Question about Sony Grand WEGA KF60XBR800 60" Rear Projection Television
TV goes off, red light flashes for about 1 minute, then tv comes on again. Is it the lamp? Time to replace bulb?
  • 10,594 Answers
Yes, if lamp has not been replaced in last 2-3 years then replace it to fix tv issue.
Posted on Sep 28, 2010
No Picture, but sound for a minute, then shuts off
I think your Display card not proper work so please contact LG Technician.
Thanks.
Feb 17, 2014 | LG RU-44SZ61D 44" TV
Tip
Pix shuts off, green light starts flashing, pix comes back and shuts off again
If you have an issue where your picture turns off and the green power light starts flashing, you are most likely looking at a weak or old lamp. Do not be confused with a pix loss and a RED light flashing, as this can be caused by many things. The normal sequence of events for this fix is this:
1) TV turns on normally, plays for 1 to 3 minutes (may be more or less time)
2) Picture goes out and green power light begins flashing. It may flash for up to 2 minutes
3) green light turns on solid (stops flashing) and picture returns.
4) Picture goes out again and process repeats.
You may have been told that "if the lamp light isn't on, it isn't a bad lamp".
FALSE!
A weak lamp will cause the process above to occur. Other signs of a weak lamp:
The reflector in the lamp is very cloudy
You may see a "growth" or "bubble" on the vertical glass tube which is the lamp
You haven't replaced the lamp in quite some time or it is the original lamp from when you purchased the TV.
In cases like these, try a new lamp. Stick with an original Sony lamp, as there are many stories (both personally witnessed by me and also documented on the web) about problems with after market replacement lamps. And remember, lamps DO NOT have a shelf life; you can store them in a good environment (not too hot or cold!) for an indefinite period with no ill effects.
on Nov 03, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Had check fan no 2 on tv. I replaced. The bulb is about 6 months old as well. I power on both fans are working the bulb comes on but the tv shuts off after a few seconds before the picture even comes on....
U recheck the tv projection lamp connections,the door latch and the lamp door closed properly and tightly.Yes,if the tv projection lamp LED light indication "LAMP" word it is still flashing or staying on the tv projection lamp some how dying again.The tv projection lamp should be replacing it again.
Sep 02, 2011 | Samsung HL-S6188W 61" HDTV
I have a Panasonic PT-52LCX66 television that I bought just over 4 years ago. I have replaced the bulb for the second time just 3 months ago and now the set will just shut off after about 3 minutes of...
Tv making and have clicking sounds as tv shutdown as lights flashes?Yes.The board that call the Ballast board might be dying and dead soon.This Ballast board job responsible only are to ingnite the tv projection lamp only.
Jun 30, 2011 | Panasonic PT-52LCX66 Projection Television
When you turn of the TV the POWER indicator flashes green for several minutes. The TV never comes on. After the several minutes of the POWER indicator flashing green, it stops, I hear a click and the...
A continuous flashing red light with the word LAMP on it would definitely mean you're going to need to spend a few bucks on a new lamp....or for a few more, upgrade to a TV from this century that doesn't require lamp changes :)
May 11, 2011 | Panasonic PT-52LCX66 Projection Television
Changed lamp green light comes tv plays for about 1 or 2 minutes tv goes blank red flashes 3 times.
Not 100% sure but I am currently looking into this. 2 things it might be which are most probable. I replaced my lamp a few years back with no issues. This time around I figured I'd be proactive and bought a new lamp as my current one was going dim. Not unusable but I could tell. Lamp arrived and I put it in. Started up, great! Then after a few minutes it shut down and the red LED would blink 3 times. I removed the lamp and replaced it after unplugging the tv and turned it on. This time it ran about 20 minutes and same thing! Tried a third time and had the same thing. So I put the old bulb back in, and this time it didn't even turn on! I removed it and with a flashlight looked in there. There are two safety switches. The first is a very small pressure switch at the base of where the bulb interfaces to the TV. That switch ensures the bulb housing is seated. Secondly there is a switch in the rear side where the second door with the lever lock is. When you rotate it the switch is engaged. I replaced the housing carefully and made sure everything was tightly seated. The tv has been on for about an hour now no issues with the old bulb.
I have two theories and am leaning toward the second one I will suggest. One is that the bulb is somehow overheating as it is newer and brighter, or is somehow defective. The other theory is that as the bulb heats up the switch might be getting dislodged. I am leaning towards this given that it is working with the old bulb. But I am not certain. Soon I will try the new bulb again and may even attempt to slightly bend the switch out a little so that it is easier to engage.
Jan 05, 2011 | Sony KDF46E2000 46" Projection HDTV
Samsung HLP4674W - changed bulb - still no picture - lights flash
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at www.tvrepairworld.com just leave them a email they respond quickly.
Aug 28, 2009 | Samsung HLP4674W 46" Rear Projection HDTV
Sony Grand Wega 55" LCD ml # KDF-55WF655 goes protective shutdown
This is the lamp going bad. For some reason, it doesn't spit out that lamp error, it just keeps refiring the lamp and it just cycles forever. When the lamp totally fails, you will get the lamp led lit. Replace the lamp to resolve.
Dec 07, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
My Sony HD-TV KDF-50E2000 is about 18 months old. The picture went out. The green on light stays on for only a few minutes then goes off and the red lamp light flashes. You can turn the Tv on again and the...
How many times Red Lamp flashes, its important as it shows problem and its location in tv. Below is detail of lamp blinks and you may know the problem area in tv by counting lamp flashes.
Need further help, let me know.
Sep 13, 2008 | Televison & Video
I have a LG RU-44SZ61D DLP TV and recently replaced the bulb. After about two months the TV went really dim and then started shutting off. The problem increased to the point where you couldnt have the tv...
DLPs have flow chart trouble shooting techniques to pinpoint exactly why your set isnt completeing the boot sequence. If you would like the service manual for your model let me know and i will post a link where you can purchase a complete one.
Apr 06, 2008 | Televison & Video
Sony Grand WEGA KF60XBR800 60" Rear Projection Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
