Question about Sony FD Trinitron KD-34XBR960 34" TV
TV keeps shutting itself off!!!!
I have a sony kd-34xbr960 and last night it was working fine, but this morning we tried watching it and it will come on for about 30 seconds, shut off for 10 seconds, and come back on. Is there anything I can do to fix it or do I have a major problem?
  • Itan2Much Oct 27, 2008
    Our sets screen turns to green, then shuts off. The red light blinks for awhile, but the set won't turn back on. We use the remote to turn the set back on. It seems to happen after the set has been on for a couple of hours. Just started happening about 2 weeks ago and getting worse. Bought the set in Aprl, 2004.
  • soopacoopa Apr 07, 2009
    We have a Sony FD Trinitron KD-34XBR960 34" TV with the exact same problem. TV works okay for a while, then screen turns muddy green, fades to black, then shuts off. Then the red standby light blinks in a set of 6 pulses. We have to use the remote to turn the set back on. This set is only about 5 years old, and this is very dissapointing for a set this expensive. Any ideas on what the problem is?
My tv for no reason switches it self off ,after it jumps to a diff chanel its doing my head in any idea anyone
Posted on Apr 30, 2012
    Problem Solver:
I think the problem with the remote control it malfunction take the remote control away from the tv
and test the tv
I had the same problem and one time the tv came on by itself
now i took the remote control away and testing the tv
now for 15 min. so far so good
try it and let me know
or call sony 1--800-222-7669
email me
Posted on Jun 15, 2008
  • Dave a. Jun 15, 2008
    now sony telling me that a software need to be updated
    or may be hardware mal function
    so i'm wating for service will update
    i think soy should pay for that
Sony KD-34XBR960 has no power; working perfect, on next start up the usual pop when powered on with remote, but failed to come on. No flashing lights, nothing. Unplugged, waited 24 hours, plugged into...
The problem is in the power supply, the most common cause is an open fuse and open capacitors, if the set is more than 10 years old consideration should given in replacing the tv especially if a professional gets involved.
May 15, 2011 | Sony FD Trinitron KD-34XBR960 34" TV
Sony KD-34XBR960....problem is that screen is black; LED light blinks 7 times in a row pauses and then starts blinking again. Have powered off and no improvement.
This tv have two power ICS left side of the FBT-The Flyback Transformer.The big black block of plastic with a red wire with a cap hook to a CRT(tv tube).Replaced those 2 power ICS,tv will solved this LED power light flashing,tv will have stable power again,tv will work.
Oct 23, 2010 | Sony FD Trinitron KD-34XBR960 34" TV
I have a Sony KD-34XBR960 that sound like it is
phillips has the same problem but if your tv actually turns on it could be a short or just a fuse sonys a better tv than phillips should be an easy fix call a repir guy going price for that problem is 75.00 dont pay any more than that. the economy is bad everyone needs the work be smart. make sure if you say yes to the work that the repair guy will waive the consultaion cost of usually 35 to 75 dollars, if you chose to have the work done.
Jun 02, 2010 | Sony FD Trinitron KD-34XBR960 34" TV
We have a SONY kd-34XBR960 I turned it off and
Turning your tv off did not cause this issue, so don't blame yourself for that. A 6 or 7 blink shutdown is because one of the two switch mode power supply control ic's have failed. the part number on them is mcz3001. They are located on the "D" baord, i don't recommend replacing this yourself because even with a tv unplugged from the wall high voltages still exist in the set.
A repairman may preform one of the two following things, he may change the whole D board or he may replace the individual components. The repair will cost around $200 if they replace the components, and if they replace the board it will cost more.
Sep 05, 2009 | Sony FD Trinitron KD-34XBR960 34" TV
Dear Sir, Is a 250.00 sony KD-34xbr960 a good buy(mfg date 6-05)? This unit is a sony "factory remanufacture" Thank you Arthur Dodge
Thats is a good deal, these sets last a long time and are very solid. I would have no problem paying 250 for that unit
Jul 16, 2009 | Sony FD Trinitron KD-34XBR960 34" TV
just try unplugging it for a little bit and see how that works.
Feb 01, 2009 | Sony FD Trinitron KD-34XBR960 34" TV
Our set turns itself off by itself. Prior to this happening, it goes to a green screen. It usually happens after the set has been on for a couple of hours. We bought the set in April, 2004 and the warrantly has now expired. The longer we keep the set on, the more it turns itself off. Is this a tuner, on/off problem or the tube? Any estimates for repair?
Jun 15, 2008 | Sony FD Trinitron KD-34XBR960 34" TV
Power/standby light flashes 7 times and the tv doesn't turn on
Audio Protect (7 Flash): When DC voltage is detected at the speaker or
woofer outputs, IC3604/pin128 (TV-micro) goes low and IC3604 turns off
the main power (AC relay turns OFF).
Troubleshooting Tips:
1) Main cause of defective will be located on the KD-board
2) Confi rm KD-board is securely seated on the G2-board
3) Replace KD-board
Jun 13, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Connecting PS2 to an old TV
Plug the Red, Yellow, and White cords into their respective "IN" ports on the VCR. Run a coax line from the "out" port of the VCR to the coax port on TV. Some VCRs require you to tune to channel 3 or "LINE" which is typically the channel before 2 for this to work. To make things easier, you may want to purchase a modulator. This would allow you more easily set this up. The Mini-modulators aren't very expensive and can be purchased at virtually any electonics store.
Aug 11, 2005 | Sony FD Trinitron KD-34XBR960 34" TV
Sony FD Trinitron KD-34XBR960 34" TV Logo
467 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
