Manual for Marshall G80RCD amplifier - Audio Players & Recorders
3 Suggested Answers
  • 1138 Answers
SOURCE: problem of marshall g80rcd, volume drop when i play
It sounds like your volume control is dirty. You will have to disassemble the amp enough to get access to the volume potentiometer which is soldered to the circuit board. There will be a square hole in it that you can spray some contact cleaner into the control. Use only contact cleaner as anything else could damage the control. Use a small squirt and rotate the shaft. If this doesn't solve the problem you may have to replace the control. While you have it apart, examine the solder side to make sure all the solder joints are perfect especially those on the controls. A bad solder joint can also cause the same problem. Before you take the amp apart unplug the power with the amp on and the volumes turned down. This will discharge the capacitors so it will be safe to work on. I hope this helps.
Posted on Nov 01, 2009
Testimonial: "thx alots, i did try to clean it by blasting air on it, but i just not really sure. i will give another try. thanks for your quickly response. "
  • 5603 Answers
SOURCE: My marshall G80RCD plays perfect...but
A wild guess is that the soldering on the cold side of the volume control pot MAY be bad. When it vibrates and loses contact where it is soldered, the unit will go to full volume. Check soldering of ALL the pot leads into the circuit board. Look for a thin grey line around the lead part way up the menicus of the soldering.
Posted on May 12, 2011
Where can i find a Marshall mg30cfx owners manual
Here is a link to the Marshall MG30CFX manual, it is the same manual as the MG15CFX:
Marshall Amplification MG15CFX Owner Manual
Best of luck to you!
Mar 02, 2016 | Audio Players & Recorders
My marshall G80RCD plays perfect...but every now and again...for no reason...the volume will spike to explosing levels for a few seconds. Thoughts?
May 12, 2011 | Marshall Mg15dfx 15-Watt Combo Guitar...
Hiwhat is the best way to connect my DigiTech RP10 to my Marshall MA100H Guitar Amplifier
Read your manuals for both pieces of gear carefully first. You only have one amp so you won't be able to take advantage of all the FX on the Digitech as a lot of them are designed for stereo. The Digitech manual shows guitar into the Digitech and output from the Digitech into input of any guitar amp. Since you have a Marshall and can already get some great sounds by running your guitar straight into the Marshalls input, you would probably be better off using your Digitech in the FX loop. Run a guitar cord out of the send on the loop into the input of the Digitech and a guitar cord out of the left / mono output jack on the Digitech into the effects return jack on the Marshall. Start out with the effects level on the Marshall all the way down. Do the same with the Digitech with both the input and output levels. (Read the manual carefully) I think the choice of the Digitech isn't that great because it is already trying to reproduce a lot of what you can already get with just your Marshall but with a little experimentation and some careful adjustments you should be able to add to the sound of the Marshall. Hope this helps.
Oct 23, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Problem of marshall g80rcd, volume drop when i play
Oct 31, 2009 | Marshall Mg15dfx 15-Watt Combo Guitar...
Where to buy an instuction manual from for my marshall amp.
Click Here For A List Of Downloadable Books And Or Write Them An E-mail And They Will Send You One For Free Or A Couple Of Bucks.
Sincerely,
Michael Scott
Jul 20, 2009 | Marshall Amplification Marshall MG250DFX...
Marshall MG100 DFX manual
If you just bought it new, Marshall will replace any parts, or the store you got it from. If its second-hand I would have a look on ebay for parts.
The user guide can be found here...
http://www.marshallamps.com/product.asp?productCode=MG100DFX&pageType=DOWNLOADS
Good luck, its a sweet little amp!!!
Feb 13, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
509 people viewed this question
 Grubhead
Grubhead
