I have a Superscan TV/DVD/VCR model 19TVD3S (2003?). The remote control quit working, even after replacing the batteries. Is there a code or key function to re-associate the remote to the TV?
SOURCE: Need a remote control code for a Sansui TDC2075 TV/VCR/DVD combo
Contact Fox International parts at 1-800-321-6993
or Sansui troubleshooting hotline at 800-289-0980
thanks
Posted on Nov 13, 2007
  • 3 Answers
SOURCE: remote control not working and need programming code for cable television/universal remote control
you can get one at
http://remotes.com/
LTD1510
MALATA
Posted on Dec 13, 2007
  • 346 Answers
SOURCE: QUASAR TV WITH VCR REMOTE CONTROL CODES
try code 021 or 125
Posted on Dec 26, 2007
  • 68 Answers
SOURCE: remote control will not work
That is certainly unusual for a remote receiver to go bad unless it was struck directly or exposed to damage. Anyway.... the procedure obviously involves getting to the PCB to replace the module. I've not worked on that exact model, but all CRT televisions are similar, and that one is made by Orion.
There really are two options: Front and back.
You can go in the back way, by removing screws and such until you can pull the rear housing off. Make sure you first unplug the unit for about 15 minutes. Leave it unplugged.
If you are uncomfortable doing this, then, please, buy a new TV.
I STRONGLY suggest that you discharge the main capacitor by grounding the anode. If you don't know what this means, then buy a new TV. You don't need a special tool, just a long, flathead screwdriver grounded with a wire to an earth ground will do. If your are afraid of getting shocked, buy a new TV.
The CRT will be mounted in a chassis attached to a main PCB at the bottom. It will be screwed to the housing face. You will have to separate the chassis/board from the face of the housing also, being careful to remove all the screws around the front input assembly. The housing removal is quite easy, but it will take time. You will then be able to locate the IR module at the front of the board. Carefully de-solder it and install the new one. Reassemble.
Somethings I would do before I undertook this venture:
Be ABSOLUTELY sure that the IR module is at fault. Not the remote.
Check the IR module for 5V at Vcc to rule out a faulty IC.
Confirm replacement module is similar in pin-out, freq. (bandwith), voltage
Reserve a good afternoon block of weekend time.
Chill some brews.
Create a large work space if you don't have a bench. And if you do have a bench, clear some space.
Be prepared to be without this TV forever, because everyone screws up sometimes.
The front inputs may give a bit of trouble. Take it easy there if you wish not to break anything.
If you are afraid to open the back. You could always go in the front. Unplug. Dremel a hole under the IR module using a depth limiter. Remove Vcc from existing module. Piggy back new module. Tada! Cake. Remember that is you put it under the board, the pins will be reversed.
If you are careful enough, after the anode, there is not much to screw up besides some broken plastic or bent front inputs.
Good luck.
Posted on Jun 30, 2008
SOURCE: Philips Universal Remote with Emerson VCR/DVD Combo
http://www.urc.philips.com/
US2-PM335
There you will find all needed information
Posted on Jul 05, 2008
What is the code for my sony tv remote control DVD VCR COMBO
Ray, Check the attached links,remote codes.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Sony eSupport Remote Control Codes Programming Select Model
New 3 digit codes for DVD VCR DVR SAT TV VCR TV DVD DVR CABLE and DVR DVD...
https://www.att.com/support_media/images/pdf/uverse/set-up-code-list.pdf
Mar 08, 2016 | Sony Televison & Video
How to program my LG BP330 blu-Ray remote to my Superscan tv,dvd, vcr combo model SSF 420TR?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Aug 26, 2015 | LG Televison & Video
I cant find programeing codes 4 a 2004 superscan dvd-vcr-com tv/model ssf-420tr
I have the same tv and code 174 worked for me. Another to try is 183 or try the Sylvania codes.
Mar 06, 2011 | Televison & Video
Hello. I have a model # URC-4640Boo and am trying to set it up to work an a Sony dvd-vcr combo model # SLV-D300P and can't seem to find out how. Can you help me?
Configuring codes:
1.Turn on a desired device (VCR or DVD player)
2. On the remote control, press a device key once (i.e., DVD/VCR,
CBL/SAT or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press DVD/VCR once. After programming a VCR Combo device, you will be able to control channel selection,volume, and VCR functions.
To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once. After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions.
To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer’s Codes to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly,
the LED will blink twice.
