Had a small puncture in the rear bronze coils used epoxy to reseal it need know how to refill the refrigerant , need to know tools and how to do the job (Kenmore 580.75101500 Air Conditioner)
    Habit-Forming:
  • 156 Answers
If it's on the rear of the coil, epoxy won't hold. The rear of the coil is the high pressure side and it will blow the epoxy out. Even if you fixed it right, you would need a vaccum pump to evacuate the unit of air and moisture, you'll need to add service taps to access the sealed system and those need to be welded in, you would need a set of gauges, a refrigeration scale to weigh the charge in, and a jug of refrigerant. Just for the equipment I listed, you would be about into $1500, so it would be alot cheaper to buy a new one. Sorry my friend...
Posted on Sep 28, 2010
Coil in freezer has puncture , how to fix?
only way to fix this problem is silver solder. It takes an oxy/acetalene torch to melt the silver solder and plug the hole. Then you have to evacuate the line (pull a vacuum on the line) and then add refigerant for it to work again you need: oxy/acetalene torch, vacuum pump, and gauges plus the refrigerent (134) probably buy a new freezer for the price of all the equipment
Oct 03, 2014 | Haier Refrigerators
Is it possible to repair a small puncture in the freon line inside a small fridge
The hole can most likely be fixed with epoxy and a filter drier added to the refrigerator by an experienced refrigerator technician but the problem involved will be the cost to have the repair done. It would be less expensive to replace the refrigerator, Thanks Sea Breeze
Dec 04, 2012 | Haier Black and Decker 2.7 Cu. Ft....
While clearing out frozen rubbish out of the base of the chest freezer I've slightly punctured the lining, can I still use the freezer?do I need to put body filler into it.
Yes, you need to patch the hole right away with epoxy. Before applying the epoxy make sure you sand and clean around the punctured area to give the epoxy a rough surface to adhere to. Turn the freezer off and wait for it to achieve room temperature before applying the epoxy.
Dec 29, 2010 | Refrigerators
My Sanyo refrigerator (model SR-4431S) isn't cooling like before and certainly will not make ice... While scraping ice from the freezer compartment up top, I accidentally made a small puncture in the back...
Hi!
Before you can refill the system, you need to have the leak fixed. They have to evacuate the system, weld shut the leak, vacuum the system for 30 min. and refill refrigerant to proper level. This is a job that by Federal Law has to be performed by an HVAC Certified Technician. Take the unit to an appliance repair shop for repair, this way you'll save on the service call.
A HELPFUL - 4 THUMBS - Rating and a TESTIMONIAL would be greatly appreciated if you are satisfied with this FREE solution. Thank you for using FixYa.
Oct 22, 2010 | Sanyo SR-4310 Compact Refrigerator
Chipping away ice in magic chef freezer section i punctured freon line in freezer panel can refridge still get cold
No, the fridge will not get cold any more. The coolant goes to the coils in the freezer. The fridge takes a small amount of cold air from the freezer to lower its temperature.
I am sorry to say that unless you can find a way to repair the puncture and refill the system with freon, you are going to have to buy another refrigerator.
Feb 05, 2010 | Magic Chef CTB1922 Top Freezer...
Have a small leak in my small freezer unit coolant system
Good day,
Gas is not dangerous. But you have a serious problem.
Repair is limited to an epoxy repair, or replacing the coil assembly complete.
A new dryer filter must be brazed in, The system must be vacuumed out, charging ports installed ect,ect,ect.
You can call around to the service companies for a price, but it will be pricey, and you will probably have to take it in.
Not considered to be a practical repair.
Dec 24, 2009 | U-Line 15R Compact Refrigerator
Need freon recharge. punctures freezer coil in
You punctured the aluminum evaporator . In the many years I've been in refrigeration , I have yet to find any way to patch a hole in the evaporator . I've used epoxy , solder , and all different advertised ways to try to patch aluminum . Nothing worked ( for long anyway ) . My suggestion would be to buy another refrig . You will be wasting time and money trying to " fix " this problem . To repair it yourself , you have to have a license to buy R12 , maybe you can buy R134A without a license , you have to look on the " modell , serial number tak to see which it uses and how much to use . Also , the system has to evacuated ( all air removed from the lines ) . Do you have a vacuum pump ? You have to buy a solder on connector ( or saddle valve which WILL leak eventually unless you get a solder on valve ) which will connect to the larger tubing on the compressor or use the access line already on the compressor but is pinched off . Do you have guages for the refrigerant type you need to use ? Once you have these things , reply back and myself or someone else will help you procede .
Aug 19, 2009 | Refrigerators
I HAVE A HOLE IN THE REFRIG.LINE OF A HAIER MO.HC125FVS
Hi, unfortunate, sorry to hear that, but it could be repaired, you should immediately dried up water/ice around punctured area, prevent water/ moisture entering punctured area (evaporator. lines), it's one of the worst thing, that could happened to any refrigeration system, it will be costly to repaired, if water get into your evaporator lines, compressor oil have to be replaced, evaporator will need to be flush out, repair puncture, change filter drier, it's better to replace compressor, vacuum system for about 2hrs. then recharge. it's better to use welding/ soldering, to repair punctured line, epoxy repair kit can be used to repair punctured (evaporator) lines . you will have to call a mechanic, if very little water entered punctured( evaporator) lines, then flushing of evaporator, (internal cleaning of lines (tube) changing of filter drier, with overnight vacuuming will do the job. take note, job like this, cannot be guaranteed. check cost for repairs, sometimes it's better to purchase a new one, and save yourself some headaches.next time never use sharp instruments in your freezer, it happened to me sometimes, it's what you get your hands on, what's available at the moment, good luck.
Aug 15, 2009 | Haier HC125FVS Wine Cooler Beverage Cooler
Chiseling the freezer compartment I punctured one of he elements and now obviously not freezing.
hi, need new refrigerator. punctures in evaporator, is one of the worst thing that could happened to ref. to repair you'll need to replace oil in compressor, replace filter dryer, repair puncture with special epoxy, or soldering of aluminum, which is difficult, vacum and recharge, if done properly, system would be o.k. water in system is refrigeration biggest enemy, it's better to buy another one.
Aug 02, 2009 | Haier HSB03 Compact Refrigerator
HELP - I punctured the Evaporator coil - is it junk now?
i will give u an experience
if u can see that tiny puncture then u can fix it.
how? well take a 100 grit sand paper and slowly rough the punctured hole on the side of the hole approx 1 inch around it.clean it with a clean cloth. next take some petroleum ether soak a tissue in ththat and with the ether moist towel wipe the area and the hole nicely .now buy fro the market aluminium epoxy tubes. mix a little bit of the epoxy in a i:1 rratio and apply a coating of this stuff on and around the just cleaned hole.After about 12 hours the puncture is repaired now dont touch it.
Take the fridge to a professional refrigerant filling person who has experience in filling gas. he will vacuum the system and remove any ingress of moisture and then begin filling gas. your fridge will be good as new after this job
Jan 11, 2009 | GE Refrigerators
Heating & Cooling Logo
41 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
