Question about Frigidaire Dishwashers
Dishes not getting clean - Frigidaire Dishwashers
  • Frigidaire Master
  • 43,501 Answers
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Posted on Sep 29, 2010
It doesn't wash the dishes well, leaves dirt and doesn't melt the detergent
Dishwasher Not Cleaning Dishes - The Family Handyman
www.familyhandyman.com > Skills > Appliance Repair
When your dishwasher doesn't clean well, fix it yourself following these simple steps and avoid the expensive professional service call. A simple cleaning often ...
Why Doesn't My Dishwasher Actually Clean My Dishes ...
dishwashers.reviewed.com/.../why-doesnt-my-dishwasher-actually-clean-...
Feb 26, 2015 - My dishwasher is supposed to wash dishes, right? So what are all these ... The good news is that filters are incredibly easy to clean. The little ...
What to Do When the Dishwasher Won't Clean - YouTube
? 8:27
https://www.youtube.com/watch?v=aZojUCnQifs
Sep 21, 2012 - Uploaded by doityourselfstan
Dishes aren't getting clean in your dishwasher? The problem ...Whirlpool, Maytag, Sears dishwasher Repair & diagnostic - Not cleaning well ...
Jan 01, 2016 | Dishwashers
Any ideas as to why dishes do not come clean?
Their cold be a couple of reasons. Are your dishes stacked too close together inhibiting the water from getting to the dishes? Are you putting in enough soap to get the job done? How dirty are the dishes and how long has the food dried on the dishes? when I have a lot of dishes I always put the dishwasher on high temp to make sure the dishes get clean!
Mar 07, 2015 | Dishwashers
Dishes on top shelf not getting clean
Check your upper wash arm.... check the holes, especially the ones at the end of the arm. Are they possibly clogged with debris or hard water? This is the usual cause of dishes on the top rack not getting clean. The holes at the end of the wash arm are angled to eject the water at an angle to use the reaction to push the wash arm around. If those holes are clogged, then the arm won't rotate, and only those few dishes or glasses right under the arm will get clean, and the remaining 80% of the dishes on the upper rack won't get clean!
Sep 13, 2014 | GE Dishwashers
Dishes not coming out clean
Hello
There are some things you can try, however, if your Maytag dishwasher is not getting your dishes as clean as you would like. Maytag recommends several processes for fixing this issue with your dishwasher.
Do not run your Maytag dishwasher while hot water is being used in other parts of your home, such as washing clothes or showering. Hot water is needed for your Maytag dishwasher to properly clean dishes.
Run water in the sink in your kitchen until it gets very hot. Then, turn on your Maytag dishwasher. This will ensure that the water cleaning your dishes is the hottest possible temperature.
Clean your Maytag dishwasher to improve the cleaning results for dishes. Run your dishwasher on a short wash cycle and wait for it to fill up with water. Stop the cycle and add about 1/3 of a cup of rust remover to the dishwasher and finish the cycle. Run your Maytag dishwasher through one normal cycle with regular detergent to finish the cleaning process.
Check your detergent. Old detergent or those that have been exposed to moisture can be clumpy. This detergent will not clean your dishes as well when loaded into your Maytag dishwasher. Purchase fresh detergent.
Use extra detergent when washing dishes that have a lot of built-up grease or food particles. The extra amount of detergent is needed to get your dishes clean. Choose a long cleaning cycle to clean these dishes.
Fill your Maytag dishwasher properly. Dishes should not be stacked on top of each other or excessively crammed into your dishwasher. This will keep the dishwasher from adequately cleaning all areas of your dishes and from rinsing them thoroughly.
Sep 13, 2011 | Maytag Dishwashers
Not cleaning dishes.
check if some dirt got in the arms of the washer as sometime this will slow the flow of water and not allow the pressure to clean the dishes well
May 24, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Detergent is left in dispensers and dishes are not clean.
make sure you are getting hot water to D/W might also try different soap
Oct 26, 2009 | Dishwashers
Will not get dishes clean
If like you say the water pressure is good the water temp is good (120o minimum). The soap dispensor opens and nothing is blocking the arms from rotating then my guess is the unit is being overloaded. There needs to be space between the dishes so that the spray can hit the surface. Also, most folks know this but bears repeating... the dishes, cups, pots, etc. have to face down or angle toward the spray. I have seen people just throw dishes in facing up and then wonder why it doesnt get clean.
May 12, 2009 | Whirlpool 24 in. GU980SCG Built-in...
GE PDW9700 - The dishes do not get cleaned
Same as above problem: I have had this dishwasher for less than 4 years and the dishes as of about 2 years ago stopped getting cleaned. I use the recommended dish liquid and rinse and lightly clean the dishes before I put them in.
What a piece of junk!! gs
Feb 26, 2009 | GE Profile PDW8400J Built-in Dishwasher
Kitchen Aid dishwasher - top shelf not getting dishes clean
Is the top sprayer clean and not clogged so that the water can flow through? The top may not be functioning properly.
Jan 16, 2009 | KitchenAid Dishwashers
Dishes not cleaning
it may be hard water or some other minerals in your water. there is a new product out called the dishwasher filtration system and it actually filters the water going into the dishwasher. i tried everything to get my dishes clean but nothing worked until i tried this system. my glasses all had a white, cloudy look to them and it was terrible. you can get it at www.dishwasherfilter.com. it is very affordable and works amazing. the filter fits right under the sink and solves the problem immediately. if you use the discount code DFMTEN you will get 10% off
Apr 01, 2008 | Dishwashers
Dishwashers Logo
53 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
