Monitor shows blackscreen. won't respond at startup. suspect virus
  • dbellin Sep 29, 2010
    I don't get a color bar. I get a "Monitor is going to sleep" message and then black.
    Brigadier General:
  • 3,917 Answers
Are the Power Management settings correct? In the Control Panel, open up the Power Options. In there, make sure that the Turn off Monitor is set to Never, and that the Power Scheme is set to Home/Office Desk. Apply and OK. Here are some places to start.
1. Check the monitor cable. Make sure there aren't any bent pins.
2. Reseat the graphics card, if it's not integrated with the motherboard (removes and reinstall it -- making sure it's seated properly).
3. Right-click on the desktop and select "Properties". Click the "Screen Saver" tab. Click the "Power" button. What settings are in there?
Is the computer itself still running (can you hear hard drive fans etc?) if so then here are your possibilities
Bad signal/power cord on monitor. Move the cables around to see if the screen comes back on if no then see next.
Your monitor itself could be going bad or overheating, however this is the least likely of any of the options, so its one to get back to.
Video card over heating/going bad. Do you have a built in thermostat? if so what's the temperature reading when you loose signal? another option is to buy a computer thermometer or sticking one inside the case. Also try removing the side panel from the case and see if it takes longer for it to loose signal(better air flow, so lower temperature, if that works then you need to get additional cooling in your system). And as posted above reseat the video card/check connections. Also ensure that all fans are in fact operating.
CPU could be overheating. If this is the case the whole system will shut down, to see how to trouble shoot/fix this again see above post.
Now this is the mostly likely issue if your computer is running after the monitor goes black.
PSU has gone bad. The reason this generally identifies the PSU going bad is that the systems are built that if voltage drops, the computer automatically turns off the one thing it doesn't need to keep running which is your graphics card. Even if the power goes back to the correct output, it will not turn the graphics card back on without a reboot. In this case if you have another PSU you can test inside the case that is the only way to tell for sure wither or not the PSU is bad. Multimeter tests can be done, but they are not a guarantee because it may not be fluctuating at that exact moment your doing the test. though it is a test that should be done.
So If you here noise after monitor turns off first check:cables, then reseat card(s), then(or during the other tests) check temperature. as all those test cost nothing but a little time to do. then swap/replace PSU.
If the PC isnt running:Check temperature, this is almost for sure your issue. PSU should also be checked though.
For temperature if temps are above 48 degrees C you need to get additional cooling in the PC with fans, though this may only help some because if the case design is bad you will still not get proper air flow. Another option would be to with the side panel of have a fan or two blowing inside of the case to help cool.
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Sep 29, 2010
  • 182 Answers
Follow these steps o find out and fix the problem :
1. unplug your monitor from the CPU ( tower ) and then plug the monitor to the power supply and turn on, if you get the color bars on the screen that means the monitor is fine. But if you don't get it that will indicate that the monitor is faulty.
If you donot get the colour lines try unplugging the cable and replugging it.
I don't think it is a virus because if you have a virus your computer will not fail at POST ( power on self test) it will at least initiate the boot process.
If you don't see anything at all that means a hardware failure on you try to boot your computer.
  • Goldi Kunal Oct 03, 2010
    Hope this has been fixed, an update
    Thanks
Blackscreen on start.no display
Try the extension RGB monitor socket on a monitor to see if that works. If it does you might have hit the function key to switch the display to externel. Look in your manual about switching displays this will help you.
It will be something like <function F4 or something similar.
Dec 31, 2012 | HP Pavilion dv2000t Notebook
Tip
My laptop shows blackscreen so i reformat it and now its not anymore showing the...
Normally if the computer has the black display then follow these steps:
1) disconnect the pwr cord form the back of the computer //
2) disconnect the printer and the internet cord//
3)hold the pwr button for 1 min and then release// this is called "pwr drain" when the pwr cord is disconnected//
4)connect the pwr cord and restart the computer and see if it boots or not.
5)if not then disconnect the pwr cord again and open the side pannel of the computer//
6)on the mother board you will find the RAM (MEMORY CARD) which will be approx 6 inch long", take out the card/s and plug the pwr cord and restart the computer//
7) if you get the beep sound then the mother board is ok and if you do not get the beep sound then the problem could be mother board//
8)if getting the beep sound then fix the RAM CARD properly and restsrt the computer// it shoul boot//
note** during all this process make sure that the pwr cord is pulled out when you put your hand inside the computer or else you can get power shock..
on Jun 15, 2010 | Computers & Internet
Emachines el120006w momitor quits displaying shortly after startup or won't even display after startup
Try another monitor, reseat ALL monitor cables .If you have a Graphics Card, shut down computer, unplug and reseat Graphics Card.
Dec 15, 2012 | eMachines EL1200 PC Desktop
Samsung syncmaster940bw blackscreen with light blue blinking of its power button
That is a typical symptom of a failed power supply board. Here is a post that shows how to open the monitor and what to look for and replace to repair the unit.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-940mw-lcd-tv/
I hope this helps.
BuddyMc
Apr 18, 2012 | Samsung Syncmaster 940BW LCD Monitor
I just bought my samsung 22 inch monitor, and in the top left corner there is a display that won't go away. It have tried every single button on the remote and the monitor and it will not go away.
What is the content of the display? This sounds like one of the
family of viruses that hackers use. The smallest unwanted display
that I experienced was a simple period "." in the upper left oorner.
That told me that a hacker had placed some unwanted software
in my computer -- virus or other -- and I had to remove the application
and reload it. That little period "." also showed up on my Explorer
application and I had to reload that one also. My Mac does not have
viruses.
Aug 21, 2011 | Samsung SyncMaster 2233BW 22" LCD Monitor
My acer travelmate 2420 don't seem to boot, it only shows blackscreen with the HDD light constantly showing
laptop monitors can become disabled if they are dropped on the ground or in other ways mis-handled, in some cases the monitor panel has to be replaced, but it could be something as easy as reconnecting a loose connector between the motherboard and the monitor panel, any computer repair shop can assist you with this.
Jul 25, 2011 | Computers & Internet
Blackscreen on good monitor computer appears to be booting ok but nothing showing on monitor
Check your connections and make sure the monitor cable is plugged in properly.
Aug 22, 2009 | Computers & Internet
Monitor blackscreen
If you have access to an external monitor then conncet that to the external monitor port. Holding the function key and F7 or F8 should switch the computer to the external monitor. If this is OK then I'd say your mercury lamp has burned out. If no access email back the beep code. You'll have to listen carefully. In either case this computer will need to be repaired by a reputable computer repair person.
Good Luck
Mar 22, 2009 | HP Pavilion dv9000z Notebook
Dell Lattitude d630, freeezing issue
Had same problem -- changed motherboard and fan on video card -- for this laptop problem occurred twice about a year about -- suspect fan on video card was causing overheat
Dec 12, 2008 | Rosewill R900J 19" Flat Panel LCD Monitor
Open Questions:
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
