Question about Ricoh Aficio 450 Copier
Can I or how do i install a network interface card? Right now I just use the copier for ony copies. I want to network the device to more than one printer, however I can't locate any CAT5 inputs. I figured I needed to install an interface card. There do appear to be phone line inputs.
  • 81 Answers
U need the print scan kit. when u get that it will have setup instructions in the kit.
Posted on Sep 29, 2010
Error 116-324 keeps coming up. i have turned machine on and off, what do I do?
1. Power off the printer using the power switch located on the right side of the printer, toward the back. Press the power switch to the off (O) position. 2. Remove all interface cables (network cable). 3. Power on the printer. Press the power switch to the on (') position. Keep interface cables disconnected. 4. Print a Configuration Page. 5. Clear all jobs from source print queue. (Network Server or USB)
The above means to delete ALL print jobs from your computers, if you have several people printing to the device they must delete all their jobs as well. 6. Reconnect interface cables after step 5 is performed.
If this deosn't resolve the issue you will have to call Xerox and request a service technician to go onsite to resolve the problem. In some cases if this doesn't fix the problem it means you have a bad network card.
I hope this helps
Mar 05, 2015 | Xerox 6505/n Workcenter 6505n Color Laser...
How do I turn off copy-card default on xerox copycenter c123
http://www.support.xerox.com/support/copycentre-c123-c128/support/enus.html
This is how to turn off Auditron but this is the same menu as "foreign interface device" or copy card.
Jan 17, 2014 | Xerox CopyCentre C123 Copier
Network controller
Your network interface card that connects you to the internet is not working because you need to install the software for this device. If it worked before, then maybe you network card is deffective.
Sep 26, 2013 | Dell Precision M4500 Notebook
Hp network interface not working
the card may be faulty or not installed correctly. go over the connection and make sure everything is installed correctly. if that doesn't work, try a new card.
Apr 06, 2013 | HP LaserJet P4015N Printer
Is the Canon lbp3360 laser printer wireless capable?
This model printer does not have wireless capability, BUT it has a network card that allows it to be connected to a LAN.
Network ready
Users can share the printer across a network with the built-in Network Interface Card. NetSpot Device Installer ensures quick and simple set up.
Jun 30, 2011 | Canon LASER SHOT LBP 3360 Printer
How to I determine what type network card I have?
The most common types of network card adapters are for the wired and wireless connections.
Here is the picture of the wired network interface card.
Here's an example of a pci wireless adapter. There are also usb types.
http://www.pcarenahungary.com/pricelist/oriaskep/pci-wireless-adapter-380.jpg
If you want to know the manufacturer and model, right click the My Computer icon, click Manage, and then click Devices. You should see the list of devices installed on your computer.
Mar 13, 2010 | Dell Dimension 2400 PC Desktop
Pls. help us,how can we used land cord to connect printer konica 7035 to computer. we already down load a driver from internet . we try many times to check sa IP address and test print but still we cannt...
Using arp command (UNIX)
From UNIX you can use the arp command to assign the IP address to the network interface card.
Perform the following procedure:
1. Turn off the print controller and the main body printer.
2. Log in as superuser on a host on the same subnet as the network interface card. However, if
the server resides on another subnet, complete this procedure to store the IP address in the
3. Find the MAC address of the network interface card. The address is printed on the Status Page
each time you turn on the print controller and the main body printer.
4. Edit the hosts file (usually /etc/hosts) or use NIS or DIS to add IP address and node name of
the network interface card. See the network administrator for the IP address. For example, a
network interface card with a name of printfast and an IP address of 192.9.200.200 has the
entry:
192.9.200.200 printfast
5. Add an entry to the arp cache for IP address and Mac address of the network interface card,
as:
arp -s 192.9.200.200 0:40:c8:0:0:ff
RS6000 (AIX) requires the ether option after arp -s. For example:
arp -s ether 192.9.200.200 0:40:c8:0:0:ff
6. Check the print controller and the main body printer to see that the network interface card is connected
to the network. Turn on the print controller and the main body printer.
7. Send a ping command to the network interface card to verify it is running on the network, as
for example:
ping 192.9.200.200 or ping printfast
The network interface card will not respond to this ping command but it will read its IP address
from the packets.
8. Turn off the print controller and the main body printer and back on again and then send the
ping command again to verify that the network interface card obtained its IP address. A confirmation
message displays as:
192.9.200.200 is alive
9. Remove the entry from the arp cache using the following command. Specify the network
interface card either by its IP address or by its name, for example:
arp -d printfast
Konica Network Interface Card INSTRUCTION MANUAL 2-5
Chapter 2 Setting Up the Network Interface Card
Using MAP
By using MAP (Management Access Program) included the CD-ROM that comes with the network
interface card, you can automatically identify the network interface card on the network and set it up
for TCP/IP by using Web Utilities. To use this method to assign the IP address to the network interface
card, the following procedure should be performed on computers in advance:
• TCP/IP correctly configured
• IPX/SPX-compatible protocol installed
• MAP installed and MAP setup correctly executed
About how to set up TCP/IP and how to install IPX/SPX-compatible protocol, refer to Windows Help
menus for example. For MAP, refer to “Using MAP (Management Access Program)” in this chapter.
To change an IP address already assigned to a network interface card, you can not use the
arp command. Use Web Utilities instead. These methods also allow you to set up subnet
mask and default gateway, etc.
Using NIManage
Refer to “Chapter 7 AppleTalk Configuration”.
 Accessing Web Utilities
The network interface card is provided with an HTTP server having Web Utilities. By accessing this server,
you can change settings of the printing system. There are two ways to access Web Utilities, through a Web
Browser, either through Netscape Navigator, version 4.x or greater or through Internet Explorer, version 4.x
or greater.
• Use MAP to have the network interface card on the networks identified automatically, thereby accessing
Web Utilities.
• Use a Web Browser to type the IP address assigned to the network interface card, and thereby access
the Web Utilities. For example:
http://192.168.0.128/
If you designate the proxy setting in your Web Browser you cannot access the Web Utilities.
For more information see your network adminisrator.
2-6 Konica Network Interface Card INSTRUCTION MANUAL
A utility called MAP is provided on the CD-ROM that comes with the network interface card.
This program automatically identifies the network interface cards on the networks and lists them on Web
Browser screen. From this Web Browser list you can select a network interface card to change its settings
and control Web Utilities.
Aug 31, 2009 | Konica Minolta Office Equipment & Supplies
Network interface card
You need to go into device manager (control panel, system, hardware, device manager). Under Network, highlight your network interface card, right click and select uninstall. Once it's uninstalled, reboot your computer and it will automatically install it again.
Jun 14, 2009 | Panasonic Computers & Internet
I was told by my isp that I need to uninstall and then reinstall my network interface card. How do I do this?
Go into device manager (control panel, system, hardware, device manager). Under network connections, right click your network interface card and select uninstall. Reboot the computer and it will automatically reinstall.
Jun 14, 2009 | E-Machines eMachines Desktop PC
Ricoh Aficio 450 Copier Logo
95 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
