Question about CyberPower 525SL (CPS525SL) UPS System
CyberPower 525SL Failure
During a thunderstorm my backup started beeping and blinking and my monitor and printer kept going off and on. I was able to shut everything down and it is all working properly, however, my backup continues to act up. I unplugged it and plugged it back on and when I power it up the power on light blinks on and off and it beeps. Is it useless at this point? Do I need a new one or is there some way to fix this. I tried the little button on the side which I thought might be a reset button but it does nothing. Please advise.
  • 1 more comment
  • Littleraine Jun 12, 2008
    My system went down during a bad thunderstorm. Now all it dose is beep and the green light comes on and off.
    What went wrong
  • Anonymous Nov 16, 2008
    but the replacement cells are hard to find.
    is this system too old?
  • sylg Jan 17, 2009
    I bought the cyberpower 525sl in August 2003. I only paid $54.00 for it and it has been great but a few times lately it has had a long beep and it clicks off. I usually can retry and it 'takes' but after reading similar problem here. I see that I am not alone. The suggestion of buying a new gel battery sounds like a saver. I am in the Orlando area and wonder if anyone knows a dealer who would carry a gel battery for this.
    Regards, Syl
  • 778 Answers
The erratic behavior and beeping could indicate that the Gel battery inside your UPS needs to be replaced, and is usually less expensive to replace than the entire UPS. You can remove the battery and contact a local or online source for a replacement. I replace mine through a local automotive battery supplier, and it' never cost me more than $20.00.
Posted on May 24, 2008
Why is my Cyberpower 550 VA surge protector beeping in set s of 3 beeps every few seconds after a power failure in the house?
This is a battery backup power supply as well. The beeps alert you that you need to power down your equipment before the battery fails.
The website is here with Support and Manuals
Dec 24, 2015 | CyberPower Computers & Internet
Cyberpower 1500 unstable output
You need an On-Line UPS, the one you have is a simpler version ...
Jul 08, 2014 | CyberPower 525SL (CPS525SL) UPS System
One side of my Cyberpower 525SL stopped working. When i press the red button the green light comes on, but goes off quickly accompanied by a beeping. The TV, dish, and vcr/dvd continues to work. Help...
Hi droger68,
The reason for the issue that you have right now with your Cyberpower 525SL is a bad battery. This means that some of the battery relay's component or relay has failed. You may contact the manufacturer if it's still under warranty. If not you may check this site they do have battery for your machine.
Hope this helps.
Thank you for using FixYa.
May 24, 2011 | CyberPower 525SL (CPS525SL) UPS System
It turns on then it starts going on and off it is only the three with battery and surge that won't work
may overload the ups. try to run it without any unit conected to it.
also possible is that inside batteries wont charge proper - replacement will help.
Feb 07, 2011 | CyberPower 525SL (CPS525SL) UPS System
I've had the CyberPower for a while now and the product burned out on me. Was there a recall on it? The model number is CPS525SL.
i dont get much more than 2 years out of a UPS, if they are plugged in 24/7 the batteries wont last very long, i usually get no more than a few minutes backup if my electric blows
Nov 08, 2010 | CyberPower 525SL (CPS525SL) UPS System
Unit does not back-up (stay on-line at all) when power goes out.
If the battery is over 3 years old then it most likely needs to be replaced. Since it works fine except for when it is relying on power from the battery, then a new battery should make it just like new. should have the battery you need. Hope that helps.
Apr 16, 2009 | CyberPower 525SL (CPS525SL) UPS System
Cbyer power 525Sl keeps turning off and on and beeps.
I have the exact same issue with my 525SL.
When you push in the red button - the green power light comes on for about 5 seconds = then the light goes out and the device plays a single long beep for about 5-8 seconds.
Given the dialogue here - I took out the battery and bough a brand new BB replacement battery and returned it into the unit as it should. The device continues to have the same behavior.
So it is NOT always a new battery that will fix the system.
Don't jump into spending $30.00 for a replacement.
Look into this further or you'll wind up wasting your money.
Oct 26, 2008 | CyberPower 525SL (CPS525SL) UPS System
(Cyberpower 525SL) not working properly
There is no other known cause of the cycling on/off behavior aside from
a bad battery. IT is possible that some component of the battery relay
or inverter has failed. If this is the case it would not be repairable
outside of warranty.
Joel Gerlach
Cyber Power Systems (USA), Inc.
877-297-6937 x7917
Jul 03, 2008 | CyberPower 525SL (CPS525SL) UPS System
Turned off my system
Well, it did just what it's supposed to do, protect your system from bad power. You probably had a power failure during the thunderstorm and your UPS shut down your PC. When you turn it back on the battery was too low and it shut off you PC again.Check your UPS software in windows, you should have an option to run a self test. But it should be just fine.
Jan 11, 2008 | CyberPower 325SL (CPS325SL) UPS System
CyberPower 525SL (CPS525SL) UPS System Logo
746 people viewed this question
Top CyberPower Computers & Internet Experts
George Nalley
Level 1 Expert
Paul Bade
Are you a CyberPower Computer and Internet Expert? Answer questions, earn points and help others
