Question about E-Flite RS232 Serial LinkProgramming Software (EFLARS232) Serial Adapter
I purchased the E-Flite RS232 programing adapter and software. What would be the best setting for the PWC and Timing. I am using the 60 amp E-Flite ESC with an E-Flite Power 32?
2 Suggested Answers
SOURCE: eflite 60amp esc - no throttle responce
Lower throttle trim all the way. It will arm like a charm.
Cliff
Posted on Jun 24, 2010
How I can transfer my files from a Acterna 5100E OTDR to my laptop? It only has a standard internal flash drive and 9 pin output. I have the original software.
This devices interface is extremely old technology the 9 pin connector is most likely a rs232 serial interface . If your laptop has a 9 pin rs232 interface you may need a DTE to DCE adapter .
if you do not have this old rs232 port on your laptop I think this device a usb to null modem rs232 DB9 Serial DCS Adapter Cable with FTDI.
http://www.startech.com/au/Cards-Adapters/Serial-Cards-Adapters/USB-to-Null-Modem-RS232-DB9-Serial-Adapter-Cable-DCE-FTDI~ICUSB232FTN
https://en.wikipedia.org/wiki/Null_modem
from my reading of the manual a null modem may be needed
Nov 16, 2015 | Cell Phones
I purchased a serial port that is not compatable with my sewing machine, I also purchased an updated software with Bernina to make my embroidery machine user friendly. however,I am unable to connect
Problem is that the Bernina software you are using expects to talk to a 'COM port and the PC's USB serial interface doesn't automatically default to a COM port. Make sure you have installed the software that was delivered with your USB-to-Serial adapter and look on your PC's 'Device Manager' under 'Ports' - you should see the USB adapter listed and it should be assigned to a COM Port number. You need to check what COM port numbers are accepted by the Bernina embroidery software (sorry, I cant remember and haven't got one here presently) - it should be in the Options menu. You have to ensure that the USB 'virtual COM port' is the same as that which is set in the Bernina software. If the Bernina software doesn't support the COM port allocated to the USB interface, go to 'Properties, Port settings, Advanced, COM port number and set this to the same as the COM port number in the Bernina software - hopefully this should set up the link OK, provided you haven't got a COM port clash - to avoid this, it's usually best to choose a COM port number of 2 or above.
Dec 02, 2011 | Bernina Artista 180
I have an Sam4 ER600 which is 9 pin seriel and only USB on my computer. I have got the recommended adaptor and software but my computer still doesn't recognise it... It says port failure. Can someone...
Buy an Athen usb-->Rs232 adaptor and install the program.. then go to hardware settings and set that usb port to Serial port 1 (very important)
After that you just start the program, opens your store @ port 1 and programs..
Jul 27, 2010 | Samsung Computers & Internet
I need a laptop with RS232 port. What model should I get?
RS232 is now not being fitted to laptops This has become old technology. If you have devices that require connecting via an RS232 There are USB cables that emulate the connections of an RS232 that can be set to a com port to fool the device that it has the rightr connection. Look on Ebay there are quite a few at various prices, most from Hong Kong. I have bought aqnd used them to connect my radio scanners and Scancat software to program Amateur radios quite succesfully, as well as to run my old HP A3 scanner
Please rate my help++++Thanks for using FIXYA
Jun 20, 2010 | Toshiba Satellite M35X-S149 Notebook
I Have Samsung Pleomax PWC 3800 personal Web camera which is giving problem to my computer. My CD ROM is corrupted or missing after installing the Pleomax webcam software. to windos vista home premium;...
You can download drivers and manuals from here
http://www.pleomax.com/
If no Vista drivers are available:-
Try running it in Compatibility Mode
Right click on your desktop icon or the file in 'All Programs' and select 'Properties'
Click the 'Compatibility' tab
Select 'Compatibility Mode' and choose an OS you ran the camera successfully in before.
Click 'Apply' & 'OK'
Restart your computer
May 28, 2010 | Samsung Pleomax PWC 3800 Webcam
Hi I'm Kandy When I try and load a card stitch I keep getting the following error message: PCDWIN22 Caused a General Protection Fault in Module PCD_WIN.EXE at 0005:38F6. The software then shuts down. I...
I replaced my USB/Serial RS232 port adapter with a genuine RS232 serial port on the PC. THis solved the problem. Further reasearch on the net indicated that USB to RS232 - serial port converters do often have problems. I previously had not had a problem running on Windows XP and this is what alerted me to the possibility of the USB/RS232 port adapter as a possible reason for the "new" problem.
Oct 24, 2009 | PfaFF Creative 7570
Activating SMDR on panasonic TDA100
First off the phone box is a TDA100, best done if you have programming software. If not go to the phone that has manager programming, enter the admin password, then goto program 800, rs232 parameter, select enter, and use the up down pad and scroll thru the settings to set baud rate, bits, ect. Programs 800 thru 805 are all related to the reports that the SMDR use. Also note the connection should be a null modem pin out.
If you have computer program for the system in the last section on the left you will see a tab for SMDR along with other manager settings. Sorry I can relay the exact the numbers and layout have changed in the different program tools and software versions.
Jul 25, 2009 | Panasonic KX-T7630 Corded Phone
Eflite 60amp esc - no throttle responce
Cliff
May 23, 2009 | E-Flite 60-Amp Pro Switch-Mode BEC...
Sigmatel s4 mobile go in flite mode
i have sigmatel s4 mobile go in flite mode and i dont open settings menu
Dec 18, 2008 | Handmark Software MobileLists (950142) for...
Reqd Software for BF-810
Go to
this page at Softpedia.com
and follow the link to download a free copy of the driver for the BafoTech BF-810.
Mar 17, 2008 | BafoTech BAFO BF-810 Serial Adapter
E-Flite RS232 Serial LinkProgramming Software (EFLARS232) Serial Adapter Logo
63 people viewed this question
Top E-Flite Computers & Internet Experts
David Payne
David Payne
Are you an E-Flite Computer and Internet Expert? Answer questions, earn points and help others
