Question about Bosch 30 in. NEM 732 / 736 Electric Cooktop
Hello left lower dual zone outer element does not
Hello left lower dual zone outer element does not go on, but inner one works. i don't know if this is the model #, in my booklet it says ETT730 i hope you can help me thanks sako
  • sako438 Oct 03, 2010
    how about the switch that turns the element on, how can i check the switch or the element?
  • 10,865 Answers
Hello. TO find the model number lift the unit up enough to look on the sides for a small plate with the model number on it.
You will need the model number to order the part, the outer element which is most likely burned out. J.
Posted on Sep 28, 2010
How do i turn the outer ring on for a dacor stove top
Pushing the button for the element will turn on the inner element at level 5. Before adjusting the level (so while the level indicator is still blinking) press the little circle on the right side of the controls for that element. The circle should light up. Now press the UP control for that element, and the level indicator should stop blinking. Now the outer and inner elements are both heating up. Adjust temp level to desired setting.
Jan 30, 2013 | Dacor Millennia ETT304 Electric Cooktop
I would like a circuit diagram for a Kleenmaid CH 14 Cooktop
Hi, I too have had a problem with the dual element on the Kleenmaid CH14. Likewise I was given an Invensys M82314 which as you will know is not configured in the same way. However, I assume that what they call"phase" is the active connection, the neutral is marked and are side by side like the old one, pilot is idicated and is the wire that bridges together with the other switches....you are only left with two...."load1" and "load2" whichever way around I apply those I can only get my inside burner to run. I am baffled !! My old switch operates both burners but keeps cutting in and out.
Nov 11, 2009 | Cooktops
Frigidaire ES340 Range One element from Dual element doesn't work
The elements DO BURN OUT. Replace it.
Often you can see evidence of a hot spot on the element where the final failure occured, but not always.
Oct 27, 2009 | Cooktops
I have a neff T1.D20 dual circuit hotplate but although the inner lights up and gets hot the outer part doesnt. Is the outer part supposed to?
I have a T172 model which also has a dual circuit hotplate.
In the control area you should find a dual circuit control pad - this has two concentric circles on it. With the hob switched on, pressing this button will chnage the mode of the dual circuit hot plate bewteen:
1. Just the inner part
2. Both the inner and outer together.
When the hob is switched off using the Standby control pad, it remembers which mode was selected and will therefore work the same next time it is switched on. However, it is worth noteing that when the mains power to the hob is interuppted, either by an isolator switch/breaker, or a power cut, the hob defaults back to just the inner ring mode.
Oct 03, 2009 | Neff T1323 Electric Cooktop
Heating element will not come on
The best to test that is to remove the top and take the outer coil and use it on any of the other burners to see if it heats up, then youll know for sure is the element or the switch.
Eddie Rentas
Tupper Lake NY
May 14, 2008 | Jenn-Air JED8430 Electric Cooktop
COOKTOP
its been my experience that the dual burner switch is far more likely the culprit, unless you can physiclaly see the outer ring is broken( visual inspection works wonders. as far as trying to ohm out i generally look at theelemnet itself (4 wires lead to the elemnt you can trace 1 to the outer portion of element, and 1 to the inner portion.WITH POWER OFF Iswithc those 2 wires and the restore power try element ad watch for outer ring to work inner ring no good. now i know its the switch not sending power. reset wires and order new switch
Mar 08, 2008 | Cooktops
Stove problem - outer cirlcle of an expandable element not working
You will need to call a professional these are very complicated and not easy to service, there are no fuses either. It will most likely be the element itself that has failed and they are not cheap. It also could be the switch too however it will take a person very familiar with schematics to properly diagnose it. Or you could just replace the element and switch yourself and that would most likely solve it.
Dec 26, 2007 | Cooktops
Bosch 30 in. NEM 732 / 736 Electric Cooktop Logo
67 people viewed this question
Top Bosch Cooktops Experts
Paul Carew
Jay Finke
Jay Finke
steve morris
steve morris
Are you a Bosch Cooktop Expert? Answer questions, earn points and help others
