Question about Roper RAS6233KQ Top Load Washer
Stops in middle of rinsing
My washer stops in middle of rinsing
  • Toby Norton
    Toby Norton May 11, 2010
    If you manually move the timer knob, can you restart it to drain? If you open the lid and start to close it do you hear a click?
  • 246 Answers
We haven't heard back on this in a week. I'm presuming the unit is now working?
Posted on Jun 21, 2008
Its stops when it reaches in 39 minute the function set on cottons what is the problem
Try resetting the mainboard by removing the wall plug overnight. May also be a faulty lid switch if it is a top loader.
  • Hello, my washing machine stops completely when it reaches ... www.shopyourway.com > Manage My Life > Questions ... my washing machine stops completely when it reaches the pause cycle, ... Answered in 5 minutes ... Kenmore washing machine 417 44252500.
  • Washing machine stops mid cycle - White Goods Help www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help Possible causes when washing machine stops mid cycle by a repairman with 30 years experience.
  • What could cause my washing machine to stop before the ... diy.stackexchange.com/questions/21181/what-could-cause-my-washing... What could cause my washing machine to stop before the ... i.e. it never reaches the end of the cycle ... What would cause my washing machine to stop at the rinse ...
  • Washer Stops Mid Cycle - Repair Parts - RepairClinic.com www.repairclinic.com/...A-Washing-Machine/50---/Washer-stops-mid-cycle ... listed below for the symptom Washer stops mid cycle are ordered from most likely to least likely to occur. ... Electrolux Front Load Washing Machine Disassembly
  • once my washing machine reaches the rinse cycle, about 3 ... https://answers.yahoo.com/question/index?qid=20080526150940AA3izVT
    • RESOLVED
    • 6 POSTS
    • 5 TOTAL ANSWERS
    2008-05-26 · Once my washing machine reaches the rinse cycle, about 3 minutes after ... Once my washing machine reaches ... My washing machine stops after the ...
  • Common Problems to all Washing Machine Brands ' Washing www.appliancerepair.net/washing-machine-repair-2.html Washing machine designs vary widely, ... but stop agitating after a few minutes and fill some more. ... stop the spin cycle and unplug the washer.
  • My washing machine will not spin and now it does not stop ... www.shopyourway.com > Manage My Life > Questions My washing machine will not spin and now it does not stop when it reaches the water level. ... Answered in 5 minutes
  • washer stops in the middle of washing cycle - Appliance ... forum.appliancepartspros.com > ... > Washer Repair
    • 6 POSTS
    • FIRST POST: 2012-02-07
    2012-06-22 · Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer stops in the ... but when the timer reaches 24 minutes left to ... Washing Machine stops ...
  • LG Washer Stuck Timer 2 - YouTube Youtube
    • BY SBUBANDIT
    • 14 MIN
    • 4.9K VIEWS
    2012-08-29 · Video embedded · In this video the washer display shows 8 minutes remaining in ... machine stops and turns ... 10kg Top Load LG Washing Machine
  • http://www.bing.com/search?q=washing+machine+stops+when+it+reaches+39+minutes&qs=n&form=QBRE&pq=washing+machine+stops+when+it+reaches+39+minute&sc=0-47&sp=-1&sk=&cvid=04BC47135B524BD8B5BAC3759F010C1B
    Jun 10, 2016 | Washing Machines
    Stops in the middle of rinse and says nd on the screen
    Is it rinse or pump out. Make sure the water is filling properly. Lot of times the water valve screen where the hose connects to the washer can get clogged with sand and not let the water enter properly causing this code.
    Feb 11, 2010 | Maytag Neptune MAH5500B Front Load Washer
    LG tromm washer stuck in rinse cycle
    • I had the same issue of being stuck in rinse and timer stuck at 20 min. Mine was a water flow problem, at the back of the washer where you hook up the water there is a small in line screen to stop debris from water supply. I removed them, they were clogged, cleaned them up, works great!!!
    Aug 22, 2009 | Frigidaire GLWS1339CS Top Load Washer
    Washer Stops Mid-cycle
    HI. this is a defective timer mechanism. it must be replaced asap, if possible. the timer is the principal initiator of the units cycles. The motor is defective at this point.
    Replace this damaged timer control device asap.
    Aug 20, 2009 | Kenmore 22422 Top Load Washer
    Whirlpool washer stops in the middle of cycle does not rinse and
    If your washer stops at the same time each wash, you have a dead spot in your timer. It will need to be replaced. .
    Aug 15, 2009 | Washing Machines
    Stops in the middle of rinsing...leaves some water at bottom-
    Calypso...The pumps fail often. They have redisigned one that theres not as many problems with, but if you still have the original, this is deffinatly the problem. As far as clothes getting stuck, the U-Joints wear out and cause too much play allowing things to get stuck. Total for this repair parts + labor will usually run about 500-600. There was a class action lawsuit for this machine and they no longer make it.
    Mar 08, 2009 | Kenmore 24032\24036 Top Load Washer
    Frigidaire washer machine stop in the middle of the cycle
    Replace your lid switch.
    The machine must have a goodd lid switch to continue timer functions after wash and rinse.
    Feb 28, 2009 | Frigidaire FWS833A Top Load Washer
    Won,t drain on rinse cycle
    Ok mc we need a timer at this point. You see the timer doing several steps different than before.
    Nov 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Roper RAS6233KQ Top Load Washer Logo
    Top Roper Washing Machines Experts
    Dan Webster
    Dan Webster
    Mike
    Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
