Question about HP Pavilion dv6000z Notebook
The laptop starts then black screen then restarts 25s later and it dosent stop.the hard drive maks a sound to.
    Scholar:
  • 55 Answers
The problem might be with the static charges on the motherboard, LCD screen, RAM or with the Hard Disk. Try the followings.
Remove Static Charges:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and do NOT connect the battery now.
5. Turn on the Notebook power.
Still same, remove and reseat the RAM and Hard Disk. Check the below link for service manual.
http://h10032.www1.hp.com/ctg/Manual/c01602064.pdf
Refer to page 128 of 278 (Memory Module)
NOTE: If you have more than one memory module, you should test them individually to determine if one or both of them are faulty. Insert each module separately, then turn on the notebook to determine if the inserted module is working. Once you have determined which memory module is faulty, you can replace the faulty module and reseat the working module.
Refer to Page 123 of 278 (Hard Disk)
If still the same, you need to contact HP for hardware repair.
Posted on Sep 29, 2010
Does not boot (hard drive problem?)
When a hard disk makes a clicking sound and the computer does not detect it then the hard disk is faulty. This is commonly known as "The click of death".
There is no way of fixing this hard drive, if you need to recover your data, then there are companies that can recover data off faulty hard drives BUT it will cost you an arm and a leg for their services.The hard drive needs replacing and Windows installed on the new hard drive to get your laptop working again.
Feb 23, 2013 | Toshiba Satellite L655-s5075 Laptop Screen...
EMachines eMD620 suddenly shutdown and not boot anymore
When this happened was the laptop overly hot? If the laptop's head got too high it could have shutdown to protect itself. It wouldn't boot until the heat had disparate. Sit you laptop aside for about 30 minutes and see if it will boot then. If it does you might want to check out a cool mat.
http://www.amazon.com/gp/product/B008TO35G0/ref=sr_1_3?ie=UTF8&qid=1358444754&s=pc&sr=1-3
Jan 17, 2013 | eMachines eMD620-5133 Notebook
Toshiba c655d - s5200 wont start up. i get a black screen that says no bootable disk
sounds like you have a bad hard drive,,try putting a bootable cd and start it like that,or at the start up hit the f2 key and go into the setup and seee if there is a hard drive loaded
Jun 12, 2012 | Toshiba Satellite C655D-S5120 Notebook
When I turn the power on it starts up but just shuts down ten seconds later and keeps starting up and shutting down over and over again
This may be a hard drive issue, remove the hard drive and power up the computer it should show the HP logo and go to black screen with a blinking cursor, turn off and re-seat the hardware back in place and restart the laptop, any change? if the same, reload the recovery disc if available this will prove if it's a software issue or hard disc problem. If there is no improvement the hard drive should be pulled and tested at a computer shop before buying a replacement.
Feb 13, 2011 | HP Computers & Internet
Laptop gives no response after reboot/restart
how old is the laptop
if it has a disc hard drive it could be that the motor in the hard drive is failing
go into device manager and do a systems check
Apr 03, 2017 | Toshiba Computers & Internet
Black blank screen Lenovo 3000 N100
You say the laptop all of a sudden flashed off.
How old is the laptop? You may have suffered one of two things? First of all, if the hard drive will not boot back up, even after using the recovery discs, then that would explain it powering off. I have seen this happen on old desktop hard drives.
Next, try to get the transformer or adapter tested. It may not be putting out enough amperage to run the laptop.
Sep 01, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
When i turn it on it's saying there's no such file directory. It's a dual core processor I tried to switch it from Os9 to Os10 and now it's got a black screen with this on it
Try starting from CD and check hard drive. Sounds like you installed something that may have corrupted something on your hard drive.
Jul 08, 2009 | Apple iMac G4 Desktop
The device Generic Volume cannot be stopped right now. try stopping the device again later. on Window XP
If you tried to stop your external hard drive with it open in Windows Explorer, You will get this message. You cannot disconnect the drive in this condition. Even if you close Windows Explorer after, Windows still thinks it is open. The best thing to do, is restart Windows and when the screen goes black, shut the power off to the external drive or disconnect the USB cable. Disconnecting in any other way causes Windows to have problems with USB devices in the future.
Jun 08, 2009 | Western Digital 500GB My Book World...
Toshiba Satellite a215-s7437 will not boot at all - black screen
It sounds like two possible things. One thing may be that your screen is not working anymore. Can you get a monitor and plug it into your port located on the side of your laptop? If your screen pops up on the monitor this tells us your screen is either in need of replacement or a connection may be loose.
If that is not the case......
Another thing is your hard drive may not be initiating. If you feel confident enough I would open the back where the hard drive is located and make sure the hard drive is not loose. Does it give you any beeping sounds when you turn it on? Can you count the number of beeps? This will tell you what the problem is on boot up. Also, is it a black screen with a cursor blinking?
Mar 14, 2009 | Toshiba Satellite A215-S4747 Notebook
TOSHIBA A135-S2386- I HAVE AN ERROR WHEN TURNING ON MY LAPTOP
You most likely have a faulty hard drive, especially if it is making a clicking sound.
You wil need to purchase a new hard drive and install Windows again with the Toshiba Recovery CD.
Jan 21, 2009 | Toshiba Satellite A135-S2386 Notebook
HP Pavilion dv6000z Notebook Logo
64 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
