Question about Dishwashers
Kenmore Model 665.17669400
This is a portable dishwasher, about 3 years old, but has not been used on a regular basis. It will fill with water, but won't cycle.
I think you found a solution -- by posting it on craigslist-- why dont you mention this porblem in your ad??
Posted on Jun 30, 2008
I have a Kenmore dishwasher, not sure of the model or year (less than 10 years old) but water constantly flows into the dishwasher. So much so that it leaked all over the floor because the bottom filled up...
Hello.
If it's filling all the time when dishwasher is not even running? The water inlet valve that the house water supply connects to at the dishwasher,is sticking open and needs to be replaced..what you can do now to stop it from constantlu filling is turn off water supply to the d/w from under the kitchen sink.
Typically the model number is on a label on the egde of the door inside or on the rim of the tub..it would be needed to order a water valve
Gene
Aug 24, 2011 | Dishwashers
My Kenmore Portable Dishwasher model number 665.17769K600 will not fill with water, I have to manually fill with water and it will then work. What could be causing this?
Hi
When the Dishwasher is not filling in, you'll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly.
Hope this helps... Please post back for any further assistance.
Daniel
Mar 24, 2011 | Kenmore Dishwashers
I just bought a good used 4 year old dishwasher
check to see if the fill hose or inlet hose is kinked , or u need a new water valve or flow meter
Oct 27, 2009 | Kenmore Dishwashers
Kenmore 665.16039403 leaks water when filling
It is coming from the fill tube. You can pull the unit out or use a mirror to look up underneath. It might have come off or got a hole chewed in it.
Eric
Sep 25, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore portable dishwasher won't drain model # 665 17799990
Service person said is is not supposed to drain all the way. Something about it helps something not dry out.
Jun 24, 2009 | Kenmore Dishwashers
Fills with water when not in use
this is meant to happen
May 17, 2009 | Dishwashers
While not in operation dishwasher slowly fills up.
water valve is clogged try to turn your valve to dishwasher under sink
Nov 29, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore ULTRA WASH Portable Dishwasher Model 665.1784 leaks
i have had my dishwasher for 10 years never a single problem , i connected it turned it on , it filled with water then it just shut down down won;t do a thing. any ideas?
Sep 27, 2008 | Dishwashers
Dishwashers Logo
240 people viewed this question
Top Dishwashers Experts
