Question about Moen & Replacement Cartridge
Moen bathroom faucet leaks from the cartridge. Unable to remove the cartridge. Do I need a special tool?
  • 4,336 Answers
Usually not a special tool needed. Moen will provide FREE replacements for you, call them up and they will ship to your door, free.
Posted on Sep 29, 2010
  • 1 more comment
  • jeffseivers Nov 09, 2010
    While Moen has an excellent customer service department, their FREE replacement policy is designed for honest people whose faucet is under warrenty.
  • Mike Nov 10, 2010
    Yes, and lifetime warrant would most likely still be under warranty....
  • rayr0683 Jan 23, 2011
    MOEN wouldn't even need Lifetime Warranty if they made a product that would Hold Up for years.....I see over and over...about myself included...how new cartridges are leaking, or leaking out of the spout/spicket...within months.....By now they should have figured a more Durable Cartridge. Ray
Hot water tap leaking what can i do
That is a simple fix - you need to replace the cartridge that is in the faucet handle. however, each manufacturer is different. NOTE sometimes you need a specially designed removal and puller tool. I found this out the hard way. I had a Moen faucet and needed a collar removing tool and a cartridge puller in order to remove the cartridge.
Google
May 01, 2017 | Water Water Heaters
How do i fix my leaky moen bathroom faucet?
Moen faucets are easy to repair. The cartridge you're looking for is most likely the #1224 cartridge, sold in pairs, and available at almost any home improvement store.
Shut the water off, unscrew the handle, remove the nut that holds the old, cartridge in, swap it out, and put the handle back. The whole job should take you about ten minutes.
Good Luck!
May 21, 2014 | Plumbing
Have a moen brantford bathroom faucet. One handle has become very hard to turn. The hot water side turns fine, but you have to use muscle to turn on the cold. Does the handle need to be replaced or the...
It usually takes a special tool to remove a Moen cartridge. Just getting the handle off can be tough. How long have you had this unit? maybe it would be cheaper just to replace the whole thing. My last Moen lasted a good twenty years, still working good, but finally starting to corrode. Good product.
Nov 30, 2013 | Moen 6610 Brantford Two Handle Lavatory...
I need replacement part for bath sink cartridge 4570
The Moen 1225 or 1200 cartridges are the same except the 1200 is brass in stead of plastic. They will fit most Moen single handle faucets. If it is a two-handle faucet, the 1224 cartridge will fit most two-handle models unless it is a fancy widespread faucet more than about 15 years old. I don't know the model numbers for those cartridges. All of these cartridges require a removal tool if you can't get them out with a pair of pliers.
Dec 09, 2011 | Moen Soap & Lotion Dispenser 3910S
Moen 2 handle bathroom faucet is leaking out of base of the left handle
There is a plastic retainer not with two tabs used for removal. You will need a removal tool to get this retainer off. Any plumbing supply that carries Moen should have this tool.
After removing the retainer nut, the cartridge pulls right out. Good luck!
May 23, 2017 | Moen Kingsley Two Handle Bathroom Sink...
Moen Eva two handle lavatory faucet - hot water leak from faucet. Old cartridge removed (had to get a special tool to remove it), new cartridge installed, and leak fixed. Four days later, leak is back...
Hot water side of most faucets give most problems try heating with hairdryer pryor to trying to remove,contact moen tell them of your situation they will more than likely send you a new cartridge free of charge if you raise enough stink about just replacing cartridge.
Jun 08, 2011 | Moen T943/MO4999 Eva Deck Mount Whirlpool...
Leaky moen 2 handle faucet
if memory serve's me,you will need to remove a stem extension,screw in center,and you may need a tool #103462 to remove cartridge.1'st stem ex't is red,(hot) blue (cold), remove, look down,white piece w/ 2 notch'es, this hold's cartridge down, ya might try needle nose plier's to remove,a little lube help's upon re assembly, carefull w/plastic thread's
Apr 26, 2010 | Moen Monticello Single-Handle Kitchen...
Removal of moen #1248 cartridge
That was exactly the solution I needed for my Jacuzi bath tub with the two handle faucet. The use of the screw in the top of the cartridge was needed to be able to get a strong enough hold on the cartridge stem. Mine is all recessed about 2 1/2 inches so I grabbed the screw head and stem with long nose pliers, and then clamped down on the pliers with a set of adjustable pliers, and then used a 1/2 block of wood as a lever to get pressure on. That got the cartridge to pop out! Thanks!
Mar 27, 2010 | Moen & Replacement Cartridge
How do I get to the valve cartridge to replace it?
how to replace moen cartridge for two handle kitchen faucet ... cartridge for two handle kitchen faucet exporters,how to replace moen cartridge for two handle kitchen faucet suppliers,how to replace moen cartridge ...cn-faucet.com/ kp-how-to-replace-moen-cartridge-for-two-handle...
Mar 17, 2010 | Moen Bathroom Sink Faucet - 4-inch...
I cant stop my Moen single lever kitchen faucet from leaking. how can I fix it?
1. If it's "leaking" from the body then, the O-Rings between the body of the faucet got gunked up with minerals from your water. This interferes with the seal.
The answer is to take some grit cloth/very fine sandpaper and clean the inside of the spout body. Wipe clean. I would also suggest replacing the O-Rings on the faucet body, but at the very least wipe the O-rings and faucet body clean.
THEN: lubricate the inside of the spout body AND the O-Rings with silicone grease. It's translucent and readily available and the only thing I would ever use for a faucet repair. NOT plumber's grease, NOT WD-40.
Reassemble and enjoy.
2. If it's dripping, the you need a new cartridge. You can get them for FREE from the hardware store if you have the old cartridge to trade them. The problem is that Moen cartridges are water-sealed into place and you need a special tool to break that water seal. The special tool (just a tiny piece of specifically shaped plastic, really) comes, you guessed it - with the new cartridge.
Two possible solutions: a) bite the bullet and just buy the cartridge (~$25) or buy a Moen cartridge puller, usually available from the hardware store as well for about the same price. Ask, they might even lend you one.
The point of whichever tool you end up with is to rotate the cartridge itself inside the faucet body to break the water seal so that you can pull it out with a set of pliers. There will be a retaining clip to pull out as well.
www.plumbingpartsdepot.com/moen7300.gif
http://img2.timeinc.net/toh/i/a/plumbing/faucets-toilets-07.jpg
Good Luck.
Sep 08, 2009 | Moen 87530 Touch Control Single Handle...
Moen & Replacement Cartridge  Logo
447 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
