Question about Dryers
I have a Frigidaire dryer mod# ferb6600eso electric dryer. When it runs, it sounds like metal on metal. Is there felt around the front and back of the drum and could this be worn out?
  • Dryers Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on Sep 29, 2010
How do I get the front panel off a ge mod djsr473et6ww cloths dryer.
GE Dryer Repair - How to Take Apart, Open, or Disassemble ...
? 6:21
https://www.youtube.com/watch?v=AgsOwIwoygc
Feb 22, 2013 - Uploaded by canyonman1963
Tags: GE, General Electric, Frigidaire, Electrolux, electric, dryer, open, remove, take apart ...
Dryer Repair - Replacing the Lower Front Drum Felt Seal ...
? 9:42
https://www.youtube.com/watch?v=XoYP_YsGP68
Jun 7, 2011 - Uploaded by PartSelect
Dryer Repair - Replacing the Lower Front Drum Felt Seal (GE Part .... on this dryer....how do you remove the ...
Nov 03, 2015 | GE Dryers
Frigidaire dryer has recently become noisy. scraping, grinding sound. dont know if its belt or motor. any info b4 i take it apart? no error lights on panel.
The problem with the dryer is not the belt or the motor. the problem is either going to be the drum bearing or the front upper and lower felt and glides.I'll list a walk-through for you if your interested .
1)The first thing you need to do is unplug the dryer.
2) You will need to pop the top of the dryer. This can be done with a flat screwdriver. Place the driver between the top and the front of the dryer and basically just pry upwards.
3)Now, that you can see inside the dryer, the next thing is to remove the front of the machine. At the upper left and right sides you will find a screw that holds the front to the frame of the dryer.Remove these screws and you can take the front off.
4) The glides and felt are located on the inside of the front piece you just removed.The drum actually rest on these and if damaged will produce a metal on metal dragging sound. If these parts are good, continue to step 5)You now have access to the belt and idler pulley, which is good because the belt needs to taken loose .
6) WIth the belt off spin the drum and listen for the sound that has been bothering you, if any sound other than a smooth sound is emitted when turning the drum your rear bearing is out.
7)You can remove the drum by lifting the back end up and pulling it out. Once you have it out the bearing will be exposed and the rest is just swapping out the old bearing and putting it back together.
Jun 16, 2012 | Frigidaire Electric Dryer
When the dryer is running it Squeeks loudly
May 27, 2012 | Frigidaire GLER642A Electric Dryer
Wed6200sw works fine except its making metal draging sound
you'll have to take it apart and check the rollers and pulley and also check around the front of the drum,there's a felt seal there that i've found the drum cuts through it or something could be stuck in the felt,pull out the lint filter and remove the two screws in front of it,then get a screw driver and stick it in between the top cover and the front panel around two inches from the corner and pop up the top cover,check the drum to see if it looks like something is rubbing against it.if so unplug the dryer,disconnect the wire connector on the right side,and remove the two 5/16 inch screws that hold the front panel on.watch video
http://www.youtube.com/user/RepairClinic?
v=zXg5iVKEel4&feature=pyv&ad=5621279621&kw=dryer%20felt%20seal
also while you have it apart vac it out.if nothing wrong with felt you can buy a kit with the belt,rollers and pulley to change them out,one of these should be your problem but metal on metal i would check the felt seal first.hope this helps and good luck.
Jan 26, 2012 | Whirlpool WED6200S Electric Dryer
We have had a consistent problem with our dryer. The lint filter eats any staps in the dryer. I have found straps from bras, tops, and belts twisted around the lint filter. They get caught on the edge...
sound like front felt glide assy # upper felt seal part #134440200 lower felt seal #134134700 u can order these from sears.com
these componets support the front of drum and when felt wears away then clothing slips in gap and when dreyer tumbles clothing gets snagged in gap and tears clothing and leaves black scuffs
Jan 31, 2011 | Frigidaire GLEQ2152ES Electric Dryer
I have an frigidaire electric dryer model number FERB6600ESO will not get hot. What could be the problem?
First check to see that your getting 220 Volts to the dryer.
Then locate your heating coil on the back of the dryer under the metal plates.
You should see a fan/blower housing that goes to the inside of the dryer drum that is where you will locate the heating coil, also some times the thermostats/thermistors are located either inside or outside of the same fan/blower housing. Check them to make sure they are not faulty.
Good Luck
Please rate me
Thanks
Aug 12, 2010 | Dryers
I have a GE profile Dryer DPSE810GOT and the dryer sounds like its running on metal to metal is the felt around the drum one piece or two and counld that cause it
The felt is two pieces. And, no, the problem is the drum support glides have worn through, allowing the drum to continue to wear into the front drum bearing. Replace the front drum bearing (WE3M26) and the drum slides (WE1M481) located at the top front of the drum.
Feb 28, 2010 | GE DPSE810EGWT Electric Dryer
The dryer squeals (metallic sound) while drying clothes.
check wear pads around front of drum or rear depending on brand. Ge's are particularly prone to scraping sounds, but still one of my preferred brands. IF a ge, did it get any dents around the sides or back? The drum is close to the sides and a dent in right place will do it. Also the rear panel can push the drum forward rubbing in front.
Ge - wear strips in front, plastic bearing in rear center, replace both, inexpensive.
Whirlpool- felt pad and wear strip in front, felt seal in rear with roller support. check rear seal lube rollers
Maytag -roller in front and rear with front and rear felt seals. some designs have front drum support posts with wear pads. ck these.
Frigidaire (include some sold under GE name) rear bearing cup (plastic)-lube, front feltpad with wear plates if plates gone get new pad/wearplate asm.
Maytag and ge nomenclature tags are in rear .
Jul 19, 2009 | Dryers
Loud squeaking noise coming from back center when drum tumbles
I am having the SAME issue. I try to put up with it, but the sound is horrific!!
FDE216RES2
Feb 19, 2009 | Frigidaire Electric Dryer
Frigidaire electric dryer; model # FDEB34RGS1
front drum seal needs replacing pop clips at front of dryer top ..lift top remove 1 secrew each side of front from the inside..remove wires lift panel off clips ckd front panel around door area for felt seal may also have embedded plastic drum glides a felt seal also goes around bottom half
May 05, 2008 | Frigidaire FGR341AC Electric Dryer
Dryers Logo
133 people viewed this question
Top Dryers Experts
