Question about Philips Audio Players & Recorders
Free i have a philips pwr2006-37 subwoofer that i want to hook up to my computer so i need pin out diagram for 15 pin vga input please
chinna_1977
  • 65 Answers
SOURCE: LG 17'' LCD Monitor VGA 15 pin connector pin diagram
pin no 1 - Red colour signal (Red colour wire)
pin no 2 - Green colour signal (Green colour wire)
pin no 3 - Blue colour signal (Blue colour wire)
4&5 Not connected
pin no 6&7&8 are (Grounds)RGB Returns
9&10 NC
pin 13 Hohizontal sync signal
pin no 14 vertical sync signal
Not nessasry other pins
Posted on Nov 17, 2008
SOURCE: VGA Pin Configuration
Pls find below the Pin configuration.
Pin 1 - Red Signal
Pin 2 - Green Signal
Pin 3 - Blue Signal
Pin 6 - Red Ground
Pin 7 - Green Ground
Pin 8 - Blue Ground
Pin 10- Horizontal Ground
Pin 11- Vertical Ground
Pin 13- Horizontal Signal
Pin 14- Vertical Signal
Best Wishes
Posted on Dec 24, 2008
SOURCE: need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Posted on Mar 24, 2009
  • 1039 Answers
SOURCE: Need input connector (13 pin din?) pinout.
Call Bose. Do google search. They sell accessories on line. They are vry helpful.
Posted on Apr 25, 2009
  • 8 Answers
SOURCE: Pinout for 15 pin audio connector on Philips
1=control (I assume this is some kind of digital signal to turn the amp on and off...?)
2=nc (no connection)
3=nc
4=centre
5=centre ground
6=digital ground (possibly not needed if you're not hooking into the sub...?)
7=subwoofer
8=sub ground
9=nc
10=left ground
11=left front
12=right front
13=right ground
14=right rear
15=left rear
A full service manual for the HTS3345 is available at http://www.scribd.com/doc/37538958/Philips-HTS3455
Posted on Nov 05, 2010
I would like to connect my Philips subwoofer to my Pioneer multi channel receiver, but the subwoofer's input has only a 15 pin serial port connection. I need an inexpensive and easy solution?
Unfortunately, most subwoofers , like the one you're describing, need a separate amplifier. I don't know the model number of what you're working with but most Phlips subwoofers with that connection need an amp. Now, if you have the rest of the system that was originally with the sub then you can scavenge it's amp. But that's tricky if you don't know what you're looking at. Craigslist has tons of "powered" subwoofers that don't require a separate amp and u can therefore use your Sub Preout from the HT receiver.
Feb 13, 2016 | Pioneer Audio Players & Recorders
CRT VGA cable pin color problem. I can not get which pin connect where
Refer its connection diagram. The user manual might help you. If not, contact any service technician.
Nov 25, 2014 | Philips Televison & Video
Need help with a VGA cord
I dont know, but I do know it is a proprietary cord, it is meant to work only with that model of unit
Jul 28, 2013 | Audio Players & Recorders
Monitor keeps saying no video input was fine last night and happened this morning
hello, please check your VGA cable,blue in colour with 15 pins.Make sure it was properly inserted. I believe that should solve the problem
Nov 18, 2010 | Philips 200W6 Monitor
I need pinout assignments for a Philips 5.1 Home Theater Speaker system (PWR2006-37)? It has a DB-15 style input connector that hooks to the output of a Philips dvd / amp / control unit. this was...
Pin assignment is as follows (not sure of levels required- preamplification / attenuation may be necessary:
1: Control 0/5V.
2: Unused
3: Unused
4. Center speaker in
5. Ground
6. Ground
7. Subwoofer in
8. Ground
9. Unused
10. Ground
11. Left Front speaker in
12. Right Front speaker in
13. Ground
14. Right surround (rear) in
15. Left surround (rear) in
Jul 10, 2010 | Philips DVP642 DVD Player
3=nc
4=centre
5=centre ground
7=subwoofer
8=sub ground
9=nc
10=left ground
11=left front
12=right front
13=right ground
14=right rear
15=left rear
Apr 14, 2010 | Philips HTS3450 System
How to make a 15 pin female sound in cable
Ya, here is a diagram I made of my Acoustimass 10 IV input cable. All you need is a female 15-pin d-type connector and a bunch of speaker cable (also one RCA connector for sub connection). Here's my diagram:
Mar 10, 2009 | Bose Acoustimass 10 III System
Info on the SW9800 Subwoofer
I would like to buy your subwoofer for my broken system. Please contact me ASAP
adam.roseneck@gmail.com
Dec 23, 2008 | Philips Cineos HTS9800W System
Find dvi cable: links dvd to subwoofer
u need a 15 pin vga cable male/male just got one today
Apr 29, 2008 | Philips HTS3440/37 System
867 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
