Question about GPS
I turn on my garmin GPS and it stays on for 2 seconds and shuts off. I have taken the face plate off and hit the reset button and it continues to shut off.
    President:
  • 1,111 Answers
That usaully happens when the battery is low...try charging it up for a few hours via the usb connector..or the car or home charger, what ever you have handy
its possible its not taking a charge though...hook it up to either the home or car charger to check the charging, it wont show if the usb is connected.
Bill
Standing Member of G.O.T.
Posted on Sep 29, 2010
Garmin is unresponsive. Won't power up or turn
I have a Garmin c340 that would not turn on.
I found the hidden reset button and it works now.
With the display unit facing you, the aluminum cover plate has the the word GARMIN on it. Use you fingernail under the word Garmin and the cover plate comes off. The left part of the cover stays attached to GPS and the right side lifts up exposing the RESET button. I pressed RESET and POWER together and it works now.
Mar 10, 2010 | Garmin StreetPilot c340 GPS Receiver
Why does my c340 keep losing satellite reception
Hello there:
please follow these instruction and this should help if not let me know and i willcontinue to get you more information for you
nstructions
  1. Step 1 Calibrate the screen of the Garmin StreetPilot C340. If the touch screen does not seem to respond when you hit it with your finger or a stylus, you may need to calibrate it. To do this, turn the unit off and then hold down the "Power" key for approximately one minute. You will see a calibration screen come up that will recalibrate the GPS2_bing.gif unit.
  2. Step 2 Reset the Garmin StreetPilot C340. If your GPS unit is not responding or is stuck on a particular screen, it may need to be reset in order to operate. To reset, remove the face plate of the unit by gently prying it off. Locate the "Reset" button under the face plate and press down in order to restart the device.
  3. Step 3 Change the fuse of the Garmin StreetPilot C340. If the fuse blows on the GPS, you will need to make a replacement using an ACG/3AG 2 amp fuse. Unscrew the adapter cord at the end and remove the fuse found there. Put in the new fuse to see if this returns function to the unit.
  4. Step 4 Update the software for your Garmin StreetPilot C340. If the GPS is not providing you with correct directional information, you may need to update the software or download new maps onto the device. Connect the Garmin StreetPilot C340 with the USB cord to your PC and log on the Garmin website for available updates.
Jan 15, 2010 | Garmin StreetPilot c340 GPS Receiver
My Garmin StreetPilot c340 is frozen.
No.......the C340 STREET PILOT has a hidden reset button. Put your fingernail in the slot just under the GARMIN name on the front face plate. Gently pull the face plate outward. Don't take it all the way off. The reset button is on the right side of the front screen just under this plate. Use a pointed object and hold the button IN for 3 seconds and unit will turn off. When you power it back up it will REBOOT.
Jun 03, 2009 | Garmin StreetPilot c340 GPS Receiver
Street Pilot c340 froze up
I had the same problem, the face plates comes off by sticking your finger nail under the little notch under the garmin symbol and pich off the thin face plate, there is a reset button under the face plate in the middle of the right hand side of the edge of the face plate( visible when the face plate is dislodged. I held the button in for a second or two, you can feel the button recess as you push down on it) and the unit resets without disturbing the existing programed route
May 17, 2009 | Garmin StreetPilot c340 GPS Receiver
I would ike to reset to correct he freezing issue but I don't want to loose all my personal POI's
Under Garmin logo, pull face plate off, press reset button few seconds.
Update at Garmin, use the web updater
Data is safe no worries there.
Regards.
Apr 13, 2009 | Garmin StreetPilot C330 GPS Receiver
Display image has shifted, difficult to use
ok, first you will have to unplug the power and usb cables to remove external power. Secondly, place your thumbnail in the groove located under the Garmin logo on the face plate and gently pull off the face plate. Next, press the reset button for three seconds. Finally, connect the c330 to a power source using the power cable. the c330 should automatically turn back on and operate normally.
Please rate my response and have a wonderful nite.
Mar 10, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin c330 gps will not turn on
try this just worked for mine
1.Under the face plate by the Garmin Logo.Use your thumbnail to remove the plate.
2.Press the reset button.
Information located on page 28 of the owners manual if you need a diagram.
Nov 14, 2008 | Garmin StreetPilot C330 GPS Receiver
Frozen screen
Resetting Your c330
If your unit locks up, press the Power button to turn off the unit, then press again to turn the unit back on. If this does not help, reset your C330.
1. Place your thumb nail in the groove located under the Garmin logo on the face plate.
2. Gently pull off the face plate.
3. Press the Reset button.
4. Turn the unit back on; it will operate normally
Apr 04, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin c330 GPS
Hello, I have had 7 Garmin units and 4 of them where streetpilots like yours.
You can try a reset of the unit. This will restore the unit and you might loose any favorites etc that you have stored. Here's how you do a reset.
"With the unit off, place your thumbnail in the groove located under the Garmin logo on the face plate, gently pull off the face place. Press the reset button and turn the unit back on."
Try this and see how the unit works. If it still gives you the same problem then your unit needs repair. I have sent in at least 2 units to Garmin for repair in the last 2 years.
Thanks
Feb 19, 2008 | Garmin StreetPilot C330 GPS Receiver
Dropped the system everything working but will allow me to go to the map screen
Did you try to reset the unit? Place you thumbnail in the groove located under the Garmin logo on the face plate. Gently pull off the face plate. Press the reset button. Turn the unit back on and see if it works - Of course replace the face plate carefully. Good luck! Dr. Know
Dec 20, 2007 | Garmin StreetPilot C330 GPS Receiver
GPS Logo
123 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
