Question about Coleman Powermate 27 Gallon Air Compressor
Where can I get a new air adjustment knob and parts
    Problem Solver:
  • 11 Answers
Off of ebay
Posted on Oct 07, 2010
Mum's Vulcan oil heater was serviced.Filter changed. Always hasn't burned all the way to the ends it's standard 1 control knob. Is there a oil/air mix adjustment. Can't find online manual anywhere.
Probably needs burner pot cleaned out, common thing to do.
Its a 40 series oil heater, only had single knob, air adjust is automatically set by internal controls.
where abouts are you.
I have some parts and manuals still
Jul 03, 2017 | Vulcan Heating & Cooling
I broke the Air flow adjusting knob and can not get air to release on my Musting 255 can you help.
replace them you can get them from guarantee vacuum and sewing center
Mar 17, 2014 | Vacuums
My Porter Cable pancake outlet regulator doesn't seem to work.
If your quick coupler is not jammed up, (remove & test) and assuming you are pulling the regulator knob out to adjust the pressure and it is not stripped, you will need a new manifold kit.
There are about 6 versions of this unit so you will need model and type to get the correct part. There are no individual regulator parts available for this unit.
Jul 02, 2013 | Porter Cable C2002 150 Psi 6 Gal...
This is a brand new compressor that I have kept in a box for about six years. It was never used. I open the box and took the compressor out of the box. The regulator fell out of the compressor. I have...
Look at the underneath side of the knob. Many of these have a square molded into the knob that fits over the square shaped adjusting stem coming out of the regulator. The replacement regulator (if you end up having to replace it) is part #885807 (reference number 30) and is $42.88 Here is the link to the parts breakdown.
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/hitachi/EC119SA
Jul 16, 2011 | Hitachi EC119SA Twin-Stack Air Compressor...
My regulator adjustment knob is not working and there is no air pressure on the psi regulator gauge. Air goes into the tank and the hose from the motor to the tank gets extremely hot. Is this normal for...
The air discharge hose will normally get very hot. When the pressure regulator valve fails, it may no longer give you air. As a temp measure you can get air out of the unit by removing the safety pop valve and installing a tee fitting in the port. On one side of t fitting reinstall safety. On the second port install a quick connect for full tank pressure. Make sure that there is not air in the tank by pulling on the ring of the safety before you take it off. Replacement parts are at www.toolpartsdirect.com or dewalt service center. Good luck
Jul 12, 2011 | Porter Cable C2002 150 Psi 6 Gal...
I have a 2005 Ford Focus. My vent distribution knob turns freely but does not change air direction. It remains blowing from the defrost vents. I pooped off the face around the knobs and stereo to look...
The part you're describing is the blend door actuator. It diverts air through the different ports, (floor, vent, defrost, mix). The good news is depending on what you need (new lever or new blend door) the price runs about $30-40. As far as ease of installation, it sounds like you have unobstructed access so replacing it shouldn't be too difficult.
Jul 07, 2011 | 2005 Ford Focus
Gauge and knob seem to be leaking on right gauge from behind adjust knob, bleeds of my air when ac is unplugged. Do I order a new gauge/knob adjust? Can I get it from you or how do I order. Is this a...
Best thing you can do is to take it back to the place of purchase, if it is under warranty you will void this if you play with the compressor. Remember to take a copy of your invoice.
Nov 23, 2009 | Porter Cable 18 - Gauge Brad Nailer and...
Part numbers
I need a new knob for my carrier through the wall air conditioner. I looked into the back of the broken knob and found part number.
0350
1029
stamped inside. I googled it and found the correct knob (saw the picture) at http://bestbuyheatingandairconditioning.com part number KNB3501029.
Not cheap but I found them.
Hope it helps :)
May 02, 2008 | Carrier XHD183D Air Conditioner
Series6500SR
Check the air filter which is at the air output (blower) part of the canister, under the part where the attachments are stored. Also, I know how to disassemble, but the air filter is the likely problem.
Dec 12, 2007 | Electrolux Epic 6500 Vacuum
Coleman Powermate 27 Gallon Air Compressor Logo
99 people viewed this question
Top Coleman Air Tools & Compressors Experts
John Trevino
elunsford
JOHN LAPIER
Are you a Coleman Air Tool and Compressor Expert? Answer questions, earn points and help others
