple maintenance first!
Is your freezer packed too the hilt with packages???????
Where the articles cover the air vents in the freezer?
The freezer and the fridge share the cold air and the passages must not be blocking the cold air from moving out of the freezer!.Search your freezer !
Also your fridge is 10 years old!
Did you ever remove the plastic grille at the bottom of the fridge along the front, and GENTLY run a refrigerator brush along the black metal tubes running back and forth under the fridge?
( You can buy this brush at any hardware store $10.)
They must not be covered in ten years of lint and dust. These narrow tubes carry the freon and run in this parallel fashion back and forth, so they are cooled by the air being **** through them.
if not and they overheat your fridge will get warm.
If the tubes are found to be covered or submerged in dust sometimes I have found them one to two inches thick in dust, and sometimes they are even not visible until you clean the dust out.
Then it will take 10 to 24 hours for the system to get back to full working temperature again. As long as the heat did not cause permanent damage!
if these are not the answer, then you may need a hands on diagnoses!
BUT, most of the time these two things are what I find!
Let me know how it goes!!!!!!!!
Thank You for asking my advice!
Huuum
Please remember to leave a rating for me!
Oct 08, 2008 | GE Hotpoint Top-Freezer Refrigerator
we had the same problem. called a repairman and they had to replace the electric unit - about $268. But I STiLL have that horrible high pitched noise every time the fan kicks in. About 20 minutes every hour. I have to leave the room. It kills my ears!
Sep 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
74 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
