Question about Hotpoint First Edition FEW10P Front Load Washer
Miele 500 premier - drum will not spin
Drum stopped spinning & I can hear the motor turning.
  • Anonymous Mar 25, 2014
    drum keeps spinning
  • 1,294 Answers
Your belt must have come off.
Posted on Mar 18, 2009
What could be wrong with my Miele Novotronic premier 500 If I use the drain/spin the machine makes a grinding noise which I~ don't hear when I use the washing programme
hi my guess is that as the machine is on drain & spin that is the time when the pump which drain the water is turning to empty the water and hence it also on when on spin to get rid of the water .
I think you may have a foreign body in the impeller of the pump , ( paper clip , a pin needle etc., ) usually by removing the filter which is located by the pump you will find foreign body in the filter but sometime these clips /needles / nails they get imbedded in the pump housing with long nose pliers they will pull out , but be careful not to puncture the pump housing
Nov 24, 2017 | Miele Washing Machines
On spin machine makes a loud whining and drum/door seal get very hot
Bearings are in bad shape ergo used up. Recycle it as repairing it is to expensive.
Mar 31, 2016 | Miele Novotronic Premier 500 Front Load...
Miele 500 washing machine inlet light comes on and machine wont pump water out or spin
try leaning against door when pressing start . if it runs get the switch replaced
Jan 24, 2016 | Miele Novotronic Premier 500 Front Load...
Loud thumping noise in spin and smell of rubber with smoke when door opened
there are diffrent kinds of front load units some have rotor and stator issues you sound like yours has motor with belt possible bad belt or motor.
or its shaft and bushing is going.
Nov 02, 2012 | Miele Novotronic Premier 500 Front Load...
Miele w1113. Washer drum won't spin during wash cycle
I assume you are saying the machine is working except the drums not turning? - you need to see if the belt has come off because thats what i would check first if you hear the motor start/stop after it fills up with water.
May 30, 2011 | Miele Touchtronic W1113 Washing Machine
Why does my washer spin out so loud, could you please help me.
Usually caused by unbalanced loads.....but depends how old...if an old one most likely cause is drum bearing failure or drive belt wearing
Dec 08, 2010 | Miele Novotronic Premier 500 Front Load...
Washing machine not spinning
Hi there are 3 possible causes.
1. Out of balance load (drum is divide into 3 sections if weight i one section is greater then 1.25kg than another section appliance will not spin)
2.Carbon brushes ( Normally good for at least 10 years)
3. Vent ( Y - Piece) from drain pump blocked.This requires front panel to be removed.
If the machine detects a fault then an indicator light will flash,(rinse light for motor circuit).
Apr 22, 2010 | Miele Novotronic Premier 500 Front Load...
The motor on my Miele washing machine is running constantly even when not set on a programme. The water seems to empty out as soon as it comes in. I Have to release the Stop /Start button to stop motor.
what motor do you mean the motor that spins the drum or the pump motor if its the pump motor i would check the programmer as it tells the pump when to run, on a rinse water evacuate cycle it would seem that you are stuck in that mode call a loacl engineer
Jan 16, 2010 | Miele Novotronic Premier 500 Front Load...
Hotpoint First Edition FEW10P Front Load Washer Logo
93 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
