Question about Acer Computers & Internet
I have an Acer Aspire 7736z which wont charge. Ive already found that the battery connector/battery pin/battery port whichever youd like to call it has snapped off. Any information on how to fix it? where i could get the part? or how to fix it as i know how to solder... any help plzz!
  • 2,567 Answers
DC Jack diagnosis:
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Posted on Sep 29, 2010
  • d_oski34 Jul 29, 2011
    my acer aspire 7736z wont charge up the light come on when its plugged in but wont charge up. its been sittin for maybe a month and a half I rarely use it. Any suggestions!
  • Mohamed Omran Jul 29, 2011
    Please refer to the following article for a detailed diagnosis procedure:http://www.fixya.com/support/r6395191-tr...
My acer aspire notebook 7736Z-4412 won't turn on. I have tried taking out the battery and using the adapter but it still won't turn on?
yes boss pl remove ur battery n start only ac supply if ur laptop on or not if run ur battery defective or not run at ac ur laptop ac supply ac to dc converter circuit problem pl send my address solved n send u
May 26, 2014 | Acer Aspire One PC Notebook
The charging port of my acer 5251 is broken, so I cannot charge my battery. Is there any way to charge the battery externally? Thanks
Charger connector breakage is a common problem in this type of device. The practical answer is to repair or replace the connector so that you can recharge the battery in the normal way.
Nov 28, 2013 | Acer Aspire 5241 5251 5332 5334 5338 5516...
I have an Acer 7736Z the battery isn't charging. The BIOS on the acer support website give me version 2.10 which doesn't seem to match the directions given from previous questions and solution
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
http://www.chargerbuy.com/replacement-acer-aspire-7736-ac-adapter-19v-90watt.html
Nov 16, 2012 | Computers & Internet
Acer Aspire 7736Z-4088 wont power on
Hi tloechli,
Follow this steps:
1. Disconnect from Power Adapter and remove battery 2. Press Power button for 5 seconds 3. Put the battery back and start the laptop
Note: If this doesn't work check memory and/or mainboard, or bring it to a certified troubleshooter or Computer Technician.
Hope it helps.
Thank you for using fixya.
Oct 05, 2011 | Acer Computers & Internet
I cannot get my laptop to start. I have bought a new power cord, and it will not charge or start. I have an acer aspire 7736z. What could the problem be?
Try removing the battery, it may be defective. Remove the battery and see if the unit powers up when plugged in.
Check to see if the charge light at least comes on when it's plugged in....if it doesn't, then the socket the power supply plugs into may need to be re-soldered.
May 27, 2011 | SIB 320GB 2.5 Inchs SATA HDD Hard Disk...
Manuels for Acer Aspire 7736Z-4448 Model No.
Hi
follow this link and hopefully you will find what you are looking for type in what you looking for
http://support.acer.com/
Nov 15, 2010 | Acer Computers & Internet
I have an Acer Aspire 7736z which will neither turn on or charge. When I plug the power adapter into the laptop the LED light on the power brick turns off.
remove the battery and plug the adapter to power on ....without battery
try that
otherwise change the adapter and check
Oct 24, 2010 | Acer Computers & Internet
Wont turn on
problem with your charger or pin connector
May 30, 2010 | Acer Aspire 3680-2682 Notebook
My acer d250 laptop wont turn on unless it is plugged in
Clean the baterry connector port with an alcohol solution or Spirit solution.and try.
If you can get hand to another battery,check out if everything is fine.Otherwise replace the battery.
Check if you have warranty of the battery.
Dec 27, 2009 | Acer Aspire One PC Notebook
Acer aspire 3680 power port
no, because the power connector is part of the motherboard and even if it can be soldered again not many manage to get the charger to charge up the battery again.
Sep 09, 2008 | Acer Aspire 3680 Laptop
Computers & Internet Logo
689 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