5. Aim the remote control at the device and press POWER once. The device should turn off. If it does not, repeat steps 2 to 5, trying each code for your brand until you find one that works. If it still doesn’t work, try Searching For Your Code on next page
Auto Code Scan:
1.On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice, then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly press POWER button.Stop when the TV turns off
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 to 5, but substitute the appropriate device key for the device you are searching for.
Thanx
Jul 17, 2010 | One For All URC-4605 Remote Control
Why does a TV remote control quit working?
Assuming you have changed the batteries, you might try blowing around the edges of the keys with "canned air" spray.
Most likely you can go to a drug store and buy a "universal" remote that will serve as a cheap replacement.
NOTE WELL: check out the "universal" remote's labeling and online to make sure it is compatible with your set BEFORE buying.
Jan 02, 2010 | Broksonic SC20145 20 in. TV/VCR/DVD Combo
I need a remote code for a emerson lcd lc195em82
1. Manually turn on the component you want the remote to
control (TV, VCR, DVD, satellite receiver or cable box).
Note: If you press an invalid key during the Auto Code
Search, the remote does not respond and the illuminated
ON•OFF key does not blink. If you do not press a valid
Auto Code Search key (TV, VCR•DVD, SAT•CBL, ON•OFF,
GO BACK, PLAY, REVERSE, STOP), the search times out
after two minutes. When the search times out, the illuminated
ON•OFF key blinks four times and turns off. The last
programmed code under that component key is retained.
2. If you are programming your TV or satellite receiver, go
directly to step 4.
3. To program the remote to control a VCR or DVD. The
VCR•DVD key can control only one component, either your
VCR or your DVD. To program your remote to control
either your DVD or your VCR, you must first put the
remote in the proper programming mode. Follow these
directions before proceeding to step 4.
a. Press and hold the VCR•DVD key.
The illuminated ON•OFF key
turns on.
b.While holding down the
VCR•DVD key, press and release
the number 2 key on the keypad to
control a VCR or the number 3 key
to control a DVD. The illuminated
ON•OFF key blinks, and then turns
back on.
c.Release the VCR•DVD key.
blinks four times and then turns
off. Your remote is now either in
VCR or DVD Programming Mode,
depending on which you chose.
Proceed to step 4.
4. Press and hold the component key
(TV, VCR•DVD, SAT•CBL) you wish
to program. The illuminated ON•OFF
key turns on and remains on.
5. While holding the component key
down, press and hold the ON•OFF
key. The illuminated ON•OFF key
turns off.
6. After holding down both keys for
three seconds, the illuminated
ON•OFF key turns back on.
7. Release both keys. The illuminated
ON•OFF key remains on.
VCR•DVD
VCR•DVD
VCR•DVD
ON•OFF
(BLINK)
ON•OFF
(BLINK)
ON•OFF
ON•OFF
(BLINK)
SAT•CBL
VCR•DVD
TV
TIP: Throughout the programming of each key, be sure to
keep the remote pointed at the IR sensor of the component you
are currently programming the remote to control.
8. Press and release the PLAY key,
then wait five seconds to see if
your component turns off. If your
component does not respond,
continue to press the PLAY key
every five seconds until your
component turns off. Each time you
press the PLAY key, the illuminated
ON•OFF key blinks and a block of
10 codes are sent to your component.
This process continues until all of
the codes in the Code Lists have
been searched. (If your component
has not turned off after all codes have
been searched, the illuminated
turns off. The Auto Code Search
Entry method is exited.)
PLAY
ON•OFF
(BLINK)
10
11. To confirm that the component key is programmed with the
correct code for maximum functionality, test the component.
Attempt to control a variety of the component’s functions
with the remote. If some of the features of your components
do not work, try programming the remote with a different
code in the list until you find the code that allows the remote
to control the majority of your component’s functions.
Different codes can provide different levels of functionality.
Mar 26, 2009 | Televison & Video
TV Remote control
my remote control quite working - I have replaced batteries, but it still will not even turn on the tv.
Oct 12, 2008 | Toshiba MV13L3 13 in. TV/VCR Combo
I need a remote Code
The comcast remote control code for Superscan VCR/DVD combo is 11963
Dec 27, 2007 | Televison & Video
DVD SETUP
hi try these Code For Model RCR450 (the closest i found) Code 1000/3160/2000 for RCA TV/VCR/DVD Code 1000/3408/2000 for RCA TV/VCR/DVD http://www.rca.com/customerservice good luck windman
Dec 19, 2005 | RCA B27TF680 27 in. TV/VCR/DVD Combo
Televison & Video Logo
208 people viewed this question
Top Televison & Video Experts
