Question about KitchenAid KERS807SSS Electric Kitchen Range
Kitchen aid KGRA 806 PSS The " probe temp" words and icon feature on our Kitchenaide KGRA 806 PSS freestanding gas stove/oven will suddenly start to beep and flash.
    Brigadier General:
  • 3,917 Answers
This is a common issue and cannot be troubleshooted. The only way to fix this is to replace the temperature probe. The error will disappear and the range would start working fine.
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Sep 28, 2010
Kgra 806 top oven burner only works on broil, not convect, I already replaced the spark electrode
I think there might also be a thermocouple involved that keeps the burner /gas valve open when hot .
Jan 01, 2015 | KitchenAid KGRA806PSS Gas Kitchen Range
"kitchen aid model KeBS107SSS00 enter probe temperaure keeps coming on. I am not using a probe and it won't let me enter convec or normal cooking temperatures." Not my wording but it was the exact problem...
This happened on our Kitchenaid electric stove/oven as well! I unplugged the oven, opened up the outside panel of the oven (same side as the temp probe jack) and found a small metal tab adjacent to the jack. I opened that up to reveal the jack surrounded by moist fiberglass sheeting. A boiling pot of beans had over-flowed on that side of the range the day before. Moisture had gotten down in there and was crossing the connections. Once I dried off the exposed metallic parts and moved the moist fiberglass away from the connections, problem went away. Hopefully, a good self-cleaning cycle will dry up that moisture.
Sep 03, 2013 | Kitchen Ranges
Hi,My oven won't light but I can smell gas and hear the clicking when I went to light it Kit. Aid model # KGSS907 Thank you. Steve
which one is your model KGSS907SBL00 (30`` Slide-In GAS OVEN CONVECTION)
> KGSS907SBL01 (30`` Freestanding GAS OVEN CONVECTION)
> KGSS907SBL02 (30`` FREESTANDING GAS OVEN CONVECTION)
> KGSS907SBL03 (30`` Freestanding Gas Range with Convection Oven)
> KGSS907SBT00 (30`` Slide-In GAS OVEN CONVECTION)
> KGSS907SBT01 (30`` Freestanding GAS OVEN CONVECTION)
> KGSS907SSS00 (30`` Slide-In GAS OVEN CONVECTION)
> KGSS907SSS01 (30`` Freestanding GAS OVEN CONVECTION)
> KGSS907SSS02 (30`` FREESTANDING GAS OVEN CONVECTION)
> KGSS907SSS03 (30`` Freestanding Gas Range with Convection Oven)
> KGSS907SWH00 (30`` Slide-In GAS OVEN CONVECTION)
> KGSS907SWH01 (30`` Freestanding GAS OVEN CONVECTION)
> KGSS907SWH02 (30`` FREESTANDING GAS OVEN CONVECTION)
> KGSS907SWH03 (30`` Freestanding Gas Range with Convection Oven)
> KGSS907XSP00 (30`` FREESTANDING GAS OVEN CONVECTION)
> KGSS907XSP01 (30`` FREESTANDING GAS RANGE WITH CONVECTION OVEN)
Jan 04, 2013 | KitchenAid KGSS907SSS Gas Kitchen Range
After the oven preheats the I can hear the clicking, but the oven will not relite therefore the temp just drops. If I shut off the stove and put the temp I want back in the stove will lite, but again after...
there is a problem w/the burner....kitchenaide is aware of these issues and the new burner should come with a new ignitor already attached to it,poor design...
Mar 06, 2010 | KitchenAid KGRA806PSS Gas Kitchen Range
Oven went dead in self clean mode and the door remains locked. Is this the thermostat? How do I get the door unlocked when control panel shut down? Kitchenaide KGRA806
Unplugged the stove and turn off the gas.Take the back off the oven and replace the thermostat. It's super easy. Before you buy the part call kitchen aid... this is a known problem. They will say the parts are not free and try to give you a discount. But if you continue to argue , they'll send it for free.
Mar 02, 2010 | KitchenAid KGRA806PSS Gas Kitchen Range
Kitchen Aid oven does not get up to temp.
you can only calibrate the oven + or - 35 degrees. if you are over 35 degrees off you will need to ohm your temperature probe to see if you get about 1280 ohms if you do then you need to replace the clock control. if you ohm the temperature probe and you are off by more than 10% then you will need to replace the probe. in most cases both the control and probe would need to be replaced.
Feb 02, 2009 | Kitchen Ranges
Frigidaire Electric Range model FEF366EC - Oven disabled
You probably have a short that is causing the stove not to heat up or you not to be able to control temperature settings. The stoves are made only to last as long as the warranty, and when it expires, the stove all of a sudden wants to break down. You might have to get a whole new stove.
Jul 14, 2008 | Frigidaire FEF366EC 30" Freestanding...
Magic Chef freestanding gas oven/stove - oven won't ignite and heat, stove works fine.
most common problem with gas stoves is a bad oven ignitor, doesyour oven usually "click" start?? or use a glow style ignitor?? do you have the model number??
Mar 17, 2008 | Kitchen Ranges
GAS RANGE / SF368LEPT
Your probably right. The oven sensor, or what you call a probe, when open will not light the oven. Take it out and check for 1 to 1.5K ohms. at room temp. if you don't have that replace the sensor.
Sep 20, 2007 | Whirlpool SF367 Gas Kitchen Range
KitchenAid KERS807SSS Electric Kitchen Range Logo
389 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
