Question about Kenmore Microwave Ovens
I have power going to microwave from electrical receptical, but the microwave has no power, will not show nothing tme, etc
  • Kenmore Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Sep 28, 2010
How long in microwave
That depends, among other things, on the make and model of the microwave and on what you're trying to cook. Would you care to provide some details?
Dec 20, 2012 | Microwave Ovens
The power just went off. tried unplug for 20 secs and plug again. tried the braker and plug. still nothing
Plug a lamp into the wall receptical, if it works! the main fuse in the microwave has blown. Unplug, and remove the top "several screws" check under the keypad and follow wires to the circuit board, look for a silver rectangular capacitor, take a screw driver and short the two points to remove any residual voltage. Now look for a small fuse "clipped" pop with screwdriver and replace with the same current rating, assemble unit because lethal voltages are present when powered on.
Mar 04, 2012 | Panasonic NN-T990SA Microwave Oven
The fuse to the Power cord on our amana hdc21 blows when you start cooking a product why?
How many other electrical items do you have working on this same fuse? Lamps, radios, tv's, fans, air conditioners, refrigerators, etc. can all put stress on the circuit causing the fuse to blow. Check the fuse to see what else it controls. You may have to move your microwave to another outlet...2100 watts is very powerful and draws a great deal of electricity. Or you may just have to turn off a lamp, tv, radio, etc when using your microwave.
Nov 04, 2010 | Amana HDC21 Microwave Oven
Electricity is on because the colon is showing. But we can't set anything, clock, power, etc. . Cannot program anything. Beeper is beeping for two short beeps around every half hour--.
Hello. Try this. Push the clock button. Then enter the time in hours and minutes, THEN push the clock button a second time. Joe
Please give my answer 4 thumbs up since it is on target and also free to you. Thanks. Joe
Oct 05, 2010 | Danby DMW753 Microwave Oven
Ge microwave digial dispaly works but nothing heats-
in 99% of casses its a burned out magnatron they can be expensive to replace but it depends on how much the microwave is worth
Jun 19, 2010 | General Electric Microwave Oven
Power on lights etc push start button but it clicks and nothing happens
Hello :
This could happen because of bad door switch or a loose door mount .This is the main reason that microwaves not heat even if the other functions work fine .
Warning : A microwave is capable to give you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
good luck .
please rate !
Apr 04, 2010 | Panasonic NN-C994S Convection/Microwave...
Model jvm131h002 Stopped working. no power or
yes, at the back of the microwave there are 4 or 6 screws, take them out and then pull the cover follow the cable( the one you connect to the outlet) going to the inside of the microwave inside you will see the fuse change it with the same size, it is a slow burn fuse
Aug 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Magic Chef Microwave Shutting Down Problem in RV
your micrwave may run fine at 110 but it draws more power than the generator is putting out when the magnetron kicks on which is the part that creates the microwave causing the food to heat up. In other words the amperage is too low for the microwave. Amperage is what matters not voltage.
Apr 12, 2009 | Hotpoint RVM1435 Microwave Oven
Has power to unit but nothing works, ie. oven, clock, timers, etc
If you don't see any light in the display or from the light bulb inside it you probably need to replace the fuse inside the microwave, it should be by the place where the cord goes in the microwave.
Apr 08, 2009 | General Electric Microwave Oven
Microwave gets no heat
This could be due to a bad door switch, or a defective part in the high voltage section. You can find my helpful and detailed text file "doorsw.txt" by going to Yahoo.com (not Google) and searching for microwave doorsw.txt Some questions: When you enter the cooking tme and press START, does the inside light come on? The fan? Is it making any unusual noise?
Nov 19, 2006 | Emerson MW8168B Microwave Oven
Microwave Ovens Logo
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
