Question about Kenmore 24 in. 16373 Built-in Dishwasher
Water leaking from under dishwasher. Hasn't been used for over 9 months.
  • Kenmore Master
  • 43,501 Answers
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
te
Posted on Sep 29, 2010
Beko dishwasher leaking from under the machine, only have it for 2 months. All water in pipes and waste pipe seem fine.
If you have only had it for two months I would suggest you contact the dealer and have it repaired under warranty. Any attempt to fix or adjust the unit will void the guarantee.
Feb 06, 2011 | Dishwashers
It says error 01
Error code 01
Leak Detected - When water is detected under washer
tub.
Dec 16, 2010 | Electrolux EWDW6505GS Fully Integrated...
Bosch exxcel auto option - Have not run it for a couple of months. Turnit on al all it does is pump out
The usual reason for this is that water hes leaked into the bottom of your dishwasher under the washing compartment. This has caused the float to rise and trip the switch which activates the Aqua-Stop / anti-flood protection system. This also closes the solenoid (water control valve) to stop water entering this dishwasher. You may already have had a small leak before you stopped using it.
The only way to check this is to remove the washer from under the counter (disconnect power and water supply first) and tilt it backwards about 15-20 degrees. Water should run on to the floor from under the washer so I suggest putting some old towels down first. Once the water has been drained from under the washer, you can use it again, but it's not advisable if you have a leak and this really needs to be investigated.
If there is no water from under the washer, you may have a faulty float switch or possibly a faulty control module.
Hope this helps.
Regards,
BElectric
Nov 23, 2010 | Bosch Dishwashers
Water leak from under refrigerator
Only two possible sources for a leak one is an ice maker, the other is defrost drain water. Either way it is only 9 months old and still under full warranty!! Call sears and have them come and look at it! I have seen a few of these units with cracked drain pans so be persistent if the tech cannot find a leak, have him pour some water into the pan to see if there is a crack.
good luck and save yourself some stress.. You have a warranty to cover this:)
Jun 11, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
No water going in and water leaks from front door
Leaking Dishwasher
heatman101
rrrw
May 29, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Water is leaking out from under the dishwasher,
Leaking Dishwasher
heatman101
fghjsd
May 15, 2010 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwasher began leaking underneath when turned on. Humming as if trying to start, but nothing further exept water on floor
I don't know how old this dishwasher is but the symptom your describing sounds like the ceramic water seal on the bottom of the impeller assy but above the motor has failed. When the seal fails it allows water to run though the motor and then the bearings in the motor fail. Once water starts running though a dishwasher motor they are pretty much shot. The reason for this is that the leak starts out slow and it leaks for a long period before you ever see the water under the dishwasher. So by the time you see the leak water has been going through the pump / motor assy for weeks or months. By that time the service technicians only option is to replace the motor pump assy.
Kelly
Apr 14, 2010 | Bosch SHU5315UC Dishwasher
Water leaking under floor when dishwasher runs
check the water to the unit it is locate under the door open the panel 2 -4 screw take flash light turn the unit on and see where the water come from ... it might be also from under your sink.
Jan 01, 2010 | Dishwashers
Kenmore 24 in. 16373 Built-in Dishwasher Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
