Question about GPS
APEX ACT3 cable tester manual - GPS
HOW DO I GET AN ANSWER FROM YOU PEOPLE
by asking the right question. If you ask a vague question you have a good chance of getting a vague answer .
as previously vaguely expained you have to do an auto scan
and let it complete.
This is based on your tv being connected to an antenna and being the model Apex Digital Apex LD4088 40 Class LCD HDTV - 1080p, 1920 x 1080, 16:9, 60Hz, 1800:1
You have to press menu button on your remote control when you see the message you saw on the tv screen.about Auto Scan. Then use the left and right arrows to select tv mode. Press the down arrow to select Air/Cable. Press the left or right arrow to select Air if antenna and Cable if it is a cable service. Once you have selected Air or Cable press the down arrow to select auto scan . If air then press right arrow on the remote (if cable then press enter on the remote)
This is explained on page 18 of the tv user manual
http://data.manualslib.com/pdf/1/84/8384-apex_digital/ld4088.pdf?0fa28d37b4d5ca4a9f59538bc95467d9
Jan 13, 2015 | Apex Digital Apex LD4088 40 Class LCD HDTV...
Apex TV LD3288T can't find channels
Have you set it on cable, it may be set for antenna.
Oct 12, 2014 | Apex Digital Apex 32 Class 720p 60hz LCD...
I want to use my cable remote to operate my Apex TV/DVD combo but it will only turn the unit on and off by using a DVD code. Problem is that in DVD mode, my Cable remote will not change channels or c
you must read carefully your owner manual, and proceed with the instruction for to see if this possible. If you do not have the instr. manual go to www.fitness.manualsonline.com and download free.
God bless you
Aug 30, 2012 | Televison & Video
My apex tv has a blue screen with a red lock key on the left side
The TV has been locked. Unlock it. Refer to its user manual for details.
May 21, 2012 | Apex Digital Televison & Video
How can i check cable on ct100
These are a simple DC continuity/short tester.
You just plug both ends of the cable in and there are indicators showing condition.
HOWEVER: I recently found 6 brand new cables that resulted in HUM from mics. These cables had a pair of wires reversed at BOTH ends and contiuity was fine, but the shield was on the wrong pins of the XLR.
If this is your problem, you will find that the shield of the XLR is connected to pin 3 instead of pin 1. The numbering of the pins are weird on XLR connectors with pin 3 at the APEX of the triangle.
Cables MADE IN CHINA... I changed all the connections on site of the gig as I had soldering equipment. I informed the vendor... they had 13000 of these in stock and many must be in the field. They were going to check them,,, I am sure my 6 cables wern't the only bad ones.
Moral of the story: there is more to electrical cables than just continuity!
Jul 03, 2010 | Behringer Ct100 Cable Tester
Apex Model TV at1302 Manuel
You can download the manual at the link below.
Apex TV Model AT1302
Randy
FixYa Support Team
Jun 01, 2010 | Apex Digital AT2702 27" TV
Can i use the apex avl2076 for a computer monitor? if so,how?
Yes, you can but you need a VGA cable to go from your laptop/PC. If your Laptop/PC has a DVI video connector, then you also need to get a DVI to VGA adaptor. The manual below will explain how to connect your TV to a PC.
http://www.retrevo.com/s/Apex-AVL-2076-TVs-review-manual/id/524ci557/t/1-2/
May 02, 2009 | Apex Digital AVL2076 20 in. EDTV-Ready LCD...
APEX Digital VCR&DVD PLAYER ADV-3800 will not play DVD's.
What it so far done, it looks pretty fine. I'd break apart the problem if is posible to do it, i mean maybe you have some other sets around the house or some friend who have them.
  • i'd test the dvd/vcr in a different tv
  • i'd test the tv with a different dvd
i would start over again the installation after this test.
the reason is to know if you can trust in those sets and second maybe with some other try the installation works
May 01, 2009 | Apex Digital ADV3800 DVD Player/VCR
No Color playing DVD just black & White
Have you tried playing the DVD in PAL60,NTSC 3.35 or alternately select the colour system on the TV manually rather than in auto ?
Aug 25, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
GPS Logo
447 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
