Question about Dryers
Does not run, power to dryer light on inside set dry time and turn start nob, does nothing.
  • Dryers Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 29, 2010
My dryer's cotton/time dry/wrinkle free option know turns freely. Dryer will not start.
Take the other knob from the other switch nd put it in that place. It should turn then . You will be able to turn it on by a pair of pliers until you get a replacement knk.
Feb 22, 2013 | Dryers
Power is on but nothing is happening when i push start. the dial wont let me change the time/dry setting. everything is lit up just nothing happening.
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer Repair - The
heatman101
Dec 17, 2010 | Samsung DV218AEW Electric Dryer
I have a Roper Dryer Model #REX3514PQ0 and it's about 5 or six years old. I was drying my laundry. The first load dryed fine. One the second load I notice that the setting nob up top was not moving and...
What I would do is pull the dryer out and unplug the power cord. I would remove the rear cover and check the components back there for continuity.f08dda1.jpg83a4f65.jpg15ccca9.jpgIf all of that is good then the timer or breaker might be bad. Why? The timer calls for heat through the RH leg. The amp draw from the heating element arcs up the contact point inside the timer. The motor runs on 120 volts the heater runs on 240 volts. So the breaker will take a beating on the heater side of it. The dryer will hower still run. To recap It could be the heater the limits the time or an electrical problem.6db32c2.jpga2de035.jpg
Rate it or Hate it:
Jul 15, 2010 | Roper Dryers
Dryer worked till I opened the door, light still comes on inside, but will not turn on!!!
First of all if you have aa ohm meter you may want to cheak your double 30 amp house breaker.If not that you may have a faulty door switch and stuck on close postion.If not your switch there is a fuse located on the heater housing behind the drum it is a small thermostat with 2 small brwon wires going to it.That may be shot.Try to bypass it and run dryer.Be carfull hope that helped any more to know on how to do these steps let me know hope i helped:)
May 16, 2009 | Dryers
Dryer stops working after 2 minutes into cycle
If it is new, is it not under warranty?
does it run ok on air dry? Is there good air flow?
post your answers in comments
May 14, 2017 | Whirlpool WED9500T Electric Dryer
EuroTech EWC177 washer/dryer combo reset
tinaheinleHello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, ..well this is a solution.....
my roommate unplugged the machine while it was drying. the start and spin lights were both flashing. I called the company and they told me to reset it, but the weren't sure how, lol.
I unplugged it and waiting, nothing. I flipped the breaker, nothing. I finally turned it to a setting, and turned on nob on the dry, and it started clicking.
I turned off the dry, and hit the start button, and it started right up...
If the next time you use it and it's fine then you did succeed in resetting the system and will be alright!
Let me know that we were successful!
Please remember to leave a rating before you go!
Thank you
Aug 30, 2008 | EuroTech EWC177 Front Load Washer / Dryer
Dryer stopped running, will not restart
When you try to restart do you hear a motor running? If you do hear that sound and the dryer does not turn your belt could be the problem. (broken)
May 26, 2008 | Maytag Atlantis MDG8400AW Gas Dryer
Equator EZ 2512 CEE Front Load dryer not starting
The blinks are the fault code on the unit you will have to watch them an count match them to the chart in the service manual
Here is a link to the service manual
http://www.appliancedesk.com/appliancedesk/service/CWD/EZ3612CEE_EZ2512CEE_EZ1612V/Service_Manual.pdf
Feb 20, 2008 | Equator EZ 2512 CEE Front Load Washer /...
Open Questions:
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
