Question about Zenith DVT412 System
Stuck in progress mode help
My dvd 412 is stuck in the progressive mode and lost signal help to get me back to picture i can hear sound
    Genius:
  • Zenith Master
  • 1,550 Answers
Try this without disc on the tray press the button stop for 5 seconds.Good luck
Posted on May 25, 2008
I was playing with settings on my Zenith xbv342 and set the menu to progressive scan. I now have a blue screen with the words "progressive scan mode" I cannot get a picture and it is stuck in this m
Progressive scan mode is used by DVD players to artificially scale standard resolution DVDs to HD resolution, usually 720i. Is your set capable of receiving HD resolution? If not, that is probably why you are getting the blue screen.
Dec 18, 2014 | Zenith XBV342 DVD Player/VCR
Dvd, sound, no picture
If your DVD is external, I'd check TVs input settings: if your DVD on "progressive scan" mode, it delivers video signal via "component" connections: green, blue, red plus 2 separate red/white for the sound. If you trying to use 3 wires: yellow, red, white( composite), good chance, that the only sound is delivered. Try to switch DVD off 'progressive", if you only have 3 wires. It will deliver "picture". Or, verso-visa: using "component", 5 wires, but DVD set off "progressive scan". I've seen that confusion many times! Unless you have 'built in" DVD player. no matter what, it's must be broken! Use external DVD player, instead! $30 and trip to the store, will solve your problem. Don't want to fix TV, if everything else is alright. Myself, I never liked those "combo" units. You got stuck with mediocre TV and lousy DVD player. Better: separate them!
Good luck,
Alex.
Dec 25, 2011 | Toshiba Televison & Video
How do I get back to the Meue that I will show progressive scan mode. to remove progressive scan mode, because its stuck on the DVD, whereas we can't see the movie but we can hear the sound. I tried to...
1) Remove any DVD that may be inside
2) Press AND Hold Stop Button (on front of Player) for 5 or more seconds
3) All Done - This will have reset player back to Interlaced Mode and you can now see your DVD!
Feb 15, 2011 | Zenith XBV343 DVD Player/VCR
Dvd player stuck in progressive mode
ok i got a solutioN!!!
ok go to ur actual dvd/vcr player (not the remote) and press and hole the STOP botton for like 5-10 seconds.
thank goodnesss!!!!!!!!!!!!
your welcome! :]]
Jun 11, 2008 | Zenith XBV243 DVD Player/VCR
Stuck in Progressive Mode
Had the same problem; here's what i did. Take DVD out of Receiver, close door to receiver and hold down stop button on receiver itself for five(5) seconds. changes should take effect and progressive scan screen should revert back to sanyo screen.
May 06, 2008 | Dual DWM-3900 System
Stuck in Progressive Scan Mode...please help!
There should be a switch on the DVD player that is makred 'progressive/interlaced.' You need to flick this switch til it says interlaced, as obviously your TV cannot view progressive signals. It may be on the back of the player, or under a flap on the front.
Feb 04, 2008 | Televison & Video
GOLDSTAR DVD/VIDEO PLAYER
Remove any discs from the unit. Make sure your tv is on the blue screen. It should say "Progressive Scan Mode"....After removing the disc(s) from the disc changer, close the changer, press and hold the stop button on the unit, not the remote, for 5 seconds or more and it will reset to normal playing mode. Progressive Scan is typically only for TVs that use Progressive Scan....most normal TVs do not use progressive scan mode. Hope this helps...It worked for me!!!!
Jan 20, 2007 | Goldstar DV7411N DVD Player
I'm stuck in Prggressive Mode on my RDR-VX515
pressing and holding the PAUSE button on the front of the DVD player for 5 seconds. (this is the one that worked for me) Hurray!
pressing the PROGRESSIVE button on the front of the DVD player or P.SCAN button on the remote control to disable the progressive signal.
power off the DVD player and press 369 using the number buttons on the remote control, then power back on the DVD player.
moving the VIDEO OUT switch on the back of the DVD player to the INTERLACED position.
Dec 11, 2006 | Sony RDR-VX515 DVD Recorder/VCR
DVD/VCR stuck in Progressive scan mode
With NO DISK in the DVD player PRESS PLAY, (display will say "no disk" or something similar) then PRESS STOP AND HOLD FOR 5-10 SECS. Our DVD was stuck on Progressive Scan Mode for over 1 year, this fixed it. I had tried the press stop, press stop and hold while playing a movie, but not while there was no disk. Try it & Good Luck!!!!!!!!
Nov 02, 2006 | Zenith XBV442 DVD Player/VCR
Zenith DVT412 System Logo
108 people viewed this question
Top Zenith Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Greg Cann
Greg Cann
Gagan Telecom
Gagan Telecom
Level 1 Expert
Are you a Zenith Audio Player and Recorder Expert? Answer questions, earn points and help others
