Question about Kenmore Kitchen Ranges
EO-F-2- keeps coming up on my range. What could this mean?
  • Kenmore Master
  • 1,711 Answers
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Posted on Oct 02, 2010
Stove is beeping and displaying EO F2. Do reset but it keeps coming back. Also one element on the range top has burned out. Is it something a DIY can do.
Hi dear.According to your explanation,E0-F2 code meaning is: F2 - E0
I hope that helps to solve your issue.Thanks.
Sep 02, 2010 | Kitchen Ranges
Error code EO -F2- Any one know what this means
Ledgestone Technologies has replacement keypads for NO LONGER AVAILABLE Whirlpool and Kitchenaid models. Each one comes with a new ribbon cable and 2 year warranty.
Contact FixYourBoard.com for more information!
512-355-1108 info@fixyourboard.com
May 29, 2010 | Whirlpool RBS275PD Electric Single Oven
Oven keeps coming up EO -F5-, and cannot work oven.
Here is what the fault code means:
F5 E0 14 Door switches do not agree Check door switch. Contacts should be closed when plunger is actuated. Check door switch circuit for open.
Feb 28, 2010 | Whirlpool Accubake RF362LXTT Electric...
After a power down the range keeps coming up EO F2? I have reset using the OFF/clear button. Oven lights but trips off to EO F2
Hi. This code is an indication of a Shorted keypad (also called touch pad)
Follow the steps below to address this issue further.
1. Check keypad connector for firm connection (keypad connects to control board, via ribbon cable). Make sure the connection is sound, and not severed.
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models may incorporate the keypad in to the control board as one unit. In this case, replace the entire control board (also called ERC or clock).
Dec 04, 2009 | Kenmore Kitchen Ranges
EO F2 on our Kenmore oven keeps coming up.
The "F2 - E0" error code means "Shorted keypad".
Remove power from the range, open the control panel and unplug the membrane switch ribbon from the control board.Reconnect power to the range and observe for an hour.If the error code reappear - replace the control board.If not - replace the membrane switch.
May 15, 2009 | Kenmore Ovens
Error EO F2
EO-F2
Is a poorly connected keypad ribbon.
Remove the front panel and unplu, then re-insert the keypad ribbon in the control.
Mar 26, 2009 | KitchenAid KEBC107 Electric Single Oven
Problem EO F-2
F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor
Dec 04, 2008 | Kenmore 96422 / 96424 / 96429 Electric...
Errror code
HI. thanks for the question. the fault code EO F2. means the touch pad key board is the problem. to repair new parts listed . thanks the appliance doc
Sep 16, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Clean cycle in oven doesn't work: FO EO
Oliversmom, Im not coming up with any information on the model number posted. However on the kitchenaid the F0 E0 is default for no error. Press the cancel button to put the range in idle state. Then in this order press cancel-cancel-start. See if an error code comes up different from the F0 E0. The F0 is what is throwing this whole deal off. If it was F1, F2, F3 etc...it would make more sense. See if you have a complete model number you can post along with the error code after doing the above key dance. We'll see if we can solve the issue....Catriver..post back.
Apr 03, 2007 | KitchenAid KERI201P Electric Kitchen Range
Kitchen Ranges Logo
160 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
